Home » Archived » Voicetools » Call drops when it gets to DB query module
Call drops when it gets to DB query module [message #692402] Mon, 04 July 2011 11:42 Go to next message
Sergej Missing name is currently offline Sergej Missing nameFriend
Member
Hi there ...
Call drops as soon as it gets to DB query module.
Any idea how to make this work?
Please look at attached picture and vxml.log
No errors or warnings can be seen from vxml.log Sad
Re: Call drops when it gets to DB query module [message #693763 is a reply to message #692402] Thu, 07 July 2011 07:20 Go to previous messageGo to next message
Member
Hi there!
In Tomcat log file: tomcat7-stdout.2011-07-07.log i found that sqljdbc.jar file cannot be found!
I've added sqljdbc.jar in MYAPP\WEB-INF\lib but again the same error occurring.
CLASS_PATH env. variable isn't set on that Windows 2003 Server - Application Server
Any idea?
INFO|2011/07/07|09:08:54|p=Interact_With_Caller|s=FEE1DF82B2A9071D86EB29FA1DF6D041|e=0002> Action "Database Query" Starting
ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> sqljdbc.jar
ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> java.lang.ClassNotFoundException: sqljdbc.jar
ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> at java.lang.ClassLoader.loadClass(Unknown Source)
Re: Call drops when it gets to DB query module [message #693764 is a reply to message #693763] Thu, 07 July 2011 07:21 Go to previous messageGo to next message
Member
Oh i forget to mention that i have both sqljdbc.jar and sqljdbc4.jar in Dependencies folder ... like you can see it from the attached picture above.
Re: Call drops when it gets to DB query module [message #693766 is a reply to message #693764] Thu, 07 July 2011 07:22 Go to previous messageGo to next message
Member
Randy! Can you help ?
Brgds,
S.
Re: Call drops when it gets to DB query module [message #694002 is a reply to message #693763] Thu, 07 July 2011 15:42 Go to previous messageGo to next message
Randy Childers is currently offline Randy ChildersFriend
Hi Sergej--
That error is a bit nonsensical, because sqljdbc.jar isn't a class name --
this makes me think there is an issue with the db configuration. If you
would, send screenshots of the db module configuration, but especially (
and more importantly, I think) send a screenshot of the export
configuration for the db that you see when you actually export the db --
I think that's where we'll find the error.
BTW, you've already done the right thing by putting the jar's in the
Dependency folder -- adding it to the WEB-INF\lib folder isn't necessary,
as having it in the dependency folder and then exporting should result
in the .jars being just where they need to be.
Randy
In <iv3m52$gpq$1@news.eclipse.org> Sergej wrote:
> Hi there!
> jar file cannot be found! I've added sqljdbc.jar in MYAPP\WEB-INF\lib
> but again the same error occurring. CLASS_PATH env. variable isn't set
> Any idea?
> Query" Starting ERROR|2011/07/07|09:08:54|p=Interact_With_Caller>
> sqljdbc.jar ERROR|2011/07/07|09:08:54|p=Interact_With_Caller> java.
> lang.ClassNotFoundException: sqljdbc.jar ERROR|2011/07/07|09:08:
> BundleLoader.findClassInternal(BundleLoader.java:513) ERROR|2011/07/
> loader.BundleLoader.findClass(BundleLoader.java:429) ERROR|2011/07/
> loader.BundleLoader.findClass(BundleLoader.java:417) ERROR|2011/07/
Re: Call drops when it gets to DB query module [message #694222 is a reply to message #694002] Fri, 08 July 2011 06:34 Go to previous messageGo to next message
Member
Hi Randy!
Here are few screenshots of db module conf. and db export conf.
Hope it will help us to resolve this issue.
Brgds and thanks in advance!
Sergej
Re: Call drops when it gets to DB query module [message #694527 is a reply to message #694222] Fri, 08 July 2011 18:56 Go to previous messageGo to next message
Hi Sergej--
I think we've found the problem. In the db export screen, you're
specifying
sqljdbc4.jar
as the JDBC Driver -- what it's actually looking for here is a class
file name (hence the error you're seeing), whereas this is the actual .
jar file name. Try something like this:
com.microsoft.sqlserver.jdbc.SQLServerDriver
And here's the document I got this from:
http://msdn.microsoft.com/en-us/library/ms378526.aspx
I'm not 100% sure this is the right answer for what should be in that
field, but at least we've identified the problem, so hopefully this
helps you along the way.
Good luck,
Randy
In <iv67ql$6h5$1@news.eclipse.org> Sergej wrote:
> Hi Randy!
> Sergej
> M_]C_X``02D9)1@`!`0$`8`!@``#_VP!#``(!`0(!`0("`@("`@("`P4#`P,#
> M`P8$!`,%!P8'!P<&!P<("0L)"`@*"`<'"@T*"@L,#`P,!PD.#PT,#@L,#`S_
> MVP!#`0("`@,#`P8#`P8,"`<(#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,
> M#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`S_P``1"`'``GD#`2(``A$!`Q$!_\0`
> M'P```04!`0$!`0$```````````$"`P0%!@<("0H+_\0`M1```@$#`P($`P4%
> M!`0```%]`0(#``01!1(A,4$&$U%A!R)Q%#*!D:$((T*QP152T?`D,V)R@@D*
> M%A<8&1HE)B<H*2HT-38W.#DZ0T1%1D=(24I35%565UA96F-D969G:&EJ<W1U
> M=G=X>7J#A(6&AXB)BI*3E)66EYB9FJ*CI*6FIZBIJK*SM+6VMC9VN'BX^3EYN?HZ>KQ\O/T]?;W^/GZ_\0`'P$``P$!`0$!
> M`0$!`0````````$"`P0%!@<("0H+_\0`M1$``@$"!`0#!`<%!`0``0)W``$"
> M`Q$$!2$Q!A)!40=A<1,B,H$(%$*1H;'!"2,S4O`58G+1"A8D-.$E\1<8&1HF
> M)R@I*C4V-S@Y.D-$149'2$E*4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
> MA8:'B(F*DI.4E9:7F)F:HJ.DI::GJ*FJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
> MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W^/GZ_]H`#`,!``(1`Q$`/P#4U"WT*U6XO`
> M6P.QJ>$`S(&^Z2,UXU^VC\5M,\>V-OI6H:]8:/)HV8N+W1$<X!`!$NIQD=>X
> MS]*_7X7]K&C%675]CY'!X&%:E*O5E;6R_,]OT*UAUVV2>VFAN('^Z\3AU;Z$
> M<5TNG>!C<*#MZU\=_P#!,C7O(^+OB?1K#Q8_B+1VL!=R0"YTB>.SF$JJI'V/
> M4;J12ZL_WHU4_M%?!SPA\;_VE?A%HGC3PMX<\7Z-]CURX^P:WIL.
> MH6OFK':A7\N567<,G!QD9/K7#G&(GA':&NJ7;=I>>Q%+"PYW%O0]9_X5N".E
> M)_PK0>@_*OE;0_CYXB^#O@WQ)X5^#(M]7LH/&FH6G@G3_P"R$UVW.BV6GVKZ
> M@('GU;3H8K2UU&:6!2;DK%@01Q%54(?"O]K?Q]XJ\8ZG\4-8\4Z!H/@Z3N65^G>5_1,^J#\,P?X136^&0QRHKXU\0?
> MM(_%GXKZWX-TCQ58^#O"OCWP?\9+'2+";5+&.SM8DN_#5[(CW-I:ZI?@RJ9W
> M*0I?*9\PH3`7+#M/'_[='Q4T/X?ZAHVCKX0U_P")_AW6->@NFTCPW]JTG5=,
> MTP0^;?*MWK5DEFL3W5M!,INHW>F]DH.3_P"W>=<R
> M\FU>SL5,J4?9):\Z7WMU$E\U3;3\[=K_`$7<_"T,/NUFW/PH&[^W#X
> ML\+1^%_%FN6&EZ7X/\3^$/M()T0&.5G:2.WWOV(OCC\6_CC%<ZE\0/!MEI/AC5=+M=5T'5K2/3X8+CS<L
> M85^S:OJ)N$\MHW6X(MPPS^Z&1CJ>.J*M*@+;M)\L\'&
> M-*%?"/CSPOXFUZUOO$6K.BZKX)@M;J7^S%LGYR7;X&D_S]>]CU
> MV7X4C'W:K2?"<?W:\>^&WC\!W;_%
> M#PREWX3L](LKFR2/7I(X&MM(DFFN)#<M<F<E&2.$HMO+D,/F&]/-9R5TGTWT
> M^)-Q6MM9<KMYV6^A-3`QC4]DVKZ]?Y6E+_P%O7[]M3V.7X3#^
> MGI%MY$ZPB1+6]$&%9XHF1?+,L<8636&:U.::E\,&]?\`#!3;MO\`#=Z7^'NX
> MINIED%2IS3UFD[=5>4H_G%7V^+LFU[)<?",'M5.;X/AOX:\<\1?MK_$+P#\&
> MXO&.HWGPR\11>+O`>J^,M`M-'LF$_
> M?`1Q_$K]LWXD?!K3=9MB2.Z^U7JQW
> M"`LKQ2^?:+<>5(N(/OC?^UY1E>EYQ7SVLFSUJ?X.`_PU4E^#`S]VN"T'XY?'C5AX3\.ZOX=\)^#/$_
> MB+6;^S_M#6M.$T4EC!9I<)=+8V6IW`1S(7A,37QR$\W<N1%7!_#+XP>+_`GA
> M;PCJ7CA_#/Q%O)OB-XMM+69=#G34--2S@UR4BT>:#BM-3T:WU;PY>M%9_9P9'!>-%M
> M=7NVU`B!]\;$V*RM'M)B\S='W/B;XJ2^._V)M3\0:?XC@N
> MX\QR?4Z/-9O3OTZ/3:^_RV=A'^!@;^"H7^!&3]VN#UC]G'X.3?%CXKWGC#PM
> MX0L](\$Z'HT=EJT]M#:W'AJVBM9B'M;L;9+0Q[0RO$Z%&4$$$`URMO\`MC?$
> M0@9)V697\J*PN-K<.4#C
> M;G2XCFV^?3WN5=>LDF]-+\C?7K:]C2GE<*D.>'W/1MKMW_X;N>QM\!1CT/XN?%#P'X(\31KK^D^*O%&M^/-1TCPSI]MX3ENYBL+W$D\9^T:Q
> M;PB-88]R%IX5C$94>:TB*.<\`_'OQU\8?%>C^+=#U+X;>%O$>I?#'^UM1_MJ
> M"6]M'^RW]RC^3%!=)MA+D,TWVB5804`$V\.(CQ7-PI3::4TI>B]DZC?G9*S]
> M;J^SMY-!SG"+3<6UZVFH?+5W7I\SV,_`%1_!3&_9_4_P5YQJGK7QU\+K;Q/IMW::+J'C0ZO8:=I&B6_A^6TBTZ*\N)(X;AKV6DW&:=^9PMWDN71:VN^=-=U=Z)-K*.41<>?I92
> M^3Z_*VOFTE=M(ZNM#<SR><T@5H1*0&B5EJ.
> M>5I55!;/DU;M_$;2TWTMJG9]+-W2C^S*7+S7U]N:Y\._#OPOK4]CHVJ7^I6/B:_O=)L6(NIET@3Y2
> M!26OV=4BECD2?S(PQ?_587YLL/Q'4KS5.FI-OEZ/>7PJ^UWK\U
> M;>UYCED'3]ITU]=$F]-]+J_77LFUW=_\`Q#%D1UQ_B+X7-IP8A2,5N7'QGU[
> M6O'T_P`'/&-MX0UOQ7=WV+TV^F20V&I^&WM/,EO39R7$K(IEWV)#2R+YI5B"
> MK;!%\'KN6_\`@GID=S+/<OIDMWI4=Q/(TDMS%:W4MM'*2L_+_AKI^E[==5).UE?FQ>!IT>FWW_.SMHT^IYMJ.DM82D'C%,MI
> M=K5TGC:%%D8C&:Y2-_G(]Z^LHSYHW9X<XV=C5AD15M&W"M2"0
> M'(I:8IP:?2:&F2`Y%`.#3$;%/J`V9(#D44U#SBG4%+L/4Y%4M;XMS]*MJ<&J
> MNLH7MV^E)C.(N),7#>A-/*AP*K:CF&X.?6B.\!4#FO5H+W3R:\K2+B!11.BR
> M*1FJZW8'7^=+]K6M>5&',RG=:()FS47_``CD?I6C]K6C[6M3[*)HJK*"^'$/
> M:G?\(VA[5<^VIZTX7R^M+V,1JK(H-X?$?08J>VT50<GM5D7H-*MX`>M3["(_
> M;2+5B%L1U%6)/$"QKC</SK'NRH#=Z[
> M:LPW_O7/
> MK>XZGBI83!\BLG$T3`GG!_.F..*<6S36&14-%7,?QUKP\
> M-V7A.Z.1M\68/_A.^(#_`$J&S^."-C!8_C7&?MA^%;KQC\)/#=G:(?*&F_`#6%?!$X(Z@YXK\,X_Q-2EF4E&-]%^2/Z5\)
> M,NPN(RKFKU.5\SZ?\$^\H?C6A'\5;?P:TKQ;\;_!%KK6D>-?`%LMA,T/C6#6
> M+1]+E\`(J&8WD@:Z=;ZU:..;RY$:`.WEYV`7'V?X0M/@%J^S_EK^=>Y?!/XR
> M^(OV>_`&G^'/#?@'PZ;.]E9_&3ZI<_;Y?&D;1M$;9R85%O`JR2;$`D"G;G?F
> M;SODLFS&C*<_KJ26EKWO>_2RV0(OQK&G1W;1Z;J8TM]*.IVP5<3_`&62:5X@S[]H=]Q0(S+&
> MS%%FN?CBBCJP_&OD/Q9\$YM4\1ZA=:3I%QH.DW$YDM--;4&OS8H0/W8F9$9U
> M#;MI9=P7:"SD%CR^I?`35\_\MN?<UR5,QJ?6)1IQ3C?2STMY:'M8;(\&\!2E
> M6JM3<5=22YDZZ7_A#?AM_P!$G\`?^"M/\*^>OV!O`U]X#/CB&\21"VD>&4RPZ-]K\32;
> M?KLDC;'HZGN*^@MXK]ZX2HQK952E5CKK^9_)_'#]AGF(IT97BG^B%)P*\:_:
> M1_89\"_M1$2ZXFJ:9?Y&Z^TJX6">10"-K;T=&'N5SQUZUT_
> M_P"@%\,__!7J?_RQK[/#TJ\Y<]"#?*6NZ/DH8J5&+BI\O-TU_R9O+F7SKJ]8=#(^!G&3@``#/2O2OB)\,OA
> M_P#'G3'M]22V=AAF19D8*2!@D8)KX3_P#EC3U_X*`>/UZ:)\-/_!7J?_RQK/$Y3B:[;JTF[]W%_P#M
> MPH8V,7S*>OS_`,CB$JNU1M4D#`J63X>?#J1=%!\%>#V'AO3I=(T@'1&:_VE'3W]MM].O;N?6VG_LV
> M?!71O!-QX:M/A/\`#*U\.7=T;V?2H?#%BEE-<&)H3,T(BV&3RG>/<1G8S+G!
> M(JWXG^"GPG\9?#O2/"&L?#?X?ZMX3T!O,TO1+SP_9SZ=IK`,`8;=XS'&<,PR
> MJCACZFOCT_M_^/S_`,P3X:_^"S4__EC33^WUX^/71/AK_P""S4__`)8TO]7Z
> MK5G2=M.L>FWVNG0G^T5=/GV]>N_3J?9?A_X;_#;P=X\'BK2/`O@O2O$ZV2::
> M-8L]%MH+\6J(D:6_GH@D\I4CC4)NVA44`8`JG\,_AK\,_@+>:C<^!_`G@GP9
> M<:QM^WRZ%HMKISWNTL5\TPHI?!9B-V<;CZFOCYOV]?'K?\P3X;?^"S4__EC4
> M;_MU^.I!SH?PW_\`!;JG_P`L:M9#5OS>R=_6/7?*^79_VU?&EQ]4_^6-59?VO_%TWWM"^'?\`
> MX`:I_P#+&KCD,U=>R=F[D*68MJSFNW7:][;;7U2Z/7J?
> M4=WX*^&$GQ0E\</X$\#MXTG#++X@.B6IU20-%Y)#7.SS3F+]V<M]SY>G%8/C
> M?0;'Q=\0/`\\MUHUKX-^'\BZCI6@VVE^6\>H)#+;PR^<)=BP10S.%A6$$.%;
> MS,*$KYS?]J_Q5)UT+X>?^`.J?_+&H7_:A\32==!^'W_@%JO_`,L:VCDDE;]T
> M]+/>/35?:Z-W79ZK4S>/>MIK5-==GNMNJT?=:/0^O]=^(VB:KLI)XDD:SFV/'YL9()1]DDB:)3<0PR,CR1+)C<J.T4190<$QH2#M&/D=_VD_$3]=!^'_\`X!ZK_P#+&HW_
> M`&B-??KX?^'_`/X!ZK_\L:Z(92XNZIR_\E[6_F[:>AC+%R>G.OQ_R/:_'_PL
> M^'NL_#?XAZ-X:\/>$_!>J?$C2$MX;BY>=)`9IC&$:<AI&?#-R2>
> M0236MX:T#X;>#?!.K>'=-\&>#;'1/$`8ZQ86VCVT-KJG';2RJ$D=%C4!6=0`Q&"P`!S3K2_P#!&F^)I]:MO#7AJWUFXO?Y.[8[+G!(KYM/QTUD_P#,O>`?_`35?_EC0?CG
> MK)_YE[P#_P"`NJ__`"QK6.5Q3OOL;:?WO)?<C%UY_P`Z_'_(]MA^%WP;
> MMM-UFRC^&7PXCL_$;(^K0+X<LA%JC))YB&=?+Q*5D^<;\X;D<\UT^H:]X5U'
> MX:3^#CIFGP>%Y].;23IEM&L%M':F,Q^2B)@(@0OWV/<9/`_P`-M7UW1M<U_P`*^%_%?BW1(K>.#Q)K&C65QJY>#!CE,XB4
> MJX8;AL"A6.5`K1\::7\.?B1XRT>\0:/Y?V#4]1TBVNKRQ\MS(G
> ME32(73:Y+#:1ACD<U\^_\+RUG_H7O`/_`("ZK_\`+&D/QQUD_P#,O>`?_`75
> M?_EC3_LNG_SY>]_L;O=_%OYA]9J_SKMUV[;;>1[^'G@"\LM
> M!1(],MY]`M)(M.5&9D6%3&1&%+N0%`P68CJ:\,_X7AK'_0O>`?\`P%U7_P"6
> M-'_"\-8_Z%I_QL@^(GA:)?`7C!Q)%JFH>'=3Z%\/
> MV/PS>ZE::3;PW=Y*X8-))*J!W9@O4U1
> M\&^"_A3\.H;J/P]X`\":%'>W%O=W"Z=H5K:BXFMY/-@E<(@W/%)\Z,>4;D$'
> MFO"/^%X:Q_T+W@'_`,!=5_\`EC1_PO#6/^A>\`_^`NJ__+&JCEM.+4HTI)K_
> M``>7]1:.T^.VDT*R
> M#/)\IE,PEG,LFYG8",^5$!"-K%\Z+7-,\%^$-.T+2D,6GZ3:QVELC2-(PC10
> MHW,Q)9L#DDDDY)Y->5-\;M888/A6_\`]"S\/_\`P$U7_P"6
> M->M#$RBK*E+_`,E_^2//>#;=^=?C_D;-O+@BK\$G%<ROQ;U!>GAGX?\`_@)J
> MO_RQJ1?C-J:#CPU\/O\`P#U7_P"6-5]<G_SZE_Y+_P#)"^I?WU^/^1U%/4Y%
> M<P/C=JH_YEKX>_\`@'JO_P`L:!\;]6!_Y%KX>_\`@'JO_P`L:/KD_P#GU+_R
> M7_Y(/J7]]?C_`)'44]3D5RO_``O+5O\`H6OAY_X!ZK_\L:4?'/5Q_P`RU\//
> M_`/5?_EC2>+G_P`^I?\`DO\`\D/ZGI\:_'_(ZJG@Y%<E_P`+TU?_`*%KX>?^
> M`6J__+&E'QVU@?\`,M?#S_P"U7_Y8TOK4_\`GU+_`,E_^2#ZG_?7X_Y'6TDT
> M8GC(/I7*?\+WUC_H6OAY_P"`6J__`"QH'QYU@?\`,M?#S_P"U7_Y8T?6I_\`
> M/J7_`)+_`/)#^J?WU^/^18UOPP;AB5'6L=O"$H;.*T&^.^L-U\-?#S_P"U7_
> M`.6--_X7GJ__`$+7P\_\`M5_^6-5''5EHJ4O_)?_`)(AY?%N[DOQ_P`BD/!\
> MQ[4X>$)O2K?_``O/5O\`H6?AY_X!:K_\L:4?'75Q_P`RS\.__`+5?_EC3_M"
> MO_S\?_DB5EL/YE^/^13_X1"7TI'\)2JI.*N_\+VU?_H6?AW_X!:K_`/+&
> MAOCIJR_\E_\`D@_LZ'\Z_'_(Q)=#F20#!ZU<
> M@\*S2*#4LGQ@U.1\GPS\._\`P"U7_P"656(_CCJT0P/#/P35O_`(7MJ_\`T+/P-6_Z%GX=_P#@%JO_`,L:3_A>>K#_`)EGX>?^`6J_
> M_+&E]?K?\^I??'_Y(/*Y?_`(7GJ_\`
> MT+7P\_\``+5?_EC0?CIJY_YEKX>_^`>J_P#RQK.6)J/>E+5_^6-92E4?_`"ZE]\?_`)(T5%+:7IX;^'O_@%JO\`\L:E3]H;78^GASX><?\`3EJO
> M_P`L:PE"J]J4OOC_`/)&L8);S7X_Y'LNF:IR.:Z;1M5S@9KYYC_:3\01'CP[
> M\.__``!U3_Y8U;M_VKO%%L?D\/?#D8_Z<-4_^6-<\J%=_P#+I_?'_P"2-5R_
> MSK\?\CZ>LKS>HYJL`#X:_^"W5/_EC0N%**_P"81?\`DG^8WQ'C7OBI??(^
> MF_#>G:;X9TTV6D:=!I=G),;F6..6:>2YG("M---,/U84445[1QA1110`4444`%%%%`!1110`4444`%%%%`!1110`4
> M444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!11
> M10`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%
> M`!1110`4444`%%%%`!1110`4444`%%%%`!1110![K^PLVV'XD?[V@?\`N8KW
> M7[37A'M48^!FC?]CE9?^FS5J^;*]C)/X=3_%_[;$Y,9O'T_5A1
> M117M'&%%%%`!1110`4444`%%%%`!1110`4444`%%/MK:2\N(X88WEEE8(B(I
> M9G8G```ZDFOK?]F__@C3\4?C996VI>(/LO@'17CW+(.T5*7HE^K1[$.&\7+>R^?\`DF?BO17GG_HGW_E=U/_
> M`.2*/^'1?[//_1/O_*T?_DB_P#5C%?S1^]_Y'XF45^V
> M?_#HO]GG_HGW_E=U/_Y(H_X=%_L\_P#1/O\`RNZG_P#)%'_$0<N_DG]T?_D@
> M_P!6,5_-'_Y'XF45^V?_``Z+_9Y_Z)]_
> MY7=3_P#DBC_AT7^SS_T3T?_D@_U8Q7\T?O?^1^)E%?MG_PZ+_9Y_Z)]_Y7=3_^2*/^'1?[//\`T3[_
> M`,KNI_\`R11_Q$'+OY)_='_Y(/\`5C%?S1^]_P"1^)E%?MG_`,.B_P!GG_HG
> MW_E=U/\`^2*/^'1?[//_`$3[_P`KNI__`"11_P`1!R[^2?W1_P#D@_U8Q7\T
> M?O?^1^)E%?MG_P`.B_V>?^B??^5W4_\`Y(H_X=%_L\_]$^_\KNI__)%'_$0<
> MN_DG]T?_`)(/]6,5_-'$^_\KNI_P#R11_Q$'+OY)_='_Y(/]6,5_-'[W_D?B917[9_\.B_V>?^
> MB??^5W4__DBC_AT7^SS_`-$^_P#*[J?_`,D4?\1!R[^2?W1_^2#_`%8Q7\T?
> MO?\`D?B917_Y7=3_`/DBC_AT7^SS_P!$^_\`*T?\`Y(/]6,5_-'[W_D?B917GG_HGW_E=U/_`.2*
> M/^'1?[//_1/O_*[J?_R11_Q$'+OY)_='_P"2#_5C%?S1^]_Y'XF45^V?_#HO
> M]GG_`*)]_P"5W4__`)(H_P"'1?[//_1/O_*[J?\`\D4?\1!R_Y'XF45^V?_#HO]GG_HGW_E=U/_Y(H_X=%_L\_P#1/O\`RNZG_P#)
> M%'_$0<N_DG]T?_D@_P!6,5_-'_Y'XF45
> M^V?_``Z+_9Y_Z)]_Y7=3_P#DBC_AT7^SS_T3T?_D@_U8Q7\T?O?^1^)E%?MG_PZ+_9Y_Z)]_Y7=3_^
> M2*/^'1?[//\`T3[_`,KNI_\`R11_Q$'+OY)_='_Y(/\`5C%?S1^]_P"1^)E%
> M?MG_`,.B_P!GG_HGW_E=U/\`^2*/^'1?[//_`$3[_P`KNI__`"11_P`1!R[^
> M2?W1_P#D@_U8Q7\T?O?^1^)E%?MG_P`.B_V>?^B??^5W4_\`Y(H_X=%_L\_]
> M$^_\KNI__)%'_$0<N_DG]T?_`)(/]6,5_-'$^_\KNI_P#R11_Q$'+OY)_='_Y(/]6,5_-'[W_D
> M?B917[9_\.B_V>?^B??^5W4__DBC_AT7^SS_`-$^_P#*[J?_`,D4?\1!R[^2
> M?W1_^2#_`%8Q7\T?O?\`D?B917_Y7=3_`/DBC_AT7^SS
> M_P!$^_\`*T?\`Y(/]6,5_-'[W_D?B917
> MGG_HGW_E=U/_`.2*/^'1?[//_1/O_*[J?_R11_Q$'+OY)_='_P"2#_5C%?S1
> M^]_Y'XF45^V?_#HO]GG_`*)]_P"5W4__`)(H_P"'1?[//_1/O_*[J?\`\D4?
> M\1!R_Y'XF45^V?_#HO]GG_HGW_E=U/_Y(H_X=%_L\
> M_P#1/O\`RNZG_P#)%'_$0<N_DG]T?_D@_P!6,5_-'_Y'XF45^V?_``Z+_9Y_Z)]_Y7=3_P#DBC_AT7^SS_T3T?_D@_U8Q7\T?O?^1^7_KGN=
> M\[7/B*-GW3.[#*QH,`X^7IDG/&>7[BHHXV&+YL3332D[J^_3U,J^'E1:I3W2
> M/+_VVTV?`S1?^QRLO_39JU?--?2_GO2+N_O++3[2+QE9>9<74Z0
> M0QYTW5@,NY"C)(`R>20.M?)'_"V_!_\`T.7@W_P?6G_QROJN'<+7JT:DJ4')
> M<W1-_9B<>+HU).+C%O3MYLZ"BN?_`.%M^#_^AR\&_P#@^M/_`(Y1_P`+;\'_
> M`/0Y>#?_``?6G_QRO?\`S.@HKG_\`A;?@_P#Z
> M'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?_!]:?_'*/S
> M.@HKG_\`A;?@_P#Z'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?_!]:?_'*/S.@HKG_\`A;?@_P#Z'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?
> M_!]:?_'*/S.@HKG_\`A;?@_P#Z'+P;_P"#ZT_^
> M.4?\+;\'_P#0Y>#?_!]:?_'*/S.@HKG_\`A;?@
> M_P#Z'+P;_P"#ZT_^.4?\+;\'_P#0Y>#?_!]:?_'*/S.@I54NP5022<`#J:Y[_A;?@__H<O!O\`X/K3_P".5NW
> MX;>'XO$'A76'EU)K[['#JMM</.+6&2Z(\M7)88A)(P>`<\9KFQE#$8;#U,14
> MIRY8)R>CV2N^AI2P=:<U#E:N[;,_2)_9N\'Z=XP\6Z?#>_$6_
> MB$X$P#IH2,.(HQT\['WWZ@DJIP"6^P***_FW,,PKXVN\17=V_P`/)>1^E8;#
> M4Z%-4Z:LD%%%%<1T!17G'GO]DCXH>/=&AL+C6/!/A/5->L8KY'>U
> MEGM;26>-951D8QED`8*RDC."#S7SM^S%_P`%-X+SP?XX\3_$/XB?"SQW\//"
> M]OH93QY\.](NETF/4=2G>V;1G@CO-1>2ZA<V;,\<N`M]'OCCQN<C[SDNUOQ;
> M2^^WWV6.6__I2VUM=[)M?:%%>46O8\901S:.=8\$ZWI=E>.]K)="V^UW-I';I=B&*5C:O(LZ^6ZM&&4@<W\(?\`
> M@IU\#_CE'<S>'_&KBQMO#LWBT:CJNB:CH^GW.DP;!<WD%U>0103QP-(BS&)W
> M,#MMD"-D4/2]^E_3OT/>ZH>*_$,7A+POJ6JSI)
> M)!IEK+=R*F-S+&A<@9XS@5\L^$/^"KW@+N=+O$5K=\"6VN8XYX7]4E16'<"JY':7:U^[T<5G>%?VH]-M_`MK=>*XI=/UY+V]TRIH^,_B=XJ@>8BT
> MFC2,$X&6=`N3S@9R<'`X.`+'=^`O%C>-O"\&H26<EA,TDT$UL_X*FM8VA>.2XGF$:,JLYB$L:DBN9N*W5OG?FM;_P%E)/E
> MY^G7RV6OJW9>?R/LNBOFWP9_P4Y\$:U\2/C;HFMZ?XF\-:?\%M5M]-GU6Z\/
> M:J;?6?.M*_P""A?PKUG5O!VF0
> MZIXG76O'=U=V6D:1-X-UJ#5/-M);>*Y%Q9O:">S$1NK=V:Y2)1%()L^4"X()
> MRY>77F2:\TU=!)6U?I]RO^6OIJ>UT5XWIG;PW>M
> M0>(_#&JZ#<Q032RPP2P0WMM%)=1RRPR11M;K())%V(68@'C9_P#@IMX7OOVD
> M?AK\/-.\+?$M?^%E:3JFH6^I:GX`\1:8=-DM)OFGRV];Z6WOIN$DXWYM+*[\EO?TMU/;J*^</
> M^"C'Q7^+_P`!?AU8>+?AOXC^&VG6"ZOHVAWFG^)?"%I+1OACX*\1P^/_%FF7WB/X=6MI+XJN=*\.7U
> MA;DW0)MWMK-GN9764Y1%BEG+2(Z`EU*"8^]!S[-K]8O\`PZ"^A:C#I_\`:ED9A<Z?]ND@6U%V
> MBP2R?9_-\UHE$JJT;*YWO@5^V)\/_P!I/7M0T
> M5MBYC%U87-S!'#J%MN`_?VCRQ8>,K/
> MSOIZZ&YJ7Q&U>7Q3JFGZ5HMA<0:1)'!-<WNI-;"25HDE*HJ0RD@)(F2<<MCM
> M2?\`":>*O^@'X9_\'MQ_\AUQ_P`3/$VJ>"O#?Q/UG1;:&\U+2;PWD-O*A=9_
> M+TVR=DP&4Y900.>I'7H:%S^T#I]GXCU6ZGNK6#PCHFC6E]<WIBDDEEN+MSY$
> M,:KDLWEJI\M49W:XB"\G!5U?^O.WWV=O,5GO_6Z7X71W_P#PFGBK_H!^&?\`
> MP>W'_P`AT?\`":>*O^@'X9_\'MQ_\AUQ%C\>M"\53Z,=+UE;/[7K)TB>SU'1
> MKN&\:?(P)+[^R
> M;P6ET3)Y2K;3&+RS_4+?U\VOS1V/_":>*O^@'X9
> M_P#!+N83'+;H9&BFMI##,A8+QNVG#JP#`C,>F?M/\`A:PU.ST+5]7)\1*]
> MG97YMM(O!9P7=S%&\2-+M>.$2^:OEB27YB2H9F5L-:NW73\=OZ]`>BOZ_A:_
> MYGH?_":>*O\`H!^&?_!KSP]XM
> M\(:EJ][9Z[I*6.MW&BPVG$DLC)$SO'&CM$`P?&TFN@T
> M[]HOPEK&NV>F6=IPU6.W@TB\EDCM\RC=(%B/E-NAD0I)M<.`A7>RJ
> M5?2_];7_`"U]!M--KM^CM^>AV'_":>*O^@'X9_\`!'O8=1^TNBND*V;Q"Y=V1U
> M=0L9)7+#(!(YG5_VMM+/B_Q#H<4&L:*ND>&D\0#5]2\.:D8+=6$U;[
> M_.MQ<-&(3*HC=M@?<5&X`J026W_`#7WDWTO_6NWY,[/_A-/%7_0#\,_
> M^#VX_P#D.C_A-/%7_0#\,_\`@]N/_D.IZP?'GQ-T7X96EO<:W=264%RYCCD%
> MM+*A8#.TE%8`D9(!QG!QG!P#L6]?^*?B'PMHMUJ5YX>T>:RL(S/<BSUF22=8
> MEY=E5>0>(?&VF_$'X(^)]2TF>2YLGTF^1)6@DA#E8'!V_:)_:A\(_LK>%8M<\
> M:-XEMM&82O-?:7X7U36K?3XXTWR373V5O,+6%5RQEG*1@`DMP<<GXA_X*,?!
> M[PO\9I/`-YXIO/\`A([;5K#0A>W\4$MC#<7T=NUI`;E;F$0F69
> M5E=BB%G1E51]Z7+'5Z$Y/9*_R6[]%W/;J*\6M_P#@H3\(L;X=>.-+\&WFCZ$WLBN27-R6U[=>WYIKY'IU%>'1?\%&OA
> M+)\.KWQ*^K^)K:&PUR/PU+I%SX-UJW\1-J4D"7$=HFCO:#49)&MW$P"6I!HOA/6-6U*633YC#?/]AM
> MK62Z6&WE`229HA$C/&"X\Q-S_K&GU$HMVLM]O/?_`"?W/L>P>/?%
> MC>"?"\^H1V<E_,LD,$-LCA#-++*D4:[CPH+NN3V&>#TK#_X33Q5WT/PT#Z?V
> M[/Q^5G3OB-K-IXC^'&EZCI]S!>V%_J>CW%M<0N'CGC>_MF1U8<%2I!!'4&O(
> MOB%\==0T+]I6U\&)XM\!^%K.73+*]ACUNU::\UB:>YGB:"W/VN$!L1)C"2'=
> M(.#P*JS4E!K5NW]?<0I)P=1/2R?WM+]3US_A-/%7_0#\,_\`@]N/_D.C_A-/
> M%7_0#\,_^#VX_P#D.N+T+]I7P9XE\;KX=L]5N)-3>]N=.7=IMU';-=6^_P`Z
> MW%PT8A,JB-VV!]Q4;@"I!/-^-/VP_#">!O$D_AK4/MVN:;H.HZSIT=UIMW%:
> MZ@EI'DRQR,B)-!O*#?$Y5LG:QP2(<E:_E?Y;EQ@W+DZWM\]CUC_A-/%7_0#\
> M,_\`@]N/_D.C_A-/%7_0#\,_^#VX_P#D.O/H/VAM'T+[=_:^J->7,=Y!9QV&
> ME:#>W-W!+)91W1BV1"5YSL8R;XT"JI"MRI)S-%_:KTBW^+7B7PUKEP+$V6K6
> M.G:8T>G71XNK2WDC%U(%9(&>:9T3S#'N*9/C/
> MQMIOP^T1M2U:>2VLD=4>58))@A;@;MBL0">,GC)`SDBD58N7'CCQ9#`ZZ?PIXAB\6^%]-U6!)(X-3M8KN-7QN59$#
> M@''&<&N(^''Q-T7XFA@MIECDD-M+$@8\[0750Q`P2!G&1G&1G?^"?
> M_)&?"/\`V!;/_P!$)0'4^-OV\X_,_:X\3<9QX0\+?^EOB:O'/LQKVO\`;BB\
> M[]KSQ0/3P?X6_P#2WQ-7D_V0^GZ5^D9'+_8XGQN:+_:)'RG_`,%RH/)_X)Y3
> M\=?&>D_^DVH5^<_CJMMJ5Q-\0/`DWAC3C:QHZPW+ZCI]T'EW.I6/9:2#*
> MAFW,ORX)(_O+Z.$,=4X%Q?\`9U24*GUO>*@W;DPZEI.,E;E;>U]-SSZJA.;7\#!U;]G3QF/AQ?^/]+\'>.KWX8VUX]M#XLG\/3P::X\WRD$DZ[X
> M(Y"Q53&)6P[;0S<$ZA_8G^,P\62:"?A'\3O8DT:>;^T%A^S000_8HXUA5XQ)\,E2HNFI
> MM^\_L_*ZUZ?R:[/WKN._Q+I?[)_Q3UQ_%BV7PU\?WC>`E9_$P@\/7<A\.A5=
> MV-[B,_9@%CD8^;MP$8]`:Z?]H3]AGQQ^R)XZ\$:5\4-+U3PI8^-=.L-6AOI=
> M+N46""XCADFCVSI"'N+83*LT0;"2#:7Y!KX-:67Q7?W4\X@6%5<E5>UMIK@%?,SF)/^6H8<C<?L5?&2U^)1\&2_"7XF
> MQ^,!9+J9T)_"]\-2%HTHA6X^SF+S/*,K+&'V[2Q^(7^+-G\!
> M;#Q+X/US5=+\,ZC:ZM\4+=Y47_A*KBW@L]/0VXMI*C3J8;GG-VE>.D+6AS)Q=G%RA*IRRM)QJPY6U&2
> MB*EAZCO?E7NOTYI:K7^6%K^:?0^:(_V./'WCCQ(=.\!?#_XL>+Y+71+'6;^,
> M>#+F.YM(UO6YM.T&>6T\*1V^I7EBOVFX3>BJXM'D#N(P,L,':6/TI\!?^"E/
> MP7\#_%+PCXOUSP]XFA\0>#-%\#Z=:ZE_PB&C^(9I$T:R$.H6D,=]<".R,\\<
> M#Q7\0:XC6+"K'N;.9H'_``4>^&ND^`/A=KVO\XV=^C35K232\#\<?L#>.8OB'
> MX>\,^`="\6?%#5=:\$Z-XUGMO#_AZXN6NM0>_N;"*PFO3+,\AF>WA9HH6?=N,<;,B$E5)`!KZGA+,
> M\\KU*E#-Z*@H1ARRM)2DW%.3=HJG;F;BHJ7,N6[
> MSO?7336VECGZ***^X.4*^XO^#;S_`)31?!G_`+C?_IBU"OAVON+_`(-O/^4T
> M7P9_YI_XE^9_5-1117^(1^E!111
> M0!PW[3OP8/[1W[-OQ`^'HU+^QCXZ\.:AX?\`[0^S_:?L/VJVD@\[RMR>9LW[
> MMN]<XQN&<U\^77_!,_Q-\0K/XUWGBCPM=MINOQZR+>.W7$SR,S/O;+(/^"4ME=?!/X;>!]1\;W<UCX"
> M^%^M_#2:YM=+6"?4%U**PC-ZFZ1UA:+XV^(_P`+O'/B
> MGQ;X;T3PVB:K\,)CH-DFF7UW=I<_8EU83-.S76Y7%TABFC61,`+&OLF@_"W4
> MO@G^Q/-X4UCQ/J?C/5="\+7-K=ZWJ$DTEQJ,H@<M(6GEFFQDX7S9I9`H4/+(
> MV7;UNJNNZ+;^)-$O-.O$,EI?P/;3H&*ED=2K#(Y'!/2KYW9KN<M-3>]D6:>62#
> M?#LE\U0RM&RA5+)M*D`>UVOPFN>II-C;:?;23/.T<*;5+N<D_R`'0``#```O\`_"K_Z''Q(/<6^G`_\`I+2"Y!X"M;Z]^&&L0Z9<VEEJ4VHZREI<75LU
> MS!!,;ZZ"/)$KQM(@;!*"1"P!`9<Y'S+\+/\`@DQJ'@?]G;Q/X&U/XD6>J77B
> M/X-6WP@&HVOAIK..VCMVU3R_DC6E
> M5G"W*[6L_FFI+XTT.3PM\49]#UI+&]\)
> M+?O8:QI4.G0PR3^9<F"\L)!IL/FV;P(SB24>>`1MWOV??^"<Y^"_C3P9K:WG
> MPO\`#;>$--\0Z:--^''P^'A#2<O_I.GDDDMD9P]U12^SMY:6_+\;O=L^#?@]_P1._X5IX3\70S
> M^./"R>(]>L-!6SUO0O`J:5/)JNC:A)J-IK.J;KR9]4O);EHVN7DDC\\(V/*+
> MY'N5Q^R]\2?$OQ<^%WC*U7^S_!-U::?K.FZC)9N\<$+Z
> MI+):W*?88@)GFG0:/NM'H#W<NK_RM^7W/7?4^
> M+O#/_!*;Q/\`#'X=:1X;\'_%FPTFVO\`X<Z=\,O&,]\1M+LO%)T^S\=^,?"WBJW
> M0Z:9CI<>B+HZK:Y,P,OFC21^\.W9Y_W7V?-],45:J24W5^TW=OO:7.K^DM4M
> MEJE9-HN4Y2ESO?\`X"7Y1BODCSG]JGX`?\-,_"-?"O\`:W]B;==T76OM7V7[
> M3_R#M4M-0\K9O3_6?9?+W;OEWWJ3)WA*F]GI^*?Z?J?#W[)'J3EZ7DY67DG)
> M^N[//]-C67Q7XR1@&5M80$$9!']G6->8:!^R-%X=^#VI>&8?$%Q)>W&K0:M9
> M:E+:JQLVM986L86CW?O(X4MX8R-REPK'*%LCV35/A6MWXDOM3LM<UO2)=3,;
> M745M]GDAE=$"!]LT4FUMBJIVXR%'%,_X5?>_]#AXC_\``;3O_D6BVMU_5FFO
> MN:T(OT_KM^NQY7!^S?>:IK>GZSKOB"VO]:CU]-;O9+733:VUPJ6,UE';Q1&9
> MVB4)+N+-)(Q;=T!4+F7WHMM,LD"
> M7>^=HKM`(XT=1%%O4-G!;(]G_P"%7WO_`$.'B/\`\!M._P#D6C_A5]S#^SMXC\#6DW@K0)O$
> M%O<6IN-"\+G3D%RQ:3;N^;S1SMR,+@P/^S#/>>'/$%I=>((GN?$
> M.K:/JTLT6GE$B:P6R!14,K'$AL\C+?)YF/FVY;UG_A5]I3R60JAR2.
> M=33_`-ER:QTG7(;?6-,T*?6?"\?AR,>'M'.F6VG,DUU*)X(A,Y3_`(^?N!LY
> M0D.-WR^N?\*OO?\`H</$?_@-IW_R+1_PJ^]_Z'#Q'_X#:=_\BU'*N7EZ?\#E
> M_+3\=R^9\W-U_P#MN;_TK7_@'A?@_P#8SG\"Z6\VDZSX;T?78-=BU[3VTSPR
> M+/2;.1;3[')&;-;C<Z21&3)\Y6WONW<8.WXW_9UUSQY>:Y<7?B?2HIO%/A)O
> M"^K>5HD@5F_TDQW$`-R3&`URQ:-S)N"@!UZUZS_PJ^]_Z'#Q'_X#:=_\BT?\
> M*OO?^AP\1_\`@-IW_P`BU4M=_P"M.7\O\]Q0?+;EZ6_!\R_'4\EO/V9;]]<U
> M*&W\2P0^%_$%[9:EJ^GOI9>T;N/2_\`A5][
> M_P!#AXC_`/`;3O\`Y%H_X5?>_P#0X>(__`;3O_D6G=WO_71_HB;+EY+:?\!K
> M\FQU4O$7AVQ\6Z)<Z;J5M'=V5VFR6)QPPZ_4$'!!'((!!!%6_P#A5][_`-#A
> MXC_\!M._^1:/^%7WO_0X>(__``&T[_Y%I#N<_P#$BSAT[X0>([>WBC@@@T.[
> MCCCC4*D:BV<!0!P`!P`*B_;-_9YU']J/X!7OA'2/$-EX6U9M5TG6++4IXB_X)T_V]X<^(NG_\)CY7_"?>,/"WBSS/[)W?8/D_?ROE_:/NOL^?Z9HJJ<W!WAIL_NDI+_P`F2?\`P`NKV^=K_`)(_/#3/
> MA3XOOOV[/A[X&\.ZIXQUWX>>!?B5KOCV\CU#X7:GH-OH"W-GJ8EB.NW92TU5
> M6O=3VVZ648<1,[2/*L6^NS\.?\$G/&>F>'-)T"X^-4%KH/@KP#K_`,/?!YT3
> MPI)INJ:3::E]C$5S<79OY//N8%LHUWQ);B3)(6-N:^W**B*2@H>5GYWCR_\`
> MI+:NVVKMWU+=67M?:Q=GT\K2E+\Y/:R\C\_)_P#@GZ?V$?A0WB31/$^@>&O$
> MEOX\MO%>EQ_#[X%ZCJ&@6,QTAM*FMFT#2KB:GX@\8:Z-)^*?PTA\2:;<V&NZL]ZC7.DM<V
> M\EG>A8***J[;<I:OIY*R5ON2VLM+L?L%BGEWMJF(+?>_D
> MQ#'R1.)_P#26G*3E+G>]FMK)?=
> MJOR1YC:?LV+;6^D1OK'F)I?BZ_\`%3#[)CSA="\!M_O_`"T;N/
> M'_"7P=USXG^(!X5&JZU-X7T#P5JOAFUU._\`!]UHIM1=^1#`A%RRF7?\*OO?\`H</$?_@-IW_R+1_PJ^]_Z'#Q'_X#:=_\BU$8I:=+
> M?^V\OX+;_A[Z<T::>?2FAL(K,/;20W<$D4_22<DD\DDDDDU>^"?_)&
> M?"/_`&!;/_T0E5+KX37=Y;20OXQ\3JDJE&,<5A&V",'#+;!@?<$&NHT+1;?P
> MWHEGIUFACM+"!+:!"Q8JB*%49/)X`ZT!U/BO]LZ+SOVP?%0QG_BCO"W_`*6^
> M)J\U^PG^Z/SKU3]KF'SOVQ/%H]/!OA;_`-+O$U<']@/H*_0,GE;"Q/D\QC>O
> M(Y/]H/\`94\+?MB0_#L2SN#;SGR-#UNYCVN`<?O(4SQ
> MR,CO3/\`B&`_98_Z!WCK_P`*!O\`XBO7;:T^S?'+X-G&,^-I?_4:U^L3]NOX
> M;Z#\/OC]'\;/&/A7P;\4_!WAVTTC3+JQU-D_M>_X*B^-]+_9I\`>
> M+(]-\%GQ#XG^"7BCXDW]F\%QY=OJ.EV]@\,2)Y^];<R7,RR*Q+G8H#J0<W'Q
> M9XT<.?\`MC%EC_`*!WCK_PH&_^(H_XA@/V6/\`H'>.O_"@;_XBO;_!'QR^,GQ`
> M^-FD?#V/7/A?HVKZ1X8T_P`8^(=0G\,7US%K%O?7ES&EEI]O_:,;1&WCMMLM
> MW)),&DFB(MXPVP8O[)GI/B#7/#`U-8;%9M/N-
> M-N)+=99+@:O)<RM,\+9MSI5OY8G0^=(J;Y=?^(I<;<_(\XQ7VO\`F(K?9?*_
> MM_S:+N_*S.;ZIAN3VGLXV]U;+/Y?>\EOK='E7_$,!^RQ_T#O'7_`(4#
> M?_$4?\0P'(U`>&M(:PAL;Q%^TH\EX\:+#&V)FF,91Q(5;TKQU^W7\5;7]J
> MWPUX$T&+PW-H&KWP\&ZOJ=WX:`AT#Q$VA3:EY8G.LQW%YL*P.T,6GI&8Y67[
> M8DB$#!^+7&JI\_\`:^+O:,K?6*VTHW6O/WM%]$Y0U]EC_`*!WCK_PH&_^
> M(KF?#7_X)?\`PCUVVUW1/B/\1KKP)<^--X#'A@?$'P=!
> MK&B:A!<W.LZJ=3T?0K-8K*E_;&*T
> MZ_6*V_,H_P`^W,VKJ_O1:\R)8"@MZ<=F]ETM=>3LXO7I)/O:+_B&`_98_P"@
> M=XZ_\*!O_B*/^(8#]EC_`*!WCK_PH&_^(KKH/^"@WQ=\5?M(>,/"_@OPSHGC
> M+P_?^'_$UUX$N)M+AT9M2U/1+)LRO^(8#]EC_H'>.O_"@;_P"(H_XA@/V6/^@=XZ_\
> M*!O_`(BOOSP3JFHZYX,TB]UC3#HFKWEE#/?:<9TG-A.R*TD/F(2CU?Y'YX?\0P'$=)1117YX=X4444`%%%%`!1110`444
> M4`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110
> M`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!
> M1110`4444`%%%%`!1110!\<?M/VQN?VR_&``Z>#/"O\`Z7>)JY3^R/\`9KO?
> MCY;?:?VTO&@QG'@KPK_Z7>)JR_[)/M7VF6U>7#Q1\WC(7K-F=X_U6W\$_%'X
> M.ZC=17TD$/CB7<EG8S7LYSX;UY1MBA1Y&Y(SM4X&2<`$UW7C'3_@Q\0_BAHW
> MCCQ!\+WUWQKX=5%TKQ!J'PMOL(/
> MC-\$B._CF?\`]1G7ZU/'_P"TK\0E_:XN/A?X&\!>#=>M](\.:=XDU;5==\8W
> M.CO#%>7E[;".""'3;L3.@LG;YY(@=ZCCEJ\7&2YJT+;]/57>_31/4]7#1M1F
> MWLM_1M+;KJUH6M)7X/Z!\7]0^(5A\-;BR\?:M!]EOO$L'PPU"/6+V+"+Y<MV
> MMD)G3$<8VLQ&(U_NBL;1?AO^S]X;U;7K_3O@OIUA?>*HA<YNF?MJ>%-,\0?%P>,=1\/>!/
> M#7PGUNQT:XU_6=;AM;&Z^U:=97B2/)*$2'YKU8@I=MQ4$'+;1Q*UM-DON3MI
> M_P"3+3SV.NTN;SO\)HLF4.^V:6R8PMF*,YCVG]VG]T8CM-(^"MA\:)OB1!\+##\1+A"DOBF/X6
> M7ZZU*IC$1#7@L?.(\L!,%_N@#IQ4'PE_X*(?#CQKX+AUGQ-XJ\$^!4U?Q=K'
> MA/P^FJ>)K6,>(WL-0ELEDM6D,?G--L1Q'&'*^:HRW#'WFJ2:]Y?U=)OYM-7Z
> M]S-I)N#Z:?\`@+:^Y-.W2^QX/<^&?@=>?&I/B3-\)HI?B+&05\4O\*;YM:4B
> M+R01>&Q\X8B_=CY_N?+TXJU-9_!NX^+A^($GPQED\>%44^)&^%VH'5R$0H@^
> MU?8O.PJ$J/FX!P.*]NHI)6M;IMY>@VQJMK:R_!ZZ>&VO+@*)[E$-AA9I0J[Y``S[1DG`K6N?#?P/O/BA9>.)OA
> M-'+XTTV036FOO\*;YM4M7$*0!H[DV/FHWDQQQY#`[]?U=W]3Y^E^'_P"GUKQ+J3_!NQ?4?&D<\/B"Z;X27AFUU)\><M
> MV_V'=.LF!O$A8-@9S4.K_"_]GKQ!\)M+\`W_`,%-+OO`NB7+7FG>'+CX0W<N
> MDV$"^-?A+POHEGIFF:'XOT`_Z!_CK_PBM9_^1:`_QU_X16L__`"+6
> MU\._C+I'BOQC9Z?:V?BN*>XW!-1._*QK<Z2BBBN(W"BBB@`HHHH`\]_:7^*<WPG^'7VNVG^QW%[
> M+)"MUY(F-I'';374TH0\,XAMY=H/!?;D$9!_/?X'_P#!4/Q#XP^/'P^TN(K#
> M;?%2%I="NH/%-UK#6,QB:>"VU*VE`MP9HT8,;7;Y3'H^PV<Z"&S>12R[@TFP,<#'!VSV?GY'FXZGC95:3PLXJ*?OIJ:VYK'B'PEI^EZEI>K:=?:`ULMY
> MI\^FW4-U:E/M4$\)"R01Y5XF!`(X<_:O\.:18?%;XG_%CX@R
> M>';.]CT:7@%AI]O&NH6HCVV\Q0B-9)?E8NQ/GT](R4MW
> M)_\`@/+'1>?,I6VU>K:;2]25G*/:R^_FEJ]M+.-]]+V2=F<Y\5/^"P_A']F^
> M7XD7?CFRUSR/"?C+2/!]MIL=AIVDR6=U?:3!J`CN-0N]4%@557<M/-):1J1Y
> M:B4A9)+GBC_@J)K<WQ=_9YT30?@_X]AT;XUV^JWMH4=E;NS(UN]
> MXA9D;9,\B&2.2#!@,J-
> MK>Z<3J$EMID6F/!/:26;V-U:W%O%F:VNK::)G=BJ)A`E3X;_`/!([X??!,\*^(_&V@+\&;W5FTOBTMV^!)^=E.8M>=^^K)*W+NV]CS+PW_P`%V?"&
> MD?!K2M<U3P9\2O&$]O\`#BQ^)OB'4M`T'3M.M--TBXGG@-RUM<:K(Z&-X&+0
> M12W$FU@4,F'V^A?%G_@L-X!^%?BK7+9/!?Q-\2^'/#7B72/!VJ>*-(L+$Z39
> M:QJ36OD6;">V,$GRO\`:3_X)(?$'XK_
> M`!UO[/PEJ-AX2^%'B'QGX=\8:ZC^-FN3J5WI;V3/>?V4=$#I<R1V20;5U9;?
> MY4F,1D&VNF+BZT8O9R_!U>O9*EKIKSM;QNE-6ZIRE#=1_%4U:WFZMT[Z<BZ/
> M5_3WQM_:=\1?!7]MWX1>#;ZWT%?AQ\4=.UBQ_M"6.5+ZSURTBCNM[]BGPU^WA\'K?P
> M?XDUCQ1X;_L_5(-8T<&?2V/GV<LR&-B
> M0R12I&XP60L`U98?24?:;*27K!OFDW_>3]V-NFY5>+DU,:U:Z;-:1
> M6RZM!=N7%R)%GV"-$.Y@\B&W;GOVA_\`@MYX6\#WGQN\$^&-!U>Q^*'PO\$:
> M_P"+-.A\1+9?8M0.F(N1+:07IU"W21I(Y(Q=06QGAS)$S(58^Q:I_P`$T?`F
> MK_!+Q5X"DU;Q:NC^+OB$?B5>3+=6XN8M1.JQ:IY4;>1M%OY\*KM96?RR1OW8
> M8>4Q?\$'?A<AUJ%_''Q6FTK5-&\5:!:Z=)?::8-'L_$4QGU!('^P^<KEE?_$Z<;?=4YO+EWUU?1&5-5N9_#SK_`,`4W>_F
> MX6\^9]$C.^*?_!8B_P!!^#DOV'P/K'A'XF6+^#[]]*\76,7V75='UO6(-/.H
> M6GV2\D(3YIPL<0NY=:O=<O?#5
> MAJ/]HZ3+;W^HV:.T\(M(3A3,,RK/<6<4$C1?)*P>(O:'_``1Q\!ZMIFHQ
> M^(O'/Q3\7ZE>0^'1L6O=+TW1-074+'3X3%:1HT/GKF229)+B4,=TQ
> M.&'<_!#_`()Z:%^SY\6)]=\->._B;:>%CK&H^(+7P(NJP0^&K&_ORS74P2*!
> M+J9&D>:18+FYF@CDF9TB5EC*=K<'5;?PWF_E>'(O)\JE?=<J_;9\<#KCP1X5/_D_XEJ3^R?8?E5KQ]!Y_P"W!X[!
> M[>!O"G_I?XEK5_LX>E?286I:DEZ?DCQJ\+S;/E7X`_M9:I^T9^T)\*[/4-.L
> M[)-,\9/,A@+$L6\-^(!@Y^E>\>,OV"O"WQ;_`&ZK(T
> MCP__`&SI,.H7^C7]I?ZA<RW$/G1,(01<V^UXWWEHCD#:I/PW^PEIEQX@_:#\
> M#6MKJE_HT\OBQ=EY9I"\\./#_B`G:)HY(^0"#N0\$XP<$?I?_P`*EU__`**A
> MXZ_\!-&_^0*$C^(>O\`@F*ZT_7]5%]$XU+2XFN!
> M-$L,226@3X@>`O$TGBOPKIWPZN=1T?QOH_BK1/#.K:[
> M?/IYM[;PK#H,MM)J!M))DFB82R0W'V>4N(TWJC2-Y?TW_P`*EU__`**AXZ_\
> M!-&_^0*/^%2Z_P#]%0\=?^`FC?\`R!7S=->SCRPTM9?<U)>NJOK?=I66A
> M%0\=?^`FC?\`R!1_PJ77_P#HJ'CK_P`!-&_^0*J+M!02T6WDNWIU\VVW=MLS
> ME%0\=?\`@)HW_P`@4?\`"I=?_P"BH>.O
> M_`31O_D"BX'<T5PW_"I=?_Z*AXZ_\!-&_P#D"C_A4NO_`/14/'7_`(":-_\`
> M(%%P.YHKAO\`A4NO_P#14/'7_@)HW_R!1_PJ77_^BH>.O_`31O\`Y`HN!W-7
> M-`_Y"T7X_P#H)KSK_A4NO_\`14/'7_@)HW_R!6U\._AWJ^A>,;.ZNO'GBO6H
> M(M^ZSO+?3$@FRC`;C#:1R<$AAM<<@9R,@S-^ZQK<]/HHHKB-PHHHH`****`"
> MBN1^*=J=4U3PE8-<W]O;7^L/%<?9+R6T>5%L;N0*7B96QO1#C/.T5+_PI_2?
> M^?OQ3_X4VI?_`!^F!U-%<M_PI_2?^?OQ3_X4VI?_`!^C_A3^D_\`/WXI_P#"
> MFU+_`./T:`=317+?\*?TG_G^*?\`PIM2_P#C
> M]&@'4T5RW_"G])_Y^_%/_A3:E_\`'Z/^%/Z3_P`_?BG_`,*;4O\`X_1H!U-%
> M<M_PI_2?^?OQ3_X4VI?_`!^C_A3^D_\`/WXI_P#"FU+_`./T:`=317+?\*?T
> MG_G^*?\`PIM2_P#C]&@'4T5RW_"G])_Y^_%/
> M_A3:E_\`'ZC@^$FE2RS*;OQ1B-]H_P"*FU+^Z#_SW]Z-`.MHKEO^%/Z3_P`_
> M?BG_`,*;4O\`X_1_PI_2?^?OQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;
> M4O\`X_1_PI_2?^?OQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_1_
> MPI_2?^?OQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_1_PI_2?^?O
> MQ3_X4VI?_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_1_PI_2?^?OQ3_X4VI?
> M_'Z-`.IHKEO^%/Z3_P`_?BG_`,*;4O\`X_5?5OA5I=AI\DJW?B<LF,9\3:EC
> MJ!_SWHT`^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`
> MZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4
> M_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^
> M*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2
> M_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"
> MG])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%
> M/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\
> M?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN
> M6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_
> M`#]^*?\`PIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`
> MPIM2_P#C]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C
> M]'_"G])_Y^_%/_A3:E_\?HT`ZFBN6_X4_I/_`#]^*?\`PIM2_P#C]'_"G])_
> MY^_%/_A3:E_\?HT`ZFBN,\$Z2OAKXHZ_IT%UJLUFFE:?<I'>:C<7GER/->J[
> M*9G<KD1H"`0/E%=G0T!\,?MP?'Z_^`'\3-
> MD8KRG_AY'XA_Z`>E?]]O_C6K_P`%9'V?M0ZQ_P!BMX7_`/2OQ-7RGYGN:_7.
> M&<IPE?+X5:L$VSX#.<?7I8N4*<K(]%_X)R-N_:>\`?\`8U_^ZN5_AK]ZTW3ZIII'M<.:Y<X][K\;
> MKEX?^!O@2-\)KV34H3XS>/_VB/V&OVH/$5QJ/@O2_`>B>&_&OAB'PZFC7,FO)<6$-U:FY
> MN+XW@AC$K1-*MN+,E8YHOWS9)/J?['7QK^(=9W-LMK;WLE[;M93F>:39N/A3?2ZAJMF\2Q/;7$[6)DEA:-50QNQ4JH4C``KJ%\/\`54N9+6%G>*`R"TW&)&EE94SM4R.0
> M!N.71:BO>UNHI^J4KOYMI^2O%:;E9J4>6*V<FO)2=/3SM&,H^;:D]=O"_P!F
> M7X0_#+]H/7/'OCCXH:1X9\4?%7P7XZU:RN=0UV.*;4/`\-O?2?V9%9NISXD?$W6O#=]J-C\(Y/C\
> MGP1K$7]GZK/KMKL^'&IK]FU"?S?.O$Q9_+<2>?/OE&';SI,D[VSGR7I*G>VB
> M6FUY>;2?FK_$WJ.4D
> M;]F;POX?@T0U^Q^TW+-='EU2]CO]
> M2E\/SR327(NOLY>T>_G\IHXCF1()`P$1$WK^M?";]G?Q)X`/A34?@AI%_P"%
> MCJDFMG1KGX07<NGF_<%7N_(:P,?GL"09=N\@G)YKI;.^^$^GZ)<:9;_#R^@T
> MVO)
> MV6VT?=UO=VG+GDGTB]M;.XC1CJES-=(DTLT;226-BNZ)6C\U'!KZXKQ'PE9
> M_!OP!\1=4\8:#\,9=$\6ZY))+J6MV'PNU"VU'4'D(,C37"60DD+$`DLQS@9Z
> M5VO_``T/H'_0/\=?^$5K/_R+6<&E3A!;$2UG*2V;T]#N:*X;_
> M`(:'T#_H'^.O_"*UG_Y%H_X:'T#_`*!_CK_PBM9_^1:=T*QW-7-`_P"0M%^/
> M_H)KSK_AH?0/^@?XZ_\`"*UG_P"1:VOAW\9=(\5^,;/3/HHHKB-PHHHH`****`.5^(;;/%
> M7@<^FMRG_P`IM]7GW[;'QB\1?!KX*1>,?#TS6\/A;6],U#7HPL3"YT87<2:B
> MI,B-MV6KRRAE*L#"/F`)!V:&5"CJ?8JQ'XT.Z2E%7:::71M.]GY.UGW5T"LWRRT3T?>S5
> MFUYKIV>QX7XJ_P""@C?!GPY\7?B9XFBEU+X>>&O%,'A31;2+5M$T=8OL\:17
> M=V]UJEU9P9>_EF@V/<9(M8S&F7;.5XQ_X*T^#?&'PPOI4]O?/%)MO9C&]V'LG18O)G0N\9.Z(2.FO!_P3P\,Z'\"OAE
> MX)T#QEX_\.S_``HOGU/1O$EM=V=WK,]S+!<P7,URUW:S0323I>7!D<PAMTA9
> M"AYJ+1/^";/@/0?AEX@\*1:QXPDT_P`2?#6W^%EU+->P27"Z9#]MVS*YA_X^
> MC]OFRKV@TWY<T^5VZ:K:S*HRCS)U--O.UZBNM=^6
> MG>SM9NUUT-S7?^"G/@GP7^U3X,^#.IV6JQ>)?'-C'<:1>R:MHLGVDM:37(,E
> ME'>'48U*V\JF8V2V_F#:).1GY]^'/_!6#Q9XF_X)FS:OJFD^.-#^)UU\&]5\
> M7Z)XRU/1E^U,3:JJF,W'E!E#*B
> MFN8\%?\`!)YI)JUXI-I/0>#J1A.#JZI<E^N
> MS]QXTOCI^GWMR-5TB!+74+
> MNU2XA@^QR7::A-O62+]Y:V<L"&8!I%V2^7F_&_\`;/\`&_P2_P""C%U:75ZM
> MQ\%M"\%:)=>(M/%E$TFCS:CJ.J6PUCS@OF^5$UI;1S(6,:0RR387RF)2_9V\,ZY\8?%'C+48Y]3N/&/A>U\(:GIMUY<NG3V,$
> MUY*`8RFXLYOIE?<Q4J%`48):YN/-&:6J<FULGCMX5CO;NS-TZVT`581NG6>7SVO8(<0PN
> MT4C9F$4;)(_!6?\`P1R\!:!\+-/\):)X_P#BSHEE:67B+2KF\AU6RNK_`%/3
> M]<NDNKZSFGN;25@OF1Q%\96$NI^)5A\<>(]!
> M\3WY2Y@#17.CKIRVR19AP(V&F6_F!@S'?)M9,KM5.,-%)NRY?7>*EW^RG*^_
> M,VG=)-
> MG/\`:8\/_M1?!'PYX^\+EI=#\2VOVBWW7$$S1D,R21F2!Y(7*2(Z%X9)(V*Y
> M1W4ACY#\2OV!?#'Q"\4>(/$5MXG\:^%_%>L^++/QI9ZYI%U:B*!
> MMDGMY86BDLT>.2.YCF5O/D.`=FSV#X>:'?>"O!=AI>I>)=9\7WUFA276-6CM
> M(KV^)8G=(MI!!`"`0OL]
> MQ^=1QW>+BZY_Y:K_`.B8J5D*[/F?XRVOQ*M/^"AGP]\,Z9\>OB?H_A+QMH^O
> M^(+K1+;2_#$D%HVGS:4L-K!+-I#W`@=;R8/YDKRGY=LB8.>U\7?\%./!G@L]]H\6@B5=1%PIG$89)XUMU".X:6:/G86=>
> MS\2_!K2?%'QU\*?$*XN=176O!VE:GI%E!'(@M98K]XN_9%\1_$GX1?M7>*;?P;JOA_QA\9?#6I:%X<\,:CJEG)/;YTUH"Y
> M>&>2U@>]NL2,%F*W?F?+ZZ.-];JVB>K7314)U8<
> MMSX/\`
> M_"9^$%9;&*_GTRY@;4]/U$VMQ$063Q<VDN4>-P89Y``X!(<,J^.Z1_P3
> M;T'Q'\-];L_&7C3XB>)O$?B+3M)LXM<O;VRBU+PLNF7'VRPCL'M;:*(&WNR9
> MA),DSRLJB9YE`6O<OA!X*U;X:>$CINM>.O%/Q"O#.\W]J^((--@NPI`Q%MT^
> MTM8-BX)!\K=\QRQXQU.$%*:>N]O2^GJN#_GG_`./?_6K%^V>X_.CL]Q^="2"8_P"Q
> M7\+_`/I7XFKY.\WV%?5__!6\X_:?U?\`J_<N#U_PET_F
> M?E_$3_VZ?R/3_P#@F\<_M/>`/^QK_P#==\0U^L=?DY_P3=X_:=\`?]C7_P"Z
> M8Z^(XT_Y&DO2/Y'U/#7^XQ]7^84445\F>^%%%%`!1110`4444`%%%%`
> M!1110`5<T#_D+1?C_P"@FJ=7-`_Y"T7X_P#H)J9_"QK<Z2BBBN$W"BBB@`HH
> MHH`XOXP7$=I?^$Y90[11:I<.X1RC$#2[\G!'(/N*KGP.[')NEB/]SSKI]OMG
> MSQG\A2_'3_5^'/\`K_NO_35?TZYU\+<R#)X8C]:8AG_"#/\`\_R_]]W7_P`D
> M4?\`"#/_`,_R_P#?=U_\D4?\)`/4U#J6NRRZ=<+;2".X:-A$QZ*^#@G\<5$Y
> MN,7)*]AQ5VD<<_Q@^'47QI7X;-\3O`R_$5XO.7PL=?QK31^7YN\6?VSSMOE@
> MOG9C:,].:[?_`(09_P#G^7_ONZ_^2*^/O^"?G9T&Q^
> M,FCQ[O$_@^\9#XGNM?0&:^OFLR!<3F6;S+D780I(CK*K>&ZTC7M2\+KJOB/KVUM
> M<_3_`,4VNF>!M)_M#6_$6F:/8&>&U^TWUY/;P^;-*D,,>][D#?)+(B*N<LSJ
> MHR2!63\7?&G@[]G_`,'MXA\>>//"W@G0$F2W;4]?U=]-LUD?.Q#+-=JFYL'`
> MSDXXK\]/VW_C_JTGB_6_A_XG^-M^-6\*^.?`>G:1X)O=+TQ+KQ=IW]I:-/)K
> MLQCMHYWD:Z:X0RVIALXS;&(PP_RK"K-QPSQ$=;-_<HQE
> M\F^:WEU5TT-*TN5_U_7W/HVM3C?@G\7?AW^TKI=]??#GXF^!_']EIDJP7EQX
> M;U_^U8K21AN5)&@O'",1R`2"17;?\(,__/\`+_WW=?\`R17PK^SE^T7J?FCX@O=WK^!/#_AJQMO&&GVUHD\DMI<67EP7,?RF3?%=_9@0KJICGF+!
> MBJ8X/]H#]M+XI?!WQCJ>@^+_`(^CX>>(K+X6V'B_2M'&A:1)/X@\27-L4%L+:'%U,(8W25'\YI.BO%0JRIK7E;7S2;T2U=TG9)-I;^"]=\3VFF7GBBSNK"&2XGM+.72
> MIKF_E%U+<Q1O;:G!&KVBH\)*N9OOW_A(!ZFEROD4^_\`P/\`,Q4O>Y?)/.S#_A!G_P"?Y?\`ONZ_^2*/^$&?)/VU<L<GYKKG@#_GX]`!^`H_X2`>IH_X
> M2`>IJ"C,,>DKXR7PX?$FE#Q"UD=2&E_;9_MAM0XC,_D_:M_E!R%WXV]W7_`,D5^;FJ?M)ZVO"T9AHFC6']O^7';>;9N6G;[);YEG\T?N(_DYE\UT?WBC;K;\7!*ZW5N=
> M7\U*VUBIP<5.72/Z1G)Z[/\`AR?HX]]W7_P`D5^<>A?MR_%SXQ_MA?$#PG\/?B)#-;_V1XD.D^'M3OM*O=3T3
> M5-)O;2*"*ZM(-)BDT^"Z/VA5%S=WDLMO.LJB!UX^J_V1_P!I#5_VJ/#OBGX@
> MV%L+>+9<W,AV^87>\::(JS,H6T0JH+/NCF?LE5B
> MK^[S6ZVNTOFVMD)JT^26FKC\U:_R\^O2YV^E?&?X;:#)=>%X/$/F:S;*$5RSV@O#,H",K9*#A@>A%;7ACQ!X8\;^+_$'A_1?&?AW5
> M]?\`"<D4.N:;9:G)<7FC/*F^);F)+HO"SI\RAP"PY&17P+X&^*O@?4?V,OA/
> M\&M%N;#_`(:$\/\`BG0KO5?#4)67Q%HVMP:I#-J^L7D*;98H)%^VS/>2!8KB
> M*Z7:SBYC63V?_@EEX7N/!?P&^*46L>+?$WBN"_\`B5XP64W]O9121[-9O8Y9
> M$^Q6T#%YL&1L;Z2:Y-4^B]Y].B=]6E4HV2?>2C;J
> MKJ;U7?W/+5M=+OZ`^&/Q4\`?&WQ!X@TGP9\2?!7BQHTQ
> M9T$=S'%=LT+9ZG_PCCW=[)-':W7_R11_P@S_\`/\O_`'W=?_)%?"7PW_:=^+D/Q6\)
> M^)=1^(VH:]H7B?XR>*_AX?"3Z-IMO80Z?:?VT]G(LZ0"Z-U&UA"A<S>6T9PT
> M6_=*U#]A?]NGQ3\7_P!IGX9:/=?&H>/6\6^#M=UKQIX671M/ME\%:S;S:8JZ
> M:##"EQ;_`&<W%Q']GNI)+CY=TCN"F,Z2=1I+JK^GNN=ON72Z3:3>H58.G.4)
> M=&UZVE*%_OB^?\(,__/\`+_WW=?\`R139?`)GB:-32)%;P1(S$F^!)Y)+W7/_DQ2?\`"#/_`,_R_P#?
> M=U_\D4?\)`/4T?\`"0#U-`!_P@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?
> M_)%'_"0#U-'_``D`]30`?\(,_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R1
> M1_PD`]31_P`)`/4T`'_"#/\`\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\
> M)`/4T?\`"0#U-`!_P@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?_)%'_"0#
> MU-'_``D`]30`?\(,_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R11_PD`]31
> M_P`)`/4T`'_"#/\`\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\)`/4T?\`
> M"0#U-`!_P@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?_)%'_"0#U-'_``D`
> M]30`?\(,_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R11_PD`]31_P`)`/4T
> M`'_"#/\`\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\)`/4T?\`"0#U-`!_
> MP@S_`//\O_?=U_\`)%'_``@S_P#/\O\`WW=?_)%'_"0#U-'_``D`]30`?\(,
> M_P#S_+_WW=?_`"11_P`(,_\`S_+_`-]W7_R11_PD`]31_P`)`/4T`'_"#/\`
> M\_R_]]W7_P`D4?\`"#/_`,_R_P#?=U_\D4?\)`/4T?\`"0#U-`!_P@S_`//\
> MO_?=U_\`)%'_``@4^V^Z&?_`"8H_P"$@'J:/^$@'J:`#X<E!\3-;6-'
> M01:/81D-*TIW+=ZDK?,W)&0<92>7^T[JO;/ACPQ_Z5^)J^1_-
> M^E?N?!W_`"*Z?S/R_B+_`'Z9ZS_P3@'_`!D[X`_UWQ#7ZQ5^4'_!.1
> M-GVS_\``Q__`(U7?4RZ)6VD()!"G!_"LJU14X2F^B;^
> MXI*[L<)_PK34OVS_\``Q__`(U7Y>?LZ?%'QS=_
> ML#>(O''@>^)O^"DFN^"_VB?"GPLT7P=I/B]M=M(M,36TU?5T33M9;1YM
> M0BM=1F72)+"VWB)-RB^ENQ'<Q2BT=6YVKQ]DG?5KI\YKKVY5!N_\`X'KVLSZ&/PSU(@C;9\_]/K__`!JO./A+^P=I?P5\57&LZ/J7
> MCN\N>^)WB'7_/-"CY48=4#`%@"`Q!^3OV;OVC?C]^TGX
> MR_8WN?B#'HL.A>(?!>J>-]:N-"^(.H:;-KDMH-,"7=U;6FFVZ2;%NR?[/,C6
> MLIG?>?W$>_V.S_X*N>)M.^"4OQ%U_P"$UCIWA3Q'\/=8^(O@AK3Q=]KO-6M+
> M"U2[%MJ,1LXUL)YH)8F7R7O$4^8K/E5\QU(^RYI-[<R;\DY+7U<9676UE[UX
> MIJE.<E3BKW:MYMNR^'J%YHUI
> M>PBSUYXG26!+HO:--Y<<L:2!89(@Y&V3S$)0S:=^R4NE_'K6/B)'-(=;UK0;
> M+P]/`VH?Z*EO:7%W/&RK]GW"0O>2AB6((5,*""3X[\4_^"G/Q)^%0\0BY^"&
> MB7K>"/A[;_$[Q*;?Q^(+$2K$1'`SM+&;E!'')/ZY^S
> M1^UCXE^+GQH\5>!O&7@;3?!FKZ-H6E^*M,?3_$)UF+4=,U"6\BA,I-M;^1=(
> M]G()(E$L8W+LFD&2!4Y1;2W3?WZQ?_I+^2;6B,92]RUXR7XR@_G&^Z.
> MV_X5IJ7]VS_\#'_^-4?\*TU+^[9_^!C_`/QJN^HJ!G`_\*TU+^VS_P#`Q_\`XU7?44`<#_PK34OK9(E^)58_:-_:4^/7A?X>:%X@T
> M_P`+66F^)/C_`*YX0OVS_\#'_^-5\S
> M_#?_`(*=?%/XN^$OA'/H'P-\-2ZY\:/#>J>*M$LKGXAM#;6%C9)IK;KV<::S
> M(\K7TBJL,4V"D!;:)93;]C^R7_P43US]I#Q]\/
> M^OB,:A?RPVKV*SP7]JMND=K+_IT3(8I[A656W&-ODK54I.7);77\.:__`*1+
> M[FMQ3BXJ;=/7M/PU_/4X'_A6FI?W;/\`\#'_`/C5'_"M-2_NV?\`X&/_
> M`/&JVS_P#`Q_\`XU1_
> MPK34OVS_P#`Q_\`XU1_
> MPK34O0KJ:;`_,+_@L9/Y'SX._Y%=/YGY?Q%
> M_OTSZ)_X)V)M_:=^'_\`V-?_`+KOB&OU:K\J/^">(_XR:^'I_P"IL_\`==\0
> MU^J]?#\:_P#(TEZ1_(^IX:_W&/J_S"BBBODSWPHHHH`****`"BBB@`HHHH`*
> M***`"KF@?\A:+\?_`$$U3JYH'_(6B_'_`-!-3/X6-;G24445PFX4444`%%%%
> M`'+?$'_D;/`W_8;E_P#3;?5U-<M\0?\`D;/`W_8;E_\`3;?5U-,04CH)$*GD
> M,,&EHJ9135GL,X&Q_9?\"Z=^S0WP>AT/9\.6T!_"YTC[9<'_`(ESPF!H/.,G
> MG<QL5W^9OYSNSS7,VWG17J67V$7
> M8L/M'V/RTWD^8R<,QKV2BJ<FY.;W?7J.3<H\LM5K^._WVU_6^
> MM^YYSXN_9,^'WCO_`(2G^U?#_P!J_P"$U\)Q^!]9_P!.N4^V:/']IV6ORR#9
> MCD%
> M%%%2`4444`<W\-/A'X>^#^B:CIOAS3_N9+FYES(S
> M$;YI9&V@A5W84*``/)6_X)?_``1W^&!'X3U*VM_"%AIFF:?:6_B;5H+.2#3)
> MS<:>+F!+D17C6\I+QO<K*Z$G#<U[]133LTUTM^%TONN[=KNPVV[WZZOSN[N_
> M>=3R?0/V(?AIX8\8G7;/1-26]7Q5+XVACDU_49K.SUB6&ZAFNH+5YS!`9
> M%O;HND2+&W*KRB2XA@25_/FW.?-DW>MT5-E:WE;Y62MZ625NR2Z()2<K\
> MVM_\V_SE)^K;ZL\Y^'_[)GP^^%O_``@G]A>'_L/_``K/0KGPUX;_`-.N9?DM_GEWN/+X8;FROP]_9.^'_PJ?P&V@:!]@/PRT.X\-^&O
> M].N9?QY?##<V?1:*OGE>]]?\[__`"4O_`GW
> M8<S[A1114B"BBB@`HHHH`****`"BBB@`HHHH`****`"BBB@`HHHH`****`"B
> MBB@`HHHH`****`"BBB@`HHHH`****`"BBB@#EM(_Y+7X@_0KJ:Y;
> M2/\`DM?B#_L":9_Z/U"NIIL#\M/^"U3;?VDM0_Z^U_\`
> M@M:,_M(:A_V+7AC_`-*O$U?$&\U^Y\'?\BNG\S\OXB_WZ9]2_P#!/'_DYGX>
> M_P#8V?\`NN^(:_5:ORI_X)X_\G,_#W_L;/\`W7?$-?JM7Q'&W_(UEZ1_(^HX
> M9_W"/J_S"BBBODCZ`****`"BBB@`HHHH`****`"BBB@`JYH'_(6B_'_T$U3J
> MYH'_`"%HOQ_]!-3/X6-;G24445PFX4444`%%%%`'+?$'_D;/`W_8;E_]-M]7
> M4URWQ!_Y&SP-_P!AN7_TVWU=33$%%%%(84444`%%%%`!1110`4444`%%%%`!
> M1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`%%
> M%%`!1110`4444`%%%%`!1110`4444`%%%%`!1110`4444`<MI'_):_$'_8$T
> MS_T?J%=37+:1_P`EK\0?]@33/_1^H5U--@?EI_P6K'_&2.H?]BUX8_\`2KQ-
> M7Q#L%?<'_!:C_DY'4?\`L6O#'_I5XFKXB\OWK]SX._Y%=/YGY?Q%_OTSZ@_X
> M)X_\G-?#W_L;#_ZCOB&OU6K\J/\`@G@<_M,_#W_L;#_ZCOB&OU7KXCC;_D:R
> M](_D?4<,?`%%%%`!1110`4444`%%%%`!1110`5<T#_`)"T
> M7X_^@FJ=7-`_Y"T7X_\`H)J9_"QK<Z2BBBN$W"BBB@`HHHH`Y;X@_P#(V>!O
> M^PW+_P"FV^KJ:Y;XEVM_]N\,W]AIEUJW]DZJUS/!;20I+Y;6=U#N'FNBG#RI
> MQNS@GTH_X6!JW_0C>*?_``(TW_Y+IV$=317+?\+`U;_H1O%/_@1IO_R71_PL
> M#5O^A&\4_P#@1IO_`,ET6&=317+?\+`U;_H1O%/_`($:;_\`)='_``L#5O\`
> MH1O%/_@1IO\`\ET6`ZFBN6_X6!JW_0C>*?\`P(TW_P"2Z/\`A8&K?]"-XI_\
> M"--_^2Z+`=317+?\+`U;_H1O%/\`X$:;_P#)='_"P-6_Z$;Q3_X$:;_\ET6`
> MZFBN6_X6!JW_`$(WBG_P(TW_`.2Z/^%@:M_T(WBG_P`"--_^2Z+`=317+?\`
> M"P-6_P"A&\4_^!&F_P#R71_PL#5O^A&\4_\`@1IO_P`ET6`ZFBN6_P"%@:M_
> MT(WBG_P(TW_Y+H_X6!JW_0C>*?\`P(TW_P"2Z+`=317+?\+`U;_H1O%/_@1I
> MO_R71_PL#5O^A&\4_P#@1IO_`,ET6`ZFBN6_X6!JW_0C>*?_``(TW_Y+H_X6
> M!JW_`$(WBG_P(TW_`.2Z+`=317+?\+`U;_H1O%/_`($:;_\`)='_``L#5O\`
> MH1O%/_@1IO\`\ET6`-(_Y+7X@_0KJ:Y'P8NI:I\0];U:\T6_T:VN
> M-.L;2%;N6W=Y7BENW<@0RR``"9.I&>>.*ZZA@?EO_P`%I5W?M(ZE_P!BUX8_
> M]*O$U?$OE^]?;G_!:`9_:2U+_L6?#'_I5XFKXG\OWK]SX._Y%=/YGY=Q%_OT
> M_D?2W_!.C9_3PQ_N$?5_F%%%%?)'T`4444`%%%%`!1110`4444`%%%%`!5S0/^0M%^/\`
> MZ":IU<T#_D+1?C_Z":F?PL:W.DHHHKA-PHHHH`****`,;QU*Y"I'&O&68D#D@#DD@`D>7:7^U]NU&1K_0IKPA>>*?!%E<6<%U=G1KQKN:WMEWSS1/
> M;7%LYC7^)T%QY@4<DQ`#)(%>;:3XO\+?\(\FGZ+]CUWQ&C+Y>F6#K-<-*"-H
> M=/O0IG[S2A`J.>VCN-4-O
> M-<Q1&XF2&$E84=]K22(-P7`!R2`"1H?#7X\>$_B_XH\8Z-X<U8:EJ7@'5$T7
> M7HA;S1"QNWMH;I8]SJJR9AN(7W1EE^?&<@@>!?\`!0_]DGQ)\</^">VC?"_0
> M=*B\5ZG9ZKX42\MI+B*%+NTL=5L);MRTS(I`@AE8KG<V,`%B`?B;QE_P2D^/
> MFJ^#/'&DZUH^LZYX2'QMAUR?1=(O/#]YJ'CGPQ;:';Z98W`AUCS=-EFBD@AF
> M>WU!5#-$8J+;TG%<L91?>__`(#-JWJX
> MI>7,MVT?L+17Y5>)O^"47Q(\/?LY_"NU\'>'?$L6M:XX^!?Q@\9>
> M)OB-HRZ4?!NDV_PL^'BB]MQ%>A8G?R3/YT$9C<K(!9(64$UJHK
> MFY6^]_E?;O>\-N\FSYJ]EK\Z?'7M/Q'X=TX'^U:2FI^'+2+^V-/\0+
> M<ZFT#V5PSR1I;,+->SJG)J:\UR/:2;
> MNJN5MQU5F81<OYBH8TV&XAX=E+;_E!P<?GM^VC_P`$WO&>B?%KQ_%\'?@O
> MX8G^&.N^$/"?A\:'I`TK3X9(H-?O[S5%M+"::"SEN(X`^#EG\1/V<+GXO>"_`4GQ"M;KPG=:KX8WQ6FJ:E:W.DD
> M6QN(-/<@*SF-/+C@,;-&JM'!&T0FY1YK;<^FU^7F4;><O=:W35[,NI!1GRIW
> M7NSNM]';Y_K1IWQT\*ZM\<-5^'%OJGF>--%T>VU^]T[[-,/)L;B::&
> M&;S2GE-NDMYAM5RPV9(`()ZVOQI?4?@1?:%<RW=_K+?"/P7X;U
> M6>UUVRGG\2-IVM7MWJ6BI+>;D=FLIHX0]W']EF)"2%HVDQ]L_P#!)?\`91U#
> M]E#X-^+;"ZT'QGX0L-?\23:EIOA_Q%J&@22Z;!Y,,1=+30;6#3-/$KQO(;>V
> M:926\UI/,ED1>B,$U*Z^U/^"R*TX._P"173^9^7\1?[],^@_^"=7_`"<U\/O^QL_]UWQ#7ZM5
> M^4O_``3J_P"3FOA]_P!C9_7^84445
> M\D?0!1110`4444`%%%%`!1110`4444`%7-`_Y"T7X_\`H)JG5S0/^0M%^/\`
> MZ":F?PL:W.DHHHKA-PHHHH`****`"BBB@`HHHH`****`"BN+U+XCZPWB75;+
> M3=(TJ:WTF=+5Y%<1_P`)%<1_PGOB;_H#>
> M%_\`P>7/_P`A4?\`">^)O^@-X7_\'ES_`/(5`';T5Q'_``GOB;_H#>%__!Y<
> M_P#R%1_PGOB;_H#>%_\`P>7/_P`A4`=O17$?\)%<1_P`)%<1_PGOB;_H#>%_\`P>7/_P`A4?\`">^)O^@-X7_\'ES_`/(5`';T5Q'_
> M``GOB;_H#>%__!Y<_P#R%1_PGOB;_H#>%_\`P>7/_P`A4`=O17$?\)%<1_P`)%<1_PGOB;_H#>%_\`P>7/_P`A4?\`">^)O^@-X7_\
> M'ES_`/(5`';T5Q'_``GOB;_H#>%__!Y<_P#R%1_PGOB;_H#>%_\`P>7/_P`A
> M4`=O17$?\)%<1
> M_P`)%<1_PGOB;_H#>%_\`P>7/_P`A
> M4?\`">^)O^@-X7_\'ES_`/(5`';T5Q'_``GOB;_H#>%__!Y<_P#R%1_PGOB;
> M_H#>%_\`P>7/_P`A4`=O17,^!_'%]XAUW4=.U'3K2QN;&""Z1.:Z:@#\Q/\`@L6,_M+:K_V+'AC_`-*O$U?&GE^]?9O_``6&
> M7=^TOJO_`&+'AC_TK\35\<>5C7_`.Z6Z^(XV_Y&LO2/Y'U/#'^
> MX1]7^84445\D?0!1110`4444`%%%%`!1110`4444`%7-`_Y"T7X_^@FJ=7-`
> M_P"0M%^/_H)J9_"QK<Z2BBBN$W"BBB@`HHHH`^<?^"KM]K=I^Q7J</AG?V4=UXATZWE,4J$$$QRNI'1@Q!!!(/D5G^VEX@T[]
> MISP)I_C37+/P]KGPZ\$^-HO'NGW.K-8:'<WMC_84MMJ4NT,J6TUO.;B*1HW:
> M&.ZD3;O61*^R/BI\)?#_`,;/"(T'Q/I_]IZ4+ZRU(0>?)#_I%G=17=L^Z-E;
> MY)X(GQG#;<,"I(/$_%G]ACX3_'+XGWOC/Q5X+T_5O%&I>%;OP3=Z@TTT4ESH
> M]RX>6T<1NJL-ZAE<C?&2VQEW',PYHWMU<W]]/EC]TKW75-/5Q2-H2A
> MZ;5U]VJWU5E92;/GCX??\%;_`!;\0O">FP6OP7=/'&J?$2+X?1:3=ZOJ6CV0
> M>;1)=6BOC)JFDV=ZL`6/9(&L58*'>(7&$23HOA)_P4P\7>+_`!;X+7Q3\*-,
> M\+>%_%/BS5_A]=:C;^+SJ5WI^O:9'J#W"K;"SC66P<Z;<+'<^<DS$H7MHP<C
> MUOX>?L"_"SX87=A=:9H>KW%_IWB)/%D=_JOB75-6OI=42P?3EN9;B^U_:;KF3YM
> M_P!NNOW;9C7S?E0;5VZ2MKR^7Y03_'G?JX]-%CHX)/XK?C^\?GI_#7HI=;-_
> M/?[(/_!47QI^V-LO/#_P)\2V^A:K_9NI:1J%V=5TV&72;F0TNUM&
> MN(K:5;E8+"YODF5)%6;A&D^RJ\+\&?\`!-WX1?#]$M]*T;Q-!I%OJ5KJ]GHD
> MGC/6I]#TJYMKU+Z!K/3I+MK2T5+A%8);Q1IM!3;L)4^Z4VX\B26MW]VENWGT
> M\[NZ45*?+J^UE:WXP\8)$
> MK2O'K2,RH-Q4'3K'!('3.#^1K0_LJZ_Y]KC_`+]FH&5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^U
> MQ_WE77_/M<?]^S0!7HJQ_95U_P`^UQ_WE77_`#E77_/M<?]^S0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`
> M5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ_95U_P`^UQ_WE77_`#E77_/M<?]^S0!7HJQ_95U_S[7'_`'E7
> M7_/M<?\`?LT`5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ_95U_P`^UQ_W
> ME77_`#E77_/M<?]^S0!7HJQ_95U_S
> M[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^UQ_WE77_/M<?]^S0!7HJQ
> M_95U_P`^UQ_WE77_`#E77_/M<?]^S
> M0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^UQ_WE77_/
> MM<?]^S0!7HJQ_95U_P`^UQ_WE77_`#E77_/M<?]^S0!7HJQ_95U_S[7'_`'E77_/M<?\`?LT`5Z*L?V5=?\^U
> MQ_WE77_/M<?]^S0`SP%_R4W6?^P)IW_I3J-=O7$>!?D^*6N1GB2+1=.5
> MU/5#]HU`X(`'YD?\%@O^3F=6_Z^Q/\`@L`,
> M_M,ZM_V+'AC_`-*_$U?'M?NG!W_(KI_,_+^(O]^F>V_\$ZQC]ISX??\`8U_^
> MZ6Z_*?_`()X+M_:<^'P_P"IL_\`==\0U^K%?$<;?\C67I'\CZCAC_<(
> M^K_,****^2/H`HHHH`****`"BBB@`HHHH`****`"KF@?\A:+\?\`T$U3JYH'
> M_(6B_'_T$U,_A8UN=)1117";A1110`4444`%%<M\8?C#I'P-\&/KVMVGBB\L
> M4F2$QZ!X:U+Q#>;FS@_9=/@GG*\<OLVKW(S7/_LQ?M9>"_VPO`8\3^`Y?$]Y
> MH$BQO;WNK>%-5T&*^CD7>DMO]OMH#<1%?^6D0=.V<T1]Z_+K;?R]0>EK]3TF
> MBBB@`HHHH`P]=^&7AOQ1J#7>I^'M#U&4V_M._#IOX>^_BP_\`J.^(:_4^OA^-7_PJ
> M2](_D?4\-?JY+XC_!#PY\6M?\`#>H^(+;4+Z3PG?#4M/ME
> MU2:N+=_&-WJ.ML+BX>S#K!!YRK&@O"NGB&-$F#+#"$Z]<
> M^-O&_P`3/#^EV,^E#P_9>&O`WBK6-&UG3FTR)+V);S3%>3>GG9\KO=.-HM-*X2G>3:VLEYOW8)WMTO%M
> M6M9R<KW=EQ/T_Y"/_3Y_P`]O^FF^NVH
> MHK2K/GFY]W<PI0Y(*'96"BBBLS0****`"BBB@`HHHH`****`"BBB@`HHHH`*
> M***`"BBB@`HHHH`****`"BBB@`HHHH`****`"BBB@`HHHH`****`"BBB@`HH
> MHH`****`"BBB@`HHHH`****`"BBB@`HHHH`_,*_$
> MU?(E?7O_``5S&?VG-7]?^$7\+_\`I7XFKY&K]TX._P"173^9^7<1?[]/Y'N'
> M[!"[?VF/AV?7Q:?_`%'/$-?J17Y<_L%C'[2WPZ_1J^%XR_P"1
> MG+T7Y'U?#?\`N*]7^84445\J>\%%%%`!1110`4444`%%%%`!1110`5<T#_D+
> M1?C_`.@FJ=7-`_Y"T7X_^@FIG\+&MSI****X3<****`"BBB@#`^('C*?PA:Z
> M>MGIXU*^U2\%G;PM.((PWER2LSOAMJJD3GA2>`,<UE_\)IXJ_P"@'X9_\'MQ
> M_P#(=2_%#_D->#_^PO+_`.FZ]KS'6/''CCQKXW\26/@U_#%A8>$72TG?5N/_`)#H_P"$T\5?]`/PS_X/;C_Y#KRZS_;/\#P>%])O]6O;S3+G4=&M
> M];GM8]/N;W^SN7U-
> MY(X6:+3N/_D.N5^(?Q]\*_"O5TL=;U"Y
> M@N3;_;)1;Z=<WBV5ONV^?<-#&ZV\60WL.S]YM6-49F4"4.49<J/O.R\_PW_'3^F#
> M5MSTG_A-/%7_`$`_#/\`X/;C_P"0Z/\`A-/%7_0#\,_^#VX_^0ZGHH"Q!_PF
> MGBK_`*`?AG_P>W'_`,AU>\#^.+WQ%K6IZ;J6F1:=>Z='!.#!=_:8+B*7S`K*
> MQ1&!#12`@J,8'7-<)I/L+S69(YVB;E&94MG52RD'&XXS5S_A-/%7_`$`_#/\`X/;C_P"0Z\G\
> M:?%'4?A;\#O`$]G<:5I%MJ-M8VEC^U-9>'/'.J>&_$J2B3PHC)V9;K:#>&^T_P`^:U\T
> MPR1$212-'(I5U5@5=6'3M6Y0P^9!_P`)IXJ_Z`?AG_P>W'_R'1_PFGBK_H!^
> M&?\`P>W'_P`AU/10%B#_`(33Q5_T`_#/_@]N/_D.C_A-/%7_`$`_#/\`X/;C
> M_P"0ZGHH"Q!_PFGBK_H!^&?_``>W'_R'1_PFGBK_`*`?AG_P>W'_`,AU/10%
> MB#_A-/%7_0#\,_\`@]N/_D.C_A-/%7_0#\,_^#VX_P#D.IZ*`L0?\)IXJ_Z`
> M?AG_`,'MQ_\`(='_``FGBK_H!^&?_!N/_D.IZ*`L0?\)IXJ_P"@'X9_\'MQ_P#(='_"
> M:>*O^@'X9_\`!N/\`Y#H_X33Q5_T`_#/_
> M`(/;C_Y#J>B@+$'_``FGBK_H!^&?_!%`6(/\`A-/%7_0#\,_^#VX_^0Z/^$T\5?\`0#\,_P#@]N/_`)#J>B@+$'_"
> M:>*O^@'X9_\`!%`6(/^$T\5?]`/PS
> M_P"#VX_^0Z/^$T\5?]`/PS_X/;C_`.0ZGHH"Q!_PFGBK_H!^&?\`P>W'_P`A
> MT?\`":>*O^@'X9_\'MQ_\AU/10%B#_A-/%7_`$`_#/\`X/;C_P"0Z/\`A-/%
> M7_0#\,_^#VX_^0ZGHH"Q!_PFGBK_`*`?AG_P>W'_`,AT?\)IXJ_Z`?AG_P`'
> MMQ_\AU/10%B#_A-/%7_0#\,_^#VX_P#D.C_A-/%7_0#\,_\`@]N/_D.IZ*`L
> M0?\`":>*O^@'X9_\'MQ_\AT?\)IXJ_Z`?AG_`,'MQ_\`(=3T4!8@_P"$T\5?
> M]`/PS_X/;C_Y#H_X33Q5_P!`/PS_`.#VX_\`D.IZXO2?V@_"6N>)X]%M=1N9
> M-5DF,`M3IURLBN,TZ.
> M"<&"<_P"P-IW_`*4:A79T
> M,$?FA_P5Q&?VG-8_J^N/^"N'_)SNL?\`8K^%_P#TK\35
> M\DU^Y\'?\BNG\S\PXB_WZ1KSOQ)\&_$$'B2\(^*K
> M3PY%XI$;:M%<:1]N<3)&(1<VK>=&L4QB5%)D69"8HSLX8/ZSXV\$P>.+&UBE
> MNKZPGL+E;NVN;214E@D567(W!E(*NZD,I!#'BLK_`(5?>_\`0X>(_P#P&TP3:/)K[]E"R30?$&EZ=JLMG8ZQX*A\&0++!Y\EJD8N0+AFWCS&/VC
> ME<+DH3N^;BG8?LB6NB?&U_&%M_PAEZUU-:7-P=7\+)>ZE;2P0I"3:7@F1H`R
> MQH0K))M?<P^]BO9?^%7WO_0X>(__``&T#AXC_P#`;3O_`)%J
> MDVI<RW_X+?YL3U5G_6B7Y)?TV>:?$_X"ZIXQ\7ZKJ>B^)+?0XO$VCQZ%K44^
> ME_;7EMT:8J]N_FH(9@+B8;G65.4.SY3NW_AK\)XOAMXA\3WEO=F:#Q#=6UQ'
> M`8]IM%ALX+4)NW'?D0;LX'WL8.,GK/\`A5]NO^=_SV[=`;N_Z'#Q'_X#
> M:=_\BT?\*OO?^AP\1_\`@-IW_P`BTPN4+;PCIEGXGN=:BL;:/5;R%()KH)B2
> M1%Z`G\LGJ0J@Y"KBUX+_`.2IZY_V!M._]*-0J7_A5]#\+WNC:=XGABL-6\'/X4OA/I7F/DFZ=)X=DR+$JO=/^Z*L-B(H9<;J]
> MKTKX+GP_I\=EI_BCQ):6-N"MO;[;.9;=,\(K2V_P"A
> MP\1_^`VG?_(M#BM?/_)K\F_SW",FK6Z6_!I_FD>6>.OV9/\`A--;N;S^V_LW
> MVBQT6RV?8]^W^SM0:\W9WC_6;MF/X<9RW2L?XM?"E_!>L:GXQM==O#AXC_P#`;3O_`)%IN_1];_>TW]#AXC_\``;3O_D6@+CJ*;_PJ^]_Z'#Q'
> M_P"`VG?_`"+1_P`*OO?^AP\1_P#@-IW_`,BT!<=13?\`A5]_Z'#Q'_X#:=_\BT?\*OO?
> M^AP\1_\`@-IW_P`BT!<=13?^%7WO_0X>(_\`P&T[_T.'B/_P`!M._^1:/^%7WO_0X>(_\`P&T_Z'#Q'_`.`VG?\`R+1_PJ^]_P"AP\1_^`VG?_(M`7'44W_A5][_T.'B/_`,!M._\`D6C_`(5?>_\`0X>(_P#P&T_P"AP\1_^`VG?_(M'_"K#AX
> MC_\``;3O_D6C_A5]`3^63U(50<A5Q?_`.%7WO\`T.'B/_P&T#AXC_\``;3O_D6@
> M+D7@O_DJ>N?]@;3O_2C4*P2,-L1
> M5C1$507<\+R6.2:WZ&"/S2_X*W#/BOX7_]*_$U?)%?7'_!6W_DYSX._P"173^9^7\1?[]/Y'M71SQ#7ZC5\+QE_P`C.7HOR/J^&_\`<5ZO\PHH
> MHKY4]X****`"BBB@`HHHH`****`"BBB@`JYH'_(6B_'_`-!-4ZN:!_R%HOQ_
> M]!-3/X6-;G24445PFX4444`%%%%`&/XS\=6'@*RMI[_CO@(@+?=1CG':L(?'O16/%EXH/_<`O/_C=.^+D)GU3P<@ZG6G_`/2"\K1L
> MM&6-03R:`#0OB?IGB/35N^`/`T'A7]GOX`S>$=*\.Z/K.L:Q:33W!L@D<\QTJ]!FG$6UIF4$G!92V-
> MN],[@1U;7G%?^!.WZ#:T;[)O\C_&C_`(3*U_YYW'_?
> M(_QKY4TWXW^*/$.J:4(/#OAC5O&D%CXGLHY88L)M/UOQ/HK_`-=UW06=[=;V^?;\_6S/<O\`A,K7_GG<?]\C
> M_&C_`(3*U_YYW'_?(_QKYJ\2?M)ZKKFAS:CX1DL+NVU:_BT_PT!I1O)=69+=
> MI]^TEXF\?_#C4/-'>*;<8F">1N@4G(<E=RY.X.K=U>_3_)O\DPBN9I+K_FH_FSZ]_X3
> M*U_YYW'_`'R/\:/^$RM?^>=Q_P!\C_&OF2;]HS6XOC3H&B6%K877A>]O(]%O
> M9%T]8/L-X=/>Z\M)C=[Y"%$9VK:;`KD>;N4BO+/"_P`0?$.G_L9VFA7TOAZ\
> MT;7OAIJMQ9QV44HN[#[+;(A::0N4D5_-P<)'Y;X3,GWJ):*3[?Y-_DKKNF%)
> M<OQ=OP=T_-'W=_PF5K_SSN/^^1_C1_PF5K_SSN/^^1_C7S'X/^.'C?Q!
> M\97\/:-X<BNO#'AN:QT_4YREOYJB6TBF,YD:\22,*)1A%M)0XC;$@+$)UWCC
> MXB>(?#/QETO3;C1O'\W=;^='.HM"`L95I861]Q`8-
> MA:*ON*_W?I]^EO6V^AG"7-'F\K_UZ=>V^Q[=_P`)E:_\\[C_`+Y'^-'_``F5
> MK_SSN/\`OD?XU\6?!/XYC<>WUGX^>,O`,-_:ZK-X1UR]@BT6]CN]-LY;61)(VGD.0F]TD\P!L'*`*=UN'O\B6+EHKO^MOUDE_3/IS_A
> M,K7_`)YW'_?(_P`:/^$RM?\`GG<?]\C_`!KY9^(7Q,N?%?QITC3Y4M7MO"7Q
> M!@LK8VX)DD5M`GN&#Y8@N'E8<`<`#&<DU/AEX_USXE_'SX9ZYK%WX:EAUWPK
> MJNIV-KIB2++812R6!$4K/(PE*X`\Q5C!97&P8J*?OVMU_P#D>9?>K_=Z!/W7
> M;RO^+7YK\3ZQ_P"$RM?^>=Q_WR/\:/\`A,K7_GG<?]\C_&ODJX^(/B'X=?&3
> MXH:EIDOAY]*M_%&C6]>_:;2P@"PLCJL3#=E=R2>8<KB/;N/4?!SX
> MX>-_BA\5M41O#D47@JSU+4-)^U!+<26LEK(T8=Y/MC2N79#^\C_&C_A,K7_GG<?]\C_&
> MOG'XD_M`>(OA3XG\73:O:V<.DZ5I=WJ&A6`TV5I=<6WMEE=_MRS-%$0^\&)X
> M%?:-REP":S/#_P`=OB0_A_2+?6=&TC2-2\5ZM;V&D:M=VL2V"1R6TL[.T%OJ
> M%R9#^YV)_I$7F-,G"?RZZA+3?S_``5V_1?CTN?4/_"96O\`
> MSSN/^^1_C1_PF5K_`,\[C_OD?XU\`NC/7;.X_9L\!6
> M"W=HVH1>'+.YDMDF5I4B=2JR%>NQBC@,1@E3Z&FE=-KR_'F_^1?F3?\`K^O5
> M?>>]?\)E:_\`/.X_[Y'^-'_"96O_`#SN/^^1_C7,T4AG3?\`"96O_/.X_P"^
> M1_C1_P`)E:_\\[C_`+Y'^-<S10!TW_"96O\`SSN/^^1_C1_PF5K_`,\[C_OD
> M?XUS-%`'3?\`"96O_/.X_P"^1_C1_P`)E:_\\[C_`+Y'^-<S10!TW_"96O\`
> MSSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'3?\`"96O_/.X_P"^1_C1_P`)E:_\
> M\[C_`+Y'^-<S10!TW_"96O\`SSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'3?\`
> M"96O_/.X_P"^1_C1_P`)E:_\\[C_`+Y'^-<S10!TW_"96O\`SSN/^^1_C1_P
> MF5K_`,\[C_OD?XUS-%`'3?\`"96O_/.X_P"^1_C1_P`)E:_\\[C_`+Y'^-<S
> M10!TW_"96O\`SSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'3?\`"96O_/.X_P"^
> MSSN/^^1_C1_PF5K_`,\[C_OD?XUS-%`'8Z7K,6K^9Y:R+Y>,[@!US?\`_\`9JWJ`/S3_P""MO\`R<]K'_8K^%__`$K\35\EU]:?\%;?^3GM
> M8__<Z;=:;=_:X9
> MX!&65O*DB(Q(CJ05E;^&L0?#;Q*/^9TUC_OS8_\`R+7=44`<7X=^%]QX=TLV
> MPN_M9>::XDFG(WRO+*TKDGS0]3MI8;G0/#5Q#.MRDJ2V,;K(+
> MA@]P&!3!$K`,^?OD`MDU=\*_!ZS\"Z%#I>AZ?H^C:9;;O*L"O/#?A:ZT.TE\Z#3IM/B>TADRQWK
> M$4V*V68Y`SECZU8B^`^D06,ULFB^'DMKBR&F2Q+9H$EM1NQ;LNS!B&]\(?E^
> M=N.37?T4`>=#]G3P^/%JZ_\`\([X8_MU%5%U+K"JNQ0)=F_`7Y1SP..E
> M5]#_`&7_``KX8AU&/3?"GA#3X]7M_LE^MMID,0O8=NWRI0L8WIM)&ULC!Q7I
> MM%`?U]VQYQJG37H
> M-%']?>%CAK'X+:?I:V"VVEZ);KI=N]I9"*V5!:0OMW11X7Y$;8F57`.U>.!6
> M=HG$TG;0+?QP_B>/P]X83Q+("'U9;",7S#;LP9MF\_+\O7IQTKT6BDM-@>N
> MYY\06V@^&DZ4.4,L8CVN5/(W`X/2O4Z*+:6"
> M^MSRX0\&7EMHT+6^GPSZ5#)'8QMPR1*8R(U.!D+@'%:\W
> MP4TZXL=2M9-+T.2VUE=FH0M;*8JR8XW`9]ZV]#^#-CX
> M8=&TW3=%T]HK:.R0VUNL12",L4A&U1B-2'_"C_`(0VZ_YZ6_\`WT?\*Z6BD,YK_A#;K_GI;_\`?1_PH_X0
> MVZ_YZ6__`'T?\*Z6B@#FO^$-NO\`GI;_`/?1_P`*/^$-NO\`GI;_`/?1_P`*
> MZ6B@#FO^$-NO^>EO_P!]'_"C_A#;K_GI;_\`?1_PKI:*`.:_X0VZ_P">EO\`
> M]]'_``H_X0VZ_P">EO\`]]'_``KI:*`.:_X0VZ_YZ6__`'T?\*/^$-NO^>EO
> M_P!]'_"NEHH`YK_A#;K_`)Z6_P#WT?\`"C_A#;K_`)Z6_P#WT?\`"NEHH`YK
> M_A#;K_GI;_\`?1_PH_X0VZ_YZ6__`'T?\*Z6B@#FO^$-NO\`GI;_`/?1_P`*
> M/^$-NO\`GI;_`/?1_P`*Z6B@#FO^$-NO^>EO_P!]'_"C_A#;K_GI;_\`?1_P
> MKI:*`.:_X0VZ_P">EO\`]]'_``H_X0VZ_P">EO\`]]'_``KI:*`.:_X0VZ_Y
> MZ6__`'T?\*/^$-NO^>EO_P!]'_"NEHH`YK_A#;K_`)Z6_P#WT?\`"C_A#;K_
> M`)Z6_P#WT?\`"NEHH`YK_A#;K_GI;_\`?1_PH_X0VZ_YZ6__`'T?\*Z6B@#F
> MO^$-NO\`GI;_`/?1_P`*/^$-NO\`GI;_`/?1_P`*Z6B@#,\.Z-+I'G>8T;>9
> MMQM)/3/MK'_8
> MK^%__2OQ-7R77H
Re: Call drops when it gets to DB query module [message #694733 is a reply to message #694527] Sat, 09 July 2011 13:46 Go to previous messageGo to next message
Member
Hi Randy!
Unfortunately it didn't work. Again there is an error message:
INFO|2011/07/09|15:44:22|p=Interact_With_Caller|s=B83276D3724C4006D5552D90A397C098|e=0002> Action "Begin" Starting
INFO|2011/07/09|15:44:22|p=Interact_With_Caller|s=B83276D3724C4006D5552D90A397C098|e=0002> Performing variable assignments
INFO|2011/07/09|15:44:22|p=Interact_With_Caller|s=B83276D3724C4006D5552D90A397C098|e=0002> Assigning variable "Card_Type"
INFO|2011/07/09|15:44:22|p=Interact_With_Caller|s=B83276D3724C4006D5552D90A397C098|e=0002> Variable assignments complete
INFO|2011/07/09|15:44:22|p=Interact_With_Caller|s=B83276D3724C4006D5552D90A397C098|e=0002> Action "Begin" Ended
INFO|2011/07/09|15:44:22|p=Interact_With_Caller|s=B83276D3724C4006D5552D90A397C098|e=0002> Action "Database Query" Starting
ERROR|2011/07/09|15:44:22|p=Interact_With_Caller> com.microsoft.sqlserver.jdbc.SQLServerDriver
ERROR|2011/07/09|15:44:22|p=Interact_With_Caller> java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SQLServerDriver
ERROR|2011/07/09|15:44:22|p=Interact_With_Caller> at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
I have no idea anymore Sad( I've try almost anything ...but with no success Sad
ANy ideas?
Re: Call drops when it gets to DB query module [message #695042 is a reply to message #694733] Sun, 10 July 2011 20:37 Go to previous messageGo to next message
Sergej, do you still have both .jars in the dependency folder? They
shouldn't both be there, just one or the other. Also, which version of
Java are you running?
Randy
In <iv9li2$lru$1@news.eclipse.org> Sergej wrote:
> Hi Randy!
> Starting INFO|2011/07/09|15:44:22|p=Interact_With_
> assignments INFO|2011/07/09|15:44:22|p=Interact_With_
> "Card_Type" INFO|2011/07/09|15:44:22|p=Interact_With_
> complete INFO|2011/07/09|15:44:22|p=Interact_With_
> Query" Starting ERROR|2011/07/09|15:44:22|p=Interact_With_Caller> com.
> microsoft.sqlserver.jdbc.SQLServerDriver ERROR|2011/07/09|15:44:
> I have no idea anymore :(( I've try almost anything ...but with no
> success :( ANy ideas?
Re: Call drops when it gets to DB query module [message #695043 is a reply to message #694733] Sun, 10 July 2011 20:37 Go to previous messageGo to next message
Randy
> Hi Randy!
Re: Call drops when it gets to DB query module [message #695125 is a reply to message #695042] Mon, 11 July 2011 04:37 Go to previous messageGo to next message
Member
Hi Randy!
I have Java 1.6. I know i should use sqljdbc4.jar for java 6.
I will try to remove other jar file from Dependencies folder ...
Will test it and reply as soon as i am back to work ...
Thanks!
Brgds,
Sergej
Re: Call drops when it gets to DB query module [message #695141 is a reply to message #695042] Mon, 11 July 2011 05:36 Go to previous messageGo to next message
Member
Hi Randy!
Unfortunately i get the same error message even if i remove sqljdbc.jar from Dependencies folder Sad
ERROR|2011/07/11|07:31:20|p=Interact_With_Caller> java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SQLServerDriver
I have CLASSPATH variable set to: CLASSPATH=.;C:\java\MS_Jdbc\sqljdbc_3.0\enu\sqljdbc4.jar
Attached is picture of java and tomcat environment.
Re: Call drops when it gets to DB query module [message #695393 is a reply to message #695141] Mon, 11 July 2011 16:09 Go to previous messageGo to next message
Hi Sergej--
It sounds like you're just not using the expected class name for that
jar. I'd suggest prepping a digital operating room and then opening the
jar up to see what the class name actually is. If you're not sure how
to do this, send me the jar and I'll take a look.
Regarding the classpath, Eclipse pretty much disregards whatever the
local variable is set to. But that's OK, as long as you've got the
right jar in the dependency folder, as Eclipse will find it.
Randy
In <ive1in$ndg$1@news.eclipse.org> Sergej wrote:
> Hi Randy!
> jar from Dependencies folder :(
Re: Call drops when it gets to DB query module [message #695402 is a reply to message #695393] Mon, 11 July 2011 16:52 Go to previous messageGo to next message
Member
Hi Randy!
Doesn't understand what did you mean by "prepping a digital operating room".
But i've unzipped sqljdbc4.jar and there is a right path to:
Here you have attached sqljdbc4.jar file.
Any other thoughts?
Brgds,
S.
  • Attachment: sqljdbc4.jar
    (Size: 524.71KB, Downloaded 299 times)
[Updated on: Mon, 11 July 2011 16:53]
Report message to a moderator
Re: Call drops when it gets to DB query module [message #695519 is a reply to message #695402] Mon, 11 July 2011 22:40 Go to previous messageGo to next message
Hi Sergej. Sorry, that was just me being linguistically playful. Turns
out, you've found a bug in the 4.0 codestream. We've implemented a fix;
I just tested it, and it seems to work fine now.
The fix is now in the build system; you should be able to get it via VTP
update site sometime tomorrow (I'm not sure of the exact timing for this,
but rest assured, it's on its way).
My apologies for the inconvenience; thanks for helping us work through
this.
Randy
In <ivf96u$3vj$1@news.eclipse.org> Sergej wrote:
> Hi Randy!
> Doesn't understand what did you mean be "prepping a digital operating
> room". But i've unzipped sqljdbc4.jar and there is a right path to:
Re: Call drops when it gets to DB query module [message #695604 is a reply to message #695519] Tue, 12 July 2011 06:13 Go to previous messageGo to next message
Member
Hi Randy!
I have downloaded new updates from:
http://download.eclipse.org/technology/vtp/helios
But it seems that didn't resolve the problem Sad
I am still getting an error message like before Sad
INFO|2011/07/12|08:06:57|p=Interact_With_Caller|s=ACF337C78F664B9FCCACE0BD6C97CD30|e=0002> Action "Database Query" Starting
ERROR|2011/07/12|08:06:57|p=Interact_With_Caller> com.microsoft.sqlserver.jdbc.SQLServerDriver
ERROR|2011/07/12|08:06:57|p=Interact_With_Caller> java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SQLServerDriver
How can i check exactly which version of VTP updates are installed? Just to confirm that updates are on my machine.
Brgds,
S.
Re: Call drops when it gets to DB query module [message #695650 is a reply to message #695604] Tue, 12 July 2011 08:47 Go to previous messageGo to next message
Member
Hi there Randy!
I have manage to see what version i am running:
4.0.0.201107080518
So i guess in that version SQL issue that we are occurring hasn't been resolved yet?
Brgds,
S.
Re: Call drops when it gets to DB query module [message #695688 is a reply to message #695650] Tue, 12 July 2011 10:27 Go to previous messageGo to next message
Member
Hi Randy!
After upgrading to 4.0.0.201107110518 DB query module is successfully connected to database ... at last Smile))
Btw: Yesterday i managed to successfully get connected over JNDI connection! (At least there was no bug in this connection) Smile
Re: Call drops when it gets to DB query module [message #695708 is a reply to message #695688] Tue, 12 July 2011 11:36 Go to previous messageGo to next message
Member
Now i have a different problem Smile
INFO|2011/07/12|13:28:40|p=Interact_With_Caller|s=6EC78B6265B2CE48FAD39765DFEFD74A|e=0002> Executing SQL statement: select * from IVR_REPORT_CREDIT_CARD_INFO.dbt where ACTION = ?
INFO|2011/07/12|13:28:40|p=Interact_With_Caller|s=6EC78B6265B2CE48FAD39765DFEFD74A|e=0002> Using parameter: SUCCESS
INFO|2011/07/12|13:28:40|p=Interact_With_Caller|s=6EC78B6265B2CE48FAD39765DFEFD74A|e=0002> Action "Database Query" Ended
ERROR|2011/07/12|13:28:40|p=Interact_With_Caller|s=6EC78B6265B2CE48FAD39765DFEFD74A|e=0002> Invalid object name 'IVR_REPORT_CREDIT_CARD_INFO.dbt'.
ERROR|2011/07/12|13:28:40|p=Interact_With_Caller|s=6EC78B6265B2CE48FAD39765DFEFD74A|e=0002> com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'IVR_REPORT_CREDIT_CARD_INFO.dbt'.
What can be wrong here? Please look at attached pics.
  • Attachment: pics.zip
    (Size: 165.66KB, Downloaded 263 times)
Re: Call drops when it gets to DB query module [message #696341 is a reply to message #695708] Wed, 13 July 2011 18:07 Go to previous messageGo to next message
Sergej, can you please post the entire stack trace?
Randy
In <ivhb2e$512$1@news.eclipse.org> Sergej wrote:
> Now i have a different problem :)
> = ? INFO|2011/07/12|13:28:40|p=Interact_With_
> SUCCESS INFO|2011/07/12|13:28:40|p=Interact_With_
> Query" Ended ERROR|2011/07/12|13:28:40|p=Interact_With_
> 'IVR_REPORT_CREDIT_CARD_INFO.dbt'. ERROR|2011/07/12|13:28:
Re: Call drops when it gets to DB query module [message #696500 is a reply to message #696341] Thu, 14 July 2011 06:17 Go to previous messageGo to next message
Member
Here it is the stack trace!
Hope it helps!
Re: Call drops when it gets to DB query module [message #696512 is a reply to message #696341] Thu, 14 July 2011 06:54 Go to previous messageGo to next message
Member
Here is also pic from MS SQL 2005 DB.
Hope it helps.
Brgds,
S.
Re: Call drops when it gets to DB query module [message #698039 is a reply to message #696500] Mon, 18 July 2011 16:04 Go to previous messageGo to next message
Sergej, this issue has been fixed; the update will be available from the
VTP update site on Tuesday (7/18/11). Once you see the update come down,
you'll need to delete your existing database block and rebuild it. I'm
sorry for the inconvenience, but this should fix the issue.
Good luck,
Randy
Re: Call drops when it gets to DB query module [message #699237 is a reply to message #698039] Thu, 21 July 2011 07:04 Go to previous messageGo to next message
Member
Hi Randy!
Thanks for the reply ...
But again after i have updated VTP and rebuild DB block (remove and add new one) errors are still the same .... nothing changed Sad
Am i missing something?
Brgds,
S.
Re: Call drops when it gets to DB query module [message #699464 is a reply to message #699237] Thu, 21 July 2011 15:02 Go to previous message
Hi Sergej--
After talking this over with the guy who fixed the error, there is one
more step that I didn't communicate to you (sorry about that). There's
a field in the OpenVXML database table file (which appears in OpenVXML
under the databases folder -- yours is IVR_REPORT_CREDIT_CARD_INFO.dbt)
which contains an invalid value as a result of the error (now fixed).
You can easily correct this manually or, if you'd prefer, delete the
table and the recreate it. However, fixing it by hand is pretty simple.
Right-click the .dbt file and open it with the XML editor. Towards the
top of the file, you'll see a name attribute with
simply remove the extension so that it reads
and then save the file.
Good luck, and please let me know how this works out for you.
Randy
In <j08ie9$ba6$1@news.eclipse.org> Sergej wrote:
> Hi Randy!
> add new one) errors are still the same .... nothing changed :(
> Brgds,
> S.
Previous Topic:Instructions for installing OpenVXML 4.0
Next Topic:WAV files played in a slow motion
Current Time: Mon May 28 05:10:22 GMT 2018
Powered by FUDForum. Page generated in 0.03294 seconds
