Home » Language IDEs » Java Development Tools (JDT) » Creating a Java search scope without creating a project?
Creating a Java search scope without creating a project? [message #648154] Tue, 11 January 2011 14:14 Go to next message
Nicolas Bros is currently offline Nicolas BrosFriend
Member
I'm creating a wizard in which I want to let the user select a type from a list of bundles (or jars).
For this, I'm using JavaUI#createTypeDialog, giving it a IJavaSearchScope.
But I couldn't find how to create a IJavaSearchScope that will look inside jars that are not referenced by projects in the workspace.
I could make it work by creating a project and deleting it afterwards [1], but this is not an elegant solution.
How could I create a IJavaSearchScope without having to create any project?
[1] http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.modi sco/plugins/trunk/org.eclipse.gmt.modisco.infra.common.ui/sr c/org/eclipse/gmt/modisco/infra/common/ui/internal/util/Java Utils.java
Re: Creating a Java search scope without creating a project? [message #648164 is a reply to message #648154] Tue, 11 January 2011 14:37 Go to previous message
Dani Megert is currently offline Dani MegertFriend
On 11.01.2011 15:14, Nicolas Bros wrote:
> IJavaSearchScope.
> inside jars that are not referenced by projects in the workspace. I
> project?
You need a Java project.
Dani
> [1]
Previous Topic:Source code path repeatedly lost in debugger
Next Topic:Why doesn't a local variable's IBinding have a declaring class, when in a class initializer?
Current Time: Mon May 28 01:46:12 GMT 2018
Powered by FUDForum. Page generated in 0.01628 seconds
