Debug breakpoint ok on backend but not on GUI client [message #648858] |
Fri, 14 January 2011 18:25 |
albertkao Messages: 46 Registered: February 2010 |
Member |
I set debug breakpoints on both backend and frontend Swing GUI client with Eclipse 3.3.2 on Windows XP. The backend (data access code) communicates with the frontend code by EJB 2.0.
The debug breakpoints can be triggered on backend (server) but not on frontend Swing GUI client. i.e. Clicking a button on the Swing GUI client will make the program stop at the breakpoints on the backend code but the frontend code.
Please help so that the breakpoints on the frontend code will also work.
[Updated on: Fri, 14 January 2011 18:27] Report message to a moderator
Re: Debug breakpoint ok on backend but not on GUI client [message #649124 is a reply to message #648876] |
Mon, 17 January 2011 19:19 |
Member |
The Swing GUI client is started by Java Web Start in a web browser for user login with their passwords.
Do I connect to both java VMs with only one instance of Eclipse or two independent instances of Eclipse?
How to connect to the Swing GUI client (which options of Eclipse are used)?
Currently I connect to the server program by the Eclipse options
"Debug", "Remote Java Application", "Connect", "Connection Type", "Standard(Socket Attach)", "Host localhost", "Port 8451".
[Updated on: Mon, 17 January 2011 19:36] Report message to a moderator
FUDForum. Page generated in 0.03591 seconds
