Home » Eclipse Projects » Eclipse 4 » EventHandler not being called!
EventHandler not being called! [message #642858] Fri, 03 December 2010 01:12 Go to next message
AppleJus Mising name is currently offline AppleJus Mising nameFriend
Member
Hi there,
I am really stuck on this one, I appreciate any help:
I have two parts in my app. In the code of the first part, I create and initialize an eventBroker using the IEContext, and pass to it an object via post().
In the second part, I want to get this object, so I create and initialize an eventBroker again using the IEContext, and also create an eventHandler. The problem I am getting is that the method handleEvent(...) is not being called.
I put some System.err.println() there and it is just confirming is it not being called, even though the .subscribe() call is returning successful. I have subscribed and posted data on the same topic string, I call "NEWDATA".
eventHandler = new EventHandler() {
public void handleEvent(org.osgi.service.event.Event event) {
System.err.println("TEST2: ");
CNCE_E.CNCE = (CreateNewCaseEncapsulate) event
.getProperty("NewCaseCreated");
System.err.println("SUCCESS: "
+ eventBroker.subscribe("NEWDATA", eventHandler));
Re: EventHandler not being called! [message #642880 is a reply to message #642858] Fri, 03 December 2010 07:43 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
How does your subscription look like? How does your post code look like?
Maybe there's a missmatch in your topics?
Tom
Am 03.12.10 02:12, schrieb AppleJus:
> Hi there,
> via post().
> I call "NEWDATA".
> @Override
> event) {
Re: EventHandler not being called! [message #643227 is a reply to message #642880] Mon, 06 December 2010 07:48 Go to previous message
Member
Hi, here is the post code, in the other part class:
//send the CNCE object
eventBroker = (IEventBroker) context.get( IEventBroker.class.getName() );
if (eventBroker != null) {
Map<String, Object> map = new HashMap<String, Object>();
map.put("NewCaseCreated", CNCE);
eventBroker.post("NEWDATA", map);
Previous Topic:HowTo Display Validaton Status ICONS in a Form
Next Topic: EPartService cannot find my parts?
Current Time: Tue Feb 20 12:19:13 GMT 2018
Powered by FUDForum. Page generated in 0.02533 seconds
