| Unable to create OSGi Bundle faceted project [message #685747] |
Sun, 19 June 2011 04:05  |
Sahoo Missing name Messages: 26 Registered: July 2009 |
Junior Member |
I am using
"Eclipse Java EE IDE for Web Developers.
Version: Helios Service Release 1
Build id: 20100917-0705"
I installed libra plugin from p2 indigo repo. The complete list of featuresis given below:
Copyright Wizard 1.3.0 com.wdev91.eclipse.copyright.feature.feature.group
Eclipse IDE for Java EE Developers 1.3.1.20100916-1202 epp.package.jee
Maven Integration for Eclipse (Required) 0.12.1.20110112-1712 org.maven.ide.eclipse.feature.feature.group
Maven Integration for WTP (Optional) 0.11.1.20101108-1810 org.maven.ide.eclipse.wtp.feature.feature.group
OSGi Bundle Facet (Incubation) 0.1.0.201105161144 org.eclipse.libra.facet.feature.feature.group
Project configurators for commonly used maven plugins (temporary) 0.12.0.20101103-1500 org.maven.ide.eclipse.temporary.mojos.feature.feature.group
Tycho Project Configurators 0.4.3.20101103-1630 org.sonatype.tycho.m2e.feature.feature.group
WAR Products (Incubation) 0.1.0.201105161144 org.eclipse.libra.warproducts.feature.feature.group
I can't get the libra plugin to work at all. I tried two things:
a) Created a Dynamic Web Project and tried to convert it to a OSGi bundle faceted one by right clicking and using confgure menu, but nothing happened. I saw the following exception in log file:
!ENTRY org.eclipse.ui 4 0 2011-06-19 13:32:07.193
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/libra/facet/OSGiBundleFacetUtils
at org.eclipse.libra.facet.ui.popup.actions.ConvertProjectsToBundlesAction.getUnconvertedProjects(ConvertProjectsToBundlesAction.java:105)
at org.eclipse.libra.facet.ui.popup.actions.ConvertProjectsToBundlesAction.run(ConvertProjectsToBundlesAction.java:60)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Then I tried to add "OSGi bundle facet," using project properties menu, but got an NPE. Here is what I see in log file for this operation:
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2011-06-19 13:32:28.173
!MESSAGE Failed to load class "org.eclipse.libra.facet.OSGiBundleFacetInstallConfigFactory" from plugin "org.eclipse.libra.facet".
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.libra.facet (769).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:121)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1197)
at org.eclipse.wst.common.project.facet.core.util.internal.PluginUtil.loadClass(PluginUtil.java:197)
at org.eclipse.wst.common.project.facet.core.util.internal.PluginUtil.instantiate(PluginUtil.java:250)
at org.eclipse.wst.common.project.facet.core.internal.ActionDefinition.createConfigObject(ActionDefinition.java:139)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.createProjectFacetAction(FacetedProjectWorkingCopy.java:1461)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.refreshProjectFacetActions(FacetedProjectWorkingCopy.java:1558)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.setProjectFacets(FacetedProjectWorkingCopy.java:777)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.addProjectFacet(FacetedProjectWorkingCopy.java:807)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionPanel.handleCheckStateChanged(FacetsSelectionPanel.java:758)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionPanel.access$10(FacetsSelectionPanel.java:729)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionPanel$6.checkStateChanged(FacetsSelectionPanel.java:309)
at org.eclipse.jface.viewers.CheckboxTreeViewer$1.run(CheckboxTreeViewer.java:166)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.CheckboxTreeViewer.fireCheckStateChanged(CheckboxTreeViewer.java:164)
at org.eclipse.jface.viewers.CheckboxTreeViewer.handleSelect(CheckboxTreeViewer.java:300)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1220)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:228)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:222)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:389)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsSelectionDialog.openDialog(FacetsSelectionDialog.java:84)
at org.eclipse.wst.common.project.facet.ui.PresetSelectionPanel.handleModifyButtonPressed(PresetSelectionPanel.java:165)
at org.eclipse.wst.common.project.facet.ui.PresetSelectionPanel.access$0(PresetSelectionPanel.java:163)
at org.eclipse.wst.common.project.facet.ui.PresetSelectionPanel$1.widgetSelected(PresetSelectionPanel.java:96)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:117)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.libra.facet.Activator.start() of bundle org.eclipse.libra.facet.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:106)
... 77 more
Caused by: java.lang.NoSuchMethodError: org.osgi.framework.BundleContext.getServiceReference(Ljava/lang/Class;)Lorg/osgi/framework/ServiceReference;
at org.eclipse.libra.facet.Activator.start(Activator.java:46)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
... 83 more
!ENTRY org.eclipse.jface 4 2 2011-06-19 13:32:28.182
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
at org.eclipse.wst.common.project.facet.core.internal.ActionDefinition.createConfigObject(ActionDefinition.java:142)
at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:157)
at org.eclipse.ui.internal.ide.actions.ProjectPropertyDialogAction.run(ProjectPropertyDialogAction.java:77)
What am I missing?
Sahoo
FUDForum. Page generated in 0.01684 seconds
