Home » Eclipse Projects » Jubula » Obeservation mode assigned Tree Node Textpath cannot be reused(The TextPath name of the tree node I get during observation mode is always different)
Obeservation mode assigned Tree Node Textpath cannot be reused [message #705108] Fri, 29 July 2011 12:52
Marc Missing name is currently offline Marc Missing nameFriend
Hi All,
During observation mode I select a tree node. I get a 'Select Node by TextPath on Tree' test step with a textpath like 'the.specific.name.of.the.treemodel@a39579'/'the.node.name'
The problem is the "@a39579" part which is different each time you run the test!?
Has anyone experienced such an issue before?
I worked around the problem by using the library 'Select Node by indexpath' and mapping the tree object with it, but I wonder if there is a way to solve the strange variable '@xyz' part during the observation mode?
Marc
Previous Topic:Newbie - Input-Field with Sample-App
Next Topic:Obeservation mode assigned Tree Node Textpath cannot be reused
Current Time: Fri May 25 13:10:47 GMT 2018
Powered by FUDForum. Page generated in 0.02088 seconds
