Generic web template connector + auto-login [message #70420] |
Sun, 12 July 2009 12:43 |
Sebastian Hoß Messages: 3 Registered: July 2009 |
Junior Member |
Hi there,
I've recently tried out the generic web template and had great success
so far. The only remaining problem I have is that Mylyn "refuses" to
log me in every time I start Eclipse. I've talked about this problem
with the development lead of InDefero (the issue tracker I want to use
- http://indefero.net/) about the login request URL and we got it down
to[1]:
${serverUrl}/login/?login=${userId}&password=${password} &action=login
However I'm still not logged in. We are using a HTTP POST request to do
the actual login and all parameters are OK (I've double-checked them
like 20 times).
I don't know if it matters but InDefero doesn't require one to login to
view issues (but you have to be logged in to create or comment on
issues). Is that the problem? When is the usual time Mylyn decides to
do the actual login? Can I force this somehow?
Any help is appreciated!
Greets
[1]: It is essentially the same as the one for the Redmine tracker. See
http://www.redmine.org/wiki/1/HowTo_Mylyn. I don't have an Redmine
instance running anywhere so I can't check if it is working there..
FUDForum. Page generated in 0.02573 seconds
