Home » Eclipse Projects » Rich Client Platform (RCP) » Splash screen login
Splash screen login [message #646839] Fri, 31 December 2010 23:15
J. Michael Dean, M.D. is currently offline J. Michael Dean, M.D.Friend
I am working with a series of RCP applications that use a login in the
splash screen. This was initially created by selecting an interactive
login in the splash tab of the RCP product editor. I have three apps,
and they all have an individual InteractiveSplashHandler class. But I
have altered this class to handle more sophisticated authentication, and
pulled it out into another plugin that is used by all three apps.
This worked fine by pointing the extensions to the common plugin, but
then I tried to delete the essentially empty splashHandler packages in
each of the apps. Then everything still worked when I launched the apps
from Eclipse, but when I used the product configurations again, they
decided to create a new splashHandler and not use the common one.
If I leave the splash handler and product binding in the extensions, but
delete having a splash handler in the splash tab of the product editor,
then no splash handler is used.
Any assistance greatly appreciated.
- Mike
Previous Topic:View Update other view
Next Topic:What is difference between parameters defined for Commands and Menu Contribs
Current Time: Wed Mar 21 20:51:51 GMT 2018
Powered by FUDForum. Page generated in 0.01790 seconds
