Home » Modeling » GMF (Graphical Modeling Framework) » comboboxcelleditor not firing
comboboxcelleditor not firing [message #652622] Fri, 04 February 2011 18:11 Go to next message
Ravi Kiran is currently offline Ravi KiranFriend
Member
As a part of making gmf editor i want to return a comboboxcelleditor for certain datatypes(enum) in my metamodel
so i have implemented my own property descriptor and returned comboboxcelleditor as a cell editor.
but in the gmf editor when i click on show property view, for that data type it's displaying a uneditable default value(default value given enum datatype.
what do i do if i want to show a comboboxcelleditor for that enum datatype
customized proprty descriptor
below DNTypes is the enum data type declared in the meta model.
if everything works fine it should show type1,type2.. in combobox but it isn't showing up
public CellEditor createPropertyEditor(Composite composite) {
CellEditor result=super.createPropertyEditor(composite);
if (result==null)
return null;
EClassifier eType = ((EStructuralFeature) itemPropertyDescriptor
.getFeature(object)).getEType();
if (eType instanceof EDataType) {
EDataType eDataType = (EDataType) eType;
if(eDataType.getInstanceClass() == DNTypes.class)
String s[]={"type1","type2","type3","type4"};
ComboBoxCellEditor cbe=new ComboBoxCellEditor(composite.getParent(),s,getEditLabelProvi der);
cbe.setActivationStyle(0);
return cbe;
//return result;
return result;
any pointers how to proceed
Re: comboboxcelleditor not firing [message #663392 is a reply to message #652622] Mon, 04 April 2011 20:17 Go to previous messageGo to next message
Aurélien Pupier is currently offline Aurélien PupierFriend
I remember that there are more work to do.
Have you already ake a look at this article: http://www.jevon.org/wiki/Using_EDataTypes_in_GMF
Otherwise, I have done it in Jasmine Design: http://wiki.jasmine.ow2.org/xwiki/bin/view/Main/Design
But it was some time ago, I won't able to guide you more.
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: comboboxcelleditor not firing [message #758588 is a reply to message #663392] Wed, 23 November 2011 19:30 Go to previous message
Hoang  is currently offline Hoang Friend
Member
Hi Aurelien,
Thanks for the post, it is very helpful. I have succeeded to create my own File Selector in the property sheet. You're the hero!
My solution is here if someone is interested: https://github.com/pnhoang/Selflet
Hoang,
Previous Topic:Saving diagram drawn on the GMF Editor
Next Topic:How to know the size of the Diagram
Current Time: Tue Jan 23 08:11:24 GMT 2018
Powered by FUDForum. Page generated in 0.01705 seconds
