Ubuntu 10.10 64bit remotely debugging jAPS on apache tomcat 6.0.18 [message #651150] |
Fri, 28 January 2011 02:35 |
No real name Messages: 1 Registered: January 2011 |
Junior Member |
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at java.net.Socket.<init>(Socket.java:375)
at java.net.Socket.<init>(Socket.java:189)
at org.eclipse.jdi.internal.connect.SocketTransportService$2.ru n(SocketTransportService.java:136)
at java.lang.Thread.run(Thread.java:662)
I've tried adding
set JAVA_OPTS="-Xdebug -Xrunjdwp:transport=dt_socket,address=8000,server=y,suspend= n -Djava.awt.headless=true -Xmx128M"
and
set DEBUG_OPTS="-Xdebug -Xrunjdwp:transport=dt_socket,address=8000,server=y,suspend= n -Djava.awt.headless=true -Xmx128M"
to catalina.sh with no success. I know nothing is listening on port 8000. Any suggestions about what to try next? Thanks.
FUDForum. Page generated in 0.02569 seconds
