Home » Language IDEs » Java Development Tools (JDT) » Open Type - filter results based on Working Set
Open Type - filter results based on Working Set [message #641904] Mon, 29 November 2010 08:33 Go to next message
Mike Dundee is currently offline Mike DundeeFriend
is it possible to set filtering on results while in "Open Type" dialog?
I am working within some "Working Set", however if I use "Open Type", it find also results from projects not in "Working Set" which is annoying, since I have some testing projects in my workspace which includes classes with the same name...
Re: Open Type - filter results based on Working Set [message #641949 is a reply to message #641904] Mon, 29 November 2010 10:46 Go to previous messageGo to next message
Deepak Azad is currently offline Deepak AzadFriend
On 11/29/2010 2:03 PM, Mike Dundee wrote:
> Hello,
Yup. On the top right of the dialog there is a button (inverted
triangle), click it and from the dropdown select a working set.
Re: Open Type - filter results based on Working Set [message #641956 is a reply to message #641949] Mon, 29 November 2010 11:20 Go to previous message
Wow, that did the trick!
Thanks a million!
Previous Topic:Providing Examples at New --> Examples Wizard
Next Topic:Error within Web Page Editor (Web Tools Platform)
Current Time: Mon Apr 23 02:16:35 GMT 2018
Powered by FUDForum. Page generated in 0.01655 seconds
