Home » Eclipse Projects » Technology Project and PMC » Q: Code for views
Q: Code for views [message #71161] Fri, 17 February 2006 16:38 Go to next message
G. Ralph Kuntz, MD is currently offline G. Ralph Kuntz, MDFriend
Sorry if this isn't the right group for this question...
I am considering converting a large Swing application to SWT. We use the
MDI pattern. I know that SWT does not support this pattern, but I really
like the way Eclipse allows the user to drag tabs to create new split
windows and then back to being just tabs on a single pane. Is there sample
code for doing this (or where in the Eclipse source code is this
implemented)?
Thanks, Ralph
Re: Q: Code for views [message #71181 is a reply to message #71161] Fri, 17 February 2006 17:44 Go to previous message
Jeremy Dowdall is currently offline Jeremy DowdallFriend
this should be a good start:
http://wiki.eclipse.org/index.php/Rich_Client_Platform
the newsgroup is eclipse.platform.rcp
also, in case you are not aware, you can embed your swing components
onto a SWT Composite using the SWT_AWT bridge, which may allow you to
migrate in a more controlled fashion. the eclipse.platform.swt
newsgroup should be able to help you with this.
enjoy!
> implemented)?
> Thanks, Ralph
Re: Q: Code for views [message #600051 is a reply to message #71161] Fri, 17 February 2006 17:44 Go to previous message
enjoy!
> implemented)?
> Thanks, Ralph
Previous Topic:Q: Code for views
Next Topic:marking a line in the editor
Current Time: Sun Jan 21 14:54:14 GMT 2018
Powered by FUDForum. Page generated in 0.01374 seconds
