org.eclipse.ui.navigator.CommonNavigator [message #693646] |
Wed, 06 July 2011 23:50 |
spcmdr Messages: 15 Registered: January 2011 |
Junior Member |
I need help to configure the org.eclipse.ui.navigator.CommonNavigator.
The restorable property does not work: I have to open folders each time a restart the application.
The delete id is only not available with popup menu. I can't delete file with the keyboard (but I can copy and paste them).
what are the properties that are configurable (the string name) ?
Is there a place to find help on the configuration of this view ?
when configuring viewerContentBinding, is there a place to find available contentExtension pattern ?
Here is my code
<extension point="org.eclipse.ui.views">
<view
name="Navigator"
icon="icons/eclipse/filenav_nav.gif"
class="org.eclipse.ui.navigator.CommonNavigator"
id="CommonNavigator.view"
restorable="true"/>
</extension>
<extension point="org.eclipse.ui.navigator.viewer">
<viewerActionBinding viewerId="CommonNavigator.view">
<includes>
<actionExtension pattern="org.eclipse.ui.navigator.resources.*" />
</includes>
</viewerActionBinding>
<viewerContentBinding viewerId="CommonNavigator.view">
<includes>
<contentExtension pattern="org.eclipse.ui.navigator.resourceContent" />
<contentExtension pattern="org.eclipse.ui.navigator.resources.filters.*" />
<contentExtension pattern="org.eclipse.ui.navigator.resources.linkHelper" />
<contentExtension pattern="org.eclipse.ui.navigator.resources.workingSets" />
</includes>
</viewerContentBinding>
</extension>
FUDForum. Page generated in 0.02732 seconds
