Home » Language IDEs » Java Development Tools (JDT) » Extending Quick Fix Dialog (UI)
Extending Quick Fix Dialog (UI) [message #653297] Wed, 09 February 2011 04:22 Go to next message
Kivanc Muslu is currently offline Kivanc Muslu
Hi all,
Is it possible to extend the dialog that opens when a user clicks on a quick fix in Eclipse programmatically?
Let's say that I want to add some buttons (such as 'OK' and 'CANCEL') to this dialog. This is an artificial example, I just want to learn if I get that dialog object (I don't know what it is exactly but let's say JPanel or a Panel, Dialog, etc.) and add GUI components into it, change the layout etc.
1- Is this possible?
2- If yes, could you point me an entry code that would create this hook (such as an extension point etc.)
3- If no, is there a better alternative method that you know of (like a hack)?
Thanks a lot in advance, best regards,
Re: Extending Quick Fix Dialog (UI) [message #653302 is a reply to message #653297] Wed, 09 February 2011 04:31 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
On 09.02.2011 10:22, Kivanc Muslu wrote:
> Hi all,
Which dialog exactly? Most of the time there is no dialog shown when a
quick fix is selected.
Eclipse does not use AWT or Swing.
Dani
> a hack)?
Re: Extending Quick Fix Dialog (UI) [message #653315 is a reply to message #653302] Wed, 09 February 2011 05:38 Go to previous message
Hi Dani,
Thanks for the response. Sorry that the question was not clear.
I mean the following dialog when you actually click on the quick fix that is on the left:
http://www.kivancmuslu.com/qf_dialog.png
AWT or Swing does not matter, I didn't knew what Eclipse used internally for GUI, if there is an open API to extend the above dialog, I can use that (actually that would be great!)
Again, thanks a lot!
Previous Topic:unknown error
Next Topic:JAD Files in Eclipse
Current Time: Wed Jun 19 06:16:28 EDT 2013
Powered by FUDForum. Page generated in 0.01762 seconds
