Home » Language IDEs » Java Development Tools (JDT) » Eclipse Classic on Ubuntu
Eclipse Classic on Ubuntu [message #653705] Thu, 10 February 2011 18:54 Go to next message
Jahangir Najafov is currently offline Jahangir NajafovFriend
I am using Ubuntu 10.10.
I have downloaded Eclipse Classic and tried to install it. But here is some problem.
Somewhere in the Documentation I found informations that Eclipse Classic supports only Ubuntu 10.04 LTS and earlier versions.
In order not to delete current OS without any use, I wanna ask you if Eclipse Classic really do not support Ubuntu 10.10 and everything would be OK, if I install Ubuntu 10.04.
Thank you.
[Updated on: Thu, 10 February 2011 18:54]
Report message to a moderator
Re: Eclipse Classic on Ubuntu [message #653737 is a reply to message #653705] Thu, 10 February 2011 22:02 Go to previous message
David Wegener is currently offline David WegenerFriend
Eclipse works on 10.10. I use it on a regular basis.
Make sure you download from the eclipse.org download page and you install the Sun JDK. Don't use gcj.
Previous Topic:Copying a project in same workspace
Next Topic:Running JUnit headless
Current Time: Fri Apr 20 18:53:35 GMT 2018
Powered by FUDForum. Page generated in 0.02264 seconds
