Home » Eclipse Projects » Eclipse Platform » Deploy eclipse plugin (On different Platform and Eclipse version)
Deploy eclipse plugin [message #667226] Wed, 27 April 2011 14:24 Go to next message
Mikael Petterson is currently offline Mikael PettersonFriend
When I am developing the plugin I want to make sure that the following is vaild for my plugin:
- It installs and runs on different platforms ( Linux/Solaris/Windows).
- That it installs and runs on 2-3 different versions of Eclipse ( java developer).
I need to automate this so you can run some kind of ant script when it is time for release.
Anyone with hints on how to go about testing this. Anyone with experience of this or who has the same problem ( then we can work together to solve it...).
Re: Deploy eclipse plugin [message #667379 is a reply to message #667226] Thu, 28 April 2011 12:39 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You can write test plugins, and then modify the automated test scripts
to install and run your tests. By default the test scripts run a test
plugin (with a test.xml) in the version of eclipse you just built. [1] runTests shows the setup for our tests. runtests [2]
actually unzips an eclipse to use as a base, and calls the tests, and
test.xml [3] defines how we install plugins into an eclipse and launch them.
[1] pse.e4.builder/scripts/
[2] pse.e4.builder/builder/general/tests/runtests?view=co
[3] pse.e4.builder/builder/general/tests/test.xml?view=co
Paul Webster platform.doc.isv/guide/workbench.htm
Previous Topic:How to resize items in toolbar
Next Topic:Add Drag And Drop support for Team Synchronize View ?
Current Time: Sat Mar 24 20:02:58 GMT 2018
Powered by FUDForum. Page generated in 0.02215 seconds
