Home » Language IDEs » Java Development Tools (JDT) » how do I access a handler method from a view?(Making a plugin, need help!)
how do I access a handler method from a view? [message #652793] Sun, 06 February 2011 19:38 Go to next message
Joel is currently offline JoelFriend
Hi, I am currently developing a plugin.
I have a view that has a dispose method. In this dispose method I want to be able to call a method called isEnabled from a handler class. The handler class is a command, that is set to a menu.
Does anyone know how i can do this?
[Updated on: Sun, 06 February 2011 19:59]
Report message to a moderator
Re: how do I access a handler method from a view? [message #652879 is a reply to message #652793] Mon, 07 February 2011 13:07 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You want the eclipse.platform or eclipse.platform.rcp forum/newsgroup.
In theory you can get the current enabled state for a command (in 3.x)
ICommandService cs
= (ICommandService) getSite().getService(ICommandService.class);
Command cmd = cs.getCommand("");
if (cmd.isDefined()) {
cmd.isEnabled() returns the enabled state as last set by
the active handler.
Paul Webster .platform.doc.isv/guide/workbench.htm
Previous Topic:organize Resources
Next Topic:Problem with republish not getting triggered
Current Time: Tue Mar 20 16:01:49 GMT 2018
Powered by FUDForum. Page generated in 0.02255 seconds
