Home » Language IDEs » Java Development Tools (JDT) » [SOLVED]add own top level new wizard entry to package explorers "New " context menu
icon1.gif  [SOLVED]add own top level new wizard entry to package explorers "New " context menu [message #649883] Thu, 20 January 2011 20:22 Go to next message
Lars Heinemann is currently offline Lars HeinemannFriend
I am currently struggling to get an entry for my new wizard into the context menu of the package explorer. The wizard is displayed if selecting New -> Other inside the Java Perspective, but I would like to have it top level like "new Interface or new Class". In the project explorer it is displayed top level already. So I am a bit puzzled why not in the Package Explorer.
Can somebody give me a hint how I can do this?
Many thanks in advance,
Lars
[Updated on: Fri, 21 January 2011 18:40]
Report message to a moderator
Re: add own top level new wizard entry to package explorers "New " context menu [message #650022 is a reply to message #649883] Fri, 21 January 2011 13:46 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Perspectives control the shortcuts for wizards and views. You can use
org.eclipse.ui.perspectiveExtensions extension to add your wizard to new.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: add own top level new wizard entry to package explorers "New " context menu [message #650026 is a reply to message #649883] Fri, 21 January 2011 13:54 Go to previous messageGo to next message
Hi Paul,
thanks for your answer.
I already did that and the wizard is shown when selecting the
"New -> Other" item. But I'd rather like it to be "New -> MyWizard" directly instead of using the "Other" item.
Re: add own top level new wizard entry to package explorers "New " context menu [message #650053 is a reply to message #650026] Fri, 21 January 2011 14:28 Go to previous messageGo to next message
On 01/21/2011 08:54 AM, Lars Heinemann wrote:
> Hi Paul,
> I already did that and the wizard is shown when selecting the "New ->
You added a perspective extension to contribute the shortcut to the Java
perspective? Then reset the perspective if you already had that
perspective open.
PW
Paul Webster
Re: add own top level new wizard entry to package explorers "New " context menu [message #650107 is a reply to message #649883] Fri, 21 January 2011 18:39 Go to previous message
Paul,
you saved my day Wink
Thank you very much. Resetting the perspective finally did the trick. Thats a bit odd though but at least it works now.
Many thanks,
Lars
Previous Topic:The server does not support version 3.0 of the J2EE Web module specification
Next Topic:Debug memory in Java
Current Time: Mon May 21 21:06:01 GMT 2018
Powered by FUDForum. Page generated in 0.01537 seconds
