Home » Eclipse Projects » Eclipse Communications Framework (ECF) » XMPPS connection fails on handshake(XMPPSContainer fails to connect if server requires client certificate)
Re: XMPPS connection fails on handshake [message #663117 is a reply to message #663008] Sun, 03 April 2011 18:24 Go to previous messageGo to next message
Teddy Yueh is currently offline Teddy YuehFriend
Junior Member
Posted a enhancement requests here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=341724
Since the patch would have to address the smack code error as well, would a temporary solution such as subclassing XmppConnection be acceptable?
The smack ppl seem to know about this already, but I don't see any work being done: http://issues.igniterealtime.org/browse/SMACK-322
Teddy
[Updated on: Sun, 03 April 2011 18:25]
Report message to a moderator
Re: XMPPS connection fails on handshake [message #663119 is a reply to message #663117] Sun, 03 April 2011 18:43 Go to previous message
Scott Lewis is currently offline Scott LewisFriend
Senior Member
Teddy Yueh wrote on Sun, 03 April 2011 14:24
Yes...if this would address both issues it could be done. For the first/certificate issue, my suggestion is to enhance the ECF xmpp provider to take a certificate in the IConnectContext callbacks.
Teddy
I/Scott have a personal connection with Matt Tucker, Jive CTO...and could bring this up with him if it's an identifiable problem with Smack that's not being addressed. Even better would be to give them/Jive a patch with the fix for the XmppConnection issue. Feel free to connect/coordinate directly with me via the bug and/or slewis at composent.com and we'll figure out how to get this addressed.
Scott
Previous Topic:Eclipse CORBA Plugin problem ....
Next Topic:EDEF xml Multiple endpoint problem
Current Time: Sat Apr 21 13:46:08 GMT 2018
Powered by FUDForum. Page generated in 0.01648 seconds
