Home » Eclipse Projects » Memory Analyzer » comparing histograms: Retained heap column not working
comparing histograms: Retained heap column not working [message #674769] Sat, 28 May 2011 11:16 Go to next message
John Smith is currently offline John SmithFriend
A great feature to compare heap dumps, but there is one important
feature missing: I also want to know the difference of the Retained
heap. Calculating the Retained heap column results in an empty column,
but instead I excpected that the difference is calculated, as I had
chosen "Difference to Base Table" before.
Re: comparing histograms: Retained heap column not working [message #675160 is a reply to message #674769] Mon, 30 May 2011 13:05 Go to previous message
Krum Tsvetkov is currently offline Krum TsvetkovFriend
This is true. The reason to have it this way is rather the technical specifics of how we implemented the tables and the retained size calculation.
From the user perspective you are completely right - having the retained size also compared is important.
I have opened a bugzilla ticket describing that we need to get rid of this limitation: https://bugs.eclipse.org/bugs/show_bug.cgi?id=347648.
[Updated on: Mon, 30 May 2011 13:05]
Report message to a moderator
Previous Topic:Download is not working
Next Topic:can't view objects in remainder
Current Time: Sun Apr 22 18:18:24 GMT 2018
Powered by FUDForum. Page generated in 0.01795 seconds
