Home » Modeling » Graphiti » Calculate minimal width of text in shape
Calculate minimal width of text in shape [message #698875] Wed, 20 July 2011 12:14 Go to next message
Joerg Reichert is currently offline Joerg ReichertFriend
Member
My context: I create a shape with an icon and (multi-)text in the AddFeature and I want to set the width of the shape according to the length of the text. Is there already a Graphiti function for doing that?
My current approach is to multiply the text length with a certain factor but this works out not very well. I found another approch by using FontMetrics in another Eclipse forum post, but do not know how to get a drawable from a Graphiti shape.
GC gc = new GC(drawable);
FontMetrics fontMetrics = gc.getFontMetrics();
gc.dispose();
int width = fontMetrics.getAverageCharWidth() * text.toCharArray().length;
Joerg
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Re: Calculate minimal width of text in shape [message #698888 is a reply to message #698875] Wed, 20 July 2011 12:33 Go to previous messageGo to next message
Jos Warmer is currently offline Jos WarmerFriend
Good question. I tried to find something for this as well and could not find it either. Also see this thread: http://www.eclipse.org/forums/index.php/m/651158/?srch=text+graphiti#msg_651158
Jos
Re: Calculate minimal width of text in shape [message #698898 is a reply to message #698888] Wed, 20 July 2011 12:40 Go to previous messageGo to next message
Member
Hi Jos,
with new Shell() the code seems to work.
GC gc = new GC(new Shell());
gc.dispose();
int width = fontMetrics.getAverageCharWidth() * ((text != null) ? text.toCharArray().length : 0);
This was inspired by:
http://www.eclipse.org/forums/index.php/mv/msg/164898/522303/#msg_522303
There is also a FigureUtilities.getTextExtents but this requires a org.eclipse.swt.graphics.Font to pass
http://www.eclipse.org/forums/index.php/mv/msg/3735/11116/#msg_11116
Joerg
Re: Calculate minimal width of text in shape [message #699346 is a reply to message #698898] Thu, 21 July 2011 11:54 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Graphiti provides the UI layout service for doing this
(GraphitiUi.getUiLayoutService().calculateTextSize(String text, Font font)).
As you see it also requires the font (and in the end delegates to draw2D
TextUtilities), but for knowing the correct extend of a text it is important
to know the font because characters might have different widths in different
fonts.
The thread Jos found is a different issue.
HTH,
Michael
"Joerg Reichert" schrieb im Newsbeitrag
news:j06hpp$eli$1@news.eclipse.org...
Hi Jos,
gc.dispose();
Joerg
Re: Calculate minimal width of text in shape [message #699357 is a reply to message #699346] Thu, 21 July 2011 12:28 Go to previous messageGo to next message
Member
Hi Michael,
sure you need the concrete font properties to calculate the size.
Thanks for pointing to GraphitiUi.getUiLayoutService().calculateTextSize
There are two overloading methods one taking a org.eclipse.graphiti.mm.algorithms.styles.Font
and one taking a org.eclipse.swt.graphics.Font, so it fits will.
Joerg
[Updated on: Thu, 21 July 2011 13:04]
Report message to a moderator
Re: Calculate minimal width of text in shape [message #699385 is a reply to message #699357] Thu, 21 July 2011 13:08 Go to previous messageGo to next message
Really, are you sure?
I see org.eclipse.graphiti.mm.algorithms.styles.Font for both the return
value of AbstractText.getFont and the Parameter font in
IUiLayoutService.calculateTextSize.
Michael
news:j095ed$v6m$1@news.eclipse.org...
Hi Michael,
But org.eclipse.graphiti.mm.algorithms.AbstractText#getFont returns
org.eclipse.graphiti.mm.algorithms.styles.Font the method above needs
org.eclipse.swt.graphics.Font. SO you have to convert the Graphiti font
to a SWT font first
org.eclipse.graphiti.ui.internal.util.DataTypeTransformation.toSwtFont(Font
pictogramFont)
When searching for references where this method is used, I found this method
org.eclipse.graphiti.ui.internal.services.impl.GefService.calculateTextSize(String
text, Font font)
that takes a org.eclipse.graphiti.mm.algorithms.styles.Font. So will use
this method instead (although it is in a internal package).
Joerg
Re: Calculate minimal width of text in shape [message #699392 is a reply to message #699385] Thu, 21 July 2011 13:35 Go to previous message
Member
oh, sorry I mixed it up in the Eclipse search result view. There is only one method for org.eclipse.graphiti.mm.algorithms.styles.Font.
Joerg
Previous Topic:ImageProvider using provided images from third-party plugins
Next Topic:Resizing of a Polygon - Bug?
Current Time: Sun May 27 01:42:25 GMT 2018
Powered by FUDForum. Page generated in 0.01945 seconds
