Home » Language IDEs » Java Development Tools (JDT) » Java Code Formatter missing
Java Code Formatter missing [message #652158] Wed, 02 February 2011 19:31 Go to next message
Nick  is currently offline Nick Friend
So I was playing around with running the java formatter via command line and when I run it I'm receiving a strange error. From the error log:
!ENTRY org.eclipse.osgi 4 0 2011-02-02 10:43:22.365
!MESSAGE Application error
java.lang.RuntimeException: Application "org.eclipse.jdt.core.javacodeformatter" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner,,, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.metadata.generator.EclipseGenerator, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher , org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication , org.eclipse.equinox.p2.metadata.repository.mirrorApplication , org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher,,,, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, org.eclipse.wst.jsdt.core.JavaCodeFormatter.
at faultApp(
at (
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(
at org.eclipse.equinox.launcher.Main.invokeFramework( 619)
at org.eclipse.equinox.launcher.Main.basicRun(
at org.eclipse.equinox.launcher.Main.main(
It appears as if my "org.eclipse.jdt.core.javacodeformatter" package is missing from the eclipse directory, I was unable to find it in the "install new software" under the help menu, so I'm at a loss at how to get it. Any help would be appreciative.
Re: Java Code Formatter missing [message #652167 is a reply to message #652158] Wed, 02 February 2011 20:37 Go to previous message
Apparently I lost capitalization somewhere along the line and the file is case sensitive, thanks anyways.
Previous Topic:ubuntu +eclipse + tomcat can not launch server
Next Topic:LONDON JOB - Up to 55k
Current Time: Fri Mar 23 15:10:57 GMT 2018
Powered by FUDForum. Page generated in 0.01907 seconds
