Home » Modeling » Graphiti » Modifying a separate Ecore file outside Create-Features
icon5.gif  Modifying a separate Ecore file outside Create-Features [message #662421] Wed, 30 March 2011 15:36 Go to next message
Rainer Thome is currently offline Rainer ThomeFriend
Hello again,
I have recently tried to create new EObjects outside of a CreateFeature but eventually failed in many cases due to a concurrent write. Strangely, this has also been happening when e.g. working with a wizard.
I am able to create EObjects, but when trying to save the files in my resource set, I am getting the following error:
URI: platform:/resource/BPMNtest/new_file.bpmn2, cause:
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:348)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:302)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:284)
	at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:240)
I can neither modify the resource by executing a Command on the CommandStack nor can I achieve my goal without a Command.
I don't really have a clue on how to solve the problem, but I hope that you can help me.
Best Regards
Rainer
Re: Modifying a separate Ecore file outside Create-Features [message #662424 is a reply to message #662421] Wed, 30 March 2011 15:39 Go to previous messageGo to next message
Jos Warmer is currently offline Jos WarmerFriend
Rainer, can you give an example of your code both using and not using Command? Also, where is your code triggered? Is this through a Graphiti feature?
Jos
Re: Modifying a separate Ecore file outside Create-Features [message #662429 is a reply to message #662421] Wed, 30 March 2011 15:56 Go to previous messageGo to next message
Hi!
This is my code (using a RecordingCommand):
final BpmnDiagramEditor editor = (BpmnDiagramEditor) Util
	.getActiveEditor();
TransactionalEditingDomain domain = editor.getEditingDomain();
ResourceSet set = domain.getResourceSet();
set.getResourceFactoryRegistry().getExtensionToFactoryMap()
	.put("wsdl", new WSDLResourceFactoryImpl());
Resource r = null;
r = set.createResource(URI.createURI(page.getFilePath()
	.replaceAll("\\\\", "/")
	.replace(Platform.getLocation().toString(), "")));
try {
	r.load(Collections.EMPTY_MAP);
} catch (IOException e) {
	return false;
r.setModified(false);
editor.getImportUtil().addResource(r, Util.PORTTYPES);
final List<EObject> objs = editor.getImportUtil()
	.getObjectsForResource(r);
Definitions def = null;
for (Resource res : set.getResources()) {
	if (res.getURI().fileExtension().equals("bpmn2")) {
		def = ((DocumentRoot) res.getContents().get(0))
			.getDefinitions();
		break;
final Definitions finalDef = def;
domain.getCommandStack().execute(new RecordingCommand(domain) {
protected void doExecute() {
	for (EObject eObject : objs) {
		Interface iface = Bpmn2Factory.eINSTANCE.createInterface();
		iface.setId(EcoreUtil.generateUUID());
		iface.setImplementationRef(eObject);
		for (Operation op : (EList<Operation>) ((PortType) eObject)
				.getEOperations()) {
			org.eclipse.bpmn2.Operation newOp = Bpmn2Factory.eINSTANCE
					.createOperation();
			newOp.setImplementationRef(op);
			iface.getOperations().add(newOp);
		finalDef.getRootElements().add(iface);
The code is called inside a "performFinish()" method of a Jface Wizard. The Exception does not occur inside that code piece, but when I am saving the diagram.
Best Regards
Rainer
[Updated on: Wed, 30 March 2011 15:56]
Report message to a moderator
icon7.gif  Re: Modifying a separate Ecore file outside Create-Features [message #662637 is a reply to message #662421] Thu, 31 March 2011 11:35 Go to previous message
Okay, I managed to resolve the problem myself. It was not a problem of Graphiti itself but of the BPMN2 Metamodel, which I am using. It automatically tries to add an ID to all its elements, if the ID was not set before. This interferes with the save process initiated by the EmfService used by Graphiti. I should have known that, because I already experienced the error before, I just forgot about it.
Thanks for your time and sorry, that I kind of wasted it Embarrassed
Previous Topic:how to remove context menu items of a MultiPageEditor
Next Topic:Images from user directories (as opposed to plugin resources)
Current Time: Thu Feb 22 05:46:21 GMT 2018
Powered by FUDForum. Page generated in 0.01690 seconds
