Home » Eclipse Projects » Rich Client Platform (RCP) » Differnt ways register ISelectionProvider
Differnt ways register ISelectionProvider [message #643091] Sat, 04 December 2010 08:24 Go to next message
ash is currently offline ashFriend
Can any once tell different ways register selection provider.
when class implement the ISelectionProvider in general we register with the view getSite().setSelectionProvider(this);
Is there any way to register selection provider with PlatformUI.
Ashok
Re: Differnt ways register ISelectionProvider [message #643117 is a reply to message #643091] Sat, 04 December 2010 19:24 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Did you try: PlatformUI.getWorkbench().getService(ISelectionService.class );
Best Regards,
Wim Jongman
> Thanks
> Ashok
Re: Differnt ways register ISelectionProvider [message #643310 is a reply to message #643091] Mon, 06 December 2010 13:14 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
Our selection service will always take the selection service from the
active part (view/editor).
You must use a part to inject state into the system, as if you *did*
manage to change the window's current selection, the first change in
active part or another parts selection would wipe it out.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Update Site does not work for core features
Next Topic:set availible software update site while creating the product
Current Time: Tue Jun 19 12:51:09 GMT 2018
Powered by FUDForum. Page generated in 0.02051 seconds
