Home » Eclipse Projects » Rich Client Platform (RCP) » IWorkbenchAdapter not registered correctly(No decorations available in BasicNewFileResourceWizard)
icon4.gif  IWorkbenchAdapter not registered correctly [message #668211] Wed, 04 May 2011 14:03 Go to next message
ChrisFriend
I am using the BasicNewFileResourceWizard in an rcp application. The tree showing the workspace resources does not show icons or labels of resources.
I found out that the factory needed to create the IWorkbenchAdapter does not return anything. That seems to be because the AdapterManager has the type org.eclipse.core.resources.mapping.ResourceMapping registered with the class org.eclipse.core.internal.resources.Project instead of the IWorkbenchAdapter.
a) How can I find out when that ResourceMapping is registered with Project instead of the IWorkbenchAdapter?
b) I tried adding a factory entry in the extension org.eclipse.core.runtime.adapters and alternatively invoke Platform.getAdapterManager().registerAdapters to register the correct class. These attempts were not successful.
A hint into the correct direction would be very helpful.
Re: IWorkbenchAdapter not registered correctly [message #668238 is a reply to message #668211] Wed, 04 May 2011 15:35 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
To work with IWorkbenchAdapter you need to call
org.eclipse.ui.ide.IDE.registerAdapters() in your application's
WorkbenchAdvisor, usually in the initialize(*) method.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: IWorkbenchAdapter not registered correctly [message #668244 is a reply to message #668238] Wed, 04 May 2011 15:57 Go to previous message
ChrisFriend
Wonderful - it worked right away!
Thank you very much!
Previous Topic:Equinox launcher: not working on Mac OS 10.4 Tiger?
Next Topic:CNF: Remove SOME popup options from the ones that are platform contributions
Current Time: Wed Feb 21 17:16:59 GMT 2018
Powered by FUDForum. Page generated in 0.01264 seconds
