Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] "0 Model Version(s) registered" error
[EMFStore] "0 Model Version(s) registered" error [message #641490] Thu, 25 November 2010 16:15 Go to next message
Guillaume P. is currently offline Guillaume P.Friend
Member
Hi !
I would like to test the EMFStore framework. So I followed the two video tutorials to install everything, to prepare the EMF model (and *.genmodel), and to launch a server using these models, but I have always the same error (even if I use directly the provided Library example):
| unicase EmfStore |
!SESSION 2010-11-25 16:59:55.593 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_13
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments:  -product org.unicase.emfstore.server -EMFStoreHome=D:/Documents/pelouas/Program Files/eclipse/EMFStoreServer
Command-line arguments:  -product org.unicase.emfstore.server -data D:\Documents\pelouas\workspace/../runtime-EMFStore_Server -dev file:D:/Documents/pelouas/workspace/.metadata/.plugins/org.eclipse.pde.core/EMFStore Server/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -EMFStoreHome=D:/Documents/pelouas/Program Files/eclipse/EMFStoreServer
!ENTRY org.unicase.metamodel 1 1 2010-11-25 16:59:58.515
!MESSAGE Property file read. (D:\Documents\pelouas\Program Files\eclipse\EMFStoreServer\.\conf\es.properties)
!ENTRY org.unicase.metamodel 2 2 2010-11-25 16:59:58.531
!MESSAGE There is 0 Model Version(s) registered for the given model. Migrator will assume model version 0.
!STACK 0
org.unicase.metamodel.util.MalformedModelVersionException: There is 0 Model Version(s) registered for the given model. Migrator will assume model version 0.
	at org.unicase.metamodel.util.ModelUtil.getModelVersionNumber(ModelUtil.java:802)
	at org.unicase.emfstore.startup.MigrationManager.migrateModel(MigrationManager.java:50)
	at org.unicase.emfstore.EmfStoreController.run(EmfStoreController.java:114)
	at org.unicase.emfstore.EmfStoreController.start(EmfStoreController.java:83)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
!ENTRY org.unicase.metamodel 1 1 2010-11-25 16:59:58.812
!MESSAGE Using RessourceStorage "org.unicase.emfstore.storage.XMLStorage".
!ENTRY org.unicase.metamodel 1 1 2010-11-25 16:59:58.906
!MESSAGE Validating serverspace ...
Validation: Resolving all elements...
Errors: 0
Validation took: 0 ms
Validation: Checking ModelElementIds...
Errors: 0
Validation: Project generation compare ...
Errors: 0
!MESSAGE Validation complete.
!MESSAGE History cache has been initialized.
!ENTRY org.unicase.metamodel 1 1 2010-11-25 16:59:58.921
!MESSAGE Couldn't load password file from path: D:/Documents/pelouas/Program Files/eclipse/EMFStoreServer\.\conf\user.properties
!ENTRY org.unicase.metamodel 2 2 2010-11-25 16:59:58.937
!MESSAGE UNICASE Model wasn't added to launch configuration.
!ENTRY org.eclipse.core.runtime 4 2 2010-11-25 16:59:58.937
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.runtime".
!STACK 0
	at org.unicase.emfstore.EmfStoreController$1.logging(EmfStoreController.java:157)
	at org.eclipse.core.internal.runtime.Log$1.run(Log.java:66)
	at org.eclipse.core.internal.runtime.Log.log(Log.java:73)
	at org.unicase.metamodel.util.ModelUtil.log(ModelUtil.java:563)
	at org.unicase.metamodel.util.ModelUtil.logWarning(ModelUtil.java:601)
	at org.unicase.emfstore.startup.ExtensionManager.checkModel(ExtensionManager.java:89)
	at org.unicase.emfstore.EmfStoreController.run(EmfStoreController.java:130)
25 nov. 2010 16:59:59 sun.rmi.server.UnicastServerRef logCall
PLUS FIN: RMI TCP Connection(1)-140.94.111.198: [140.94.111.198: sun.rmi.registry.RegistryImpl[0:0:0, 0]: void rebind(java.lang.String, java.rmi.Remote)]
RMIConnectionHandler is running.
RMIAdminConnectionHandler is running.
!ENTRY org.unicase.metamodel 1 1 2010-11-25 16:59:59.640
!MESSAGE Started XML RPC Webserver on port: 8080
!ENTRY org.unicase.metamodel 1 1 2010-11-25 16:59:59.671
!MESSAGE Notifying post startup listener
!ENTRY org.unicase.metamodel 1 1 2010-11-25 16:59:59.718
!MESSAGE Backchannel initiated successfully.
!MESSAGE Initialitation COMPLETE.
!MESSAGE Server is RUNNING...
Does someone has an idea of what could be wrong ?
I'm using the Helios version of Eclipse, on XP, and with the EMFStore 6.2 (last) version. I can provide more information if needed.
Thank you for your help !
Re: [EMFStore] "0 Model Version(s) registered" error [message #641504 is a reply to message #641490] Thu, 25 November 2010 17:20 Go to previous messageGo to next message
Maximilian Koegel is currently offline Maximilian KoegelFriend
Hi Guillaume,
everything should be fine and working since the server states: Server is
RUNNING.... However I see that these are ugly warnings...;) We have
already removed these warnings, but the new version has not been
released yet.
The first warning by the way is only related to model migration and not
relevant as long as you do not want to migrate a model. The second
warning is a bug with Helios but only harms logging and no other
functionality.
Hope this helps!
Maximilian
On 11/25/10 5:15 PM, Guillaume P. wrote:
> Hi !
> example):
> | unicase EmfStore |
> file:D:/Documents/pelouas/workspace/.metadata/.plugins/org.e clipse.pde.core/EMFStore
> !STACK 0
> model version 0.
> at
> org.unicase.metamodel.util.ModelUtil.getModelVersionNumber(M odelUtil.java:802)
> at
> org.unicase.emfstore.startup.MigrationManager.migrateModel(M igrationManager.java:50)
> at org.unicase.emfstore.EmfStoreController.run(EmfStoreControll er.java:114)
> at
> org.unicase.emfstore.EmfStoreController.start(EmfStoreContro ller.java:83)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> model version 0.
> at
> at
> at
> at
> at
> at
> at
> at
> Errors: 0
> Errors: 0
> Errors: 0
> !STACK 0
> java.lang.NullPointerException
> at
> org.unicase.emfstore.EmfStoreController$1.logging(EmfStoreCo ntroller.java:157)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.unicase.metamodel.util.ModelUtil.logWarning(ModelUtil.ja va:601)
> at
> org.unicase.emfstore.startup.ExtensionManager.checkModel(Ext ensionManager.java:89)
> at org.unicase.emfstore.EmfStoreController.run(EmfStoreControll er.java:130)
> at
> at
> at
> at
> at
> at
> java.rmi.Remote)]
> java.rmi.Remote)]
Re: [EMFStore] "0 Model Version(s) registered" error [message #641612 is a reply to message #641504] Fri, 26 November 2010 10:14 Go to previous messageGo to next message
Member
Yes, you're right, it's working perfectly if I ignore these errors !
I had other exceptions, but it was a problem on my side (bad re-generation of my EMF model code, which produced an incorrect plugin.xml file).
But I have some more questions:
- Is the backchannel implemented (as I don't see it working in the sample interface) ?
- When creating a new user, I cannot chose the password... where is it configurable ? what is the default password for a new user ?
- How to access the EMFStore Client API ? It seem's that the "org.unicase.emfstore.client.source" (I don't find the not-source version) does not exports any package...
And at last, a more global question: I'm currently testing different solutions (CDO, SVN and EMF based system, ... and EMFStore) in order develop some big solution for my enterprise (by "big", I mean managing big models, with something like 80 000 objects, about 20 simultaneous users, advanced search features over all the model, ...).
So, do you think your solution is currently sufficiently mature to be used in such project, or is there some important bugs or important features missing ?
Moreover, what are EMFStore advantages compared to CDO (as CDO has now an offline mode too, even if it is not documented) ?
I know all of this make a lot of questions, but I'm just discovering your project (I've already tested CDO and a solution with SVN), and it doesn't remains a lot of time for me make the choice between those technologies.
Thank you very much for your future response Smile
Guillaume
[EDIT]: I changed my question about the automatic feedback (which is described as the backchannel on your website), and added a question about the Client API.
[EDIT AGAIN]: I founded a start of solution to use the EMFStore API by using this tutorial and this example (where I see that the used pluggin is not "org.unicase.emfstore.client.source" but "org.unicase.workspace").
[Updated on: Fri, 26 November 2010 14:23]
Report message to a moderator
Re: [EMFStore] "0 Model Version(s) registered" error [message #641970 is a reply to message #641612] Mon, 29 November 2010 12:18 Go to previous messageGo to next message
Hi Guillaume,
comments inline...
> plugin.xml file).
OK, great!
> - Is there a feature allowing efficient auto-feedback (updating
> automatically local model when a remote change occurs, and this without
> reloading all the model) ?
Yes, there is a feature called backchannel, which allows you to be
notified when the remote model changes. You can then let the local model
update from the server. This will be efficient since only the changes
will be transferred, not the whole model. There is almost no
documentation on the backchannel feature at the moment. But if you would
like to use it I can definitely help you and write some documentation.
The feature is used by the RedView project for example.
Authentication can be configured in the es.properties:
http://code.google.com/p/unicase/wiki/EMFStore_Configuration
It is configured via the parameters
emfstore.accesscontrol.authentication.policy and the other parameters
below that in the config. Users can be authenticated against LDAP or a
plain text file. Currently there is no way to set the password in the
UI, but we plan on having this feature. If you would like to have it let
me know and I will increase priority.
We test with 100.000+ elements. 20 simultaneous users seems no problem
to me, we have far more than that in existing installations. Concerning
the search features, EMFStore is a fast as EMF is since you have a local
copy of the model on the client.
> features missing ?
Yes I do think it is sufficiently mature. We are already using it in
production software. To our knowledge no important feature is missing,
but this depends on your use case...;). I suggest to have a telco and
discuss this live on Skype. I sent you an email to your gmail adress
with my nickname.
The offline mode of CDO does not support interactive merging to my best
knowledge, so the client application code has to merge models in case of
a conflict manually.
> technologies.
This is perfectly fine, I understand this! Actually it is great that you
ask all these questions since they will help other people in the future
if they read this newsgroup. When I started with EMF there was almost no
question that had not already been answered (by Ed ;) ). So let´s try
and do that for EMFStore!
Maximilian
> Thank you very much for your future response :)
> Guillaume
Re: [EMFStore] "0 Model Version(s) registered" error [message #643338 is a reply to message #641970] Mon, 06 December 2010 14:38 Go to previous messageGo to next message
Member
Hi Maximilian !
Yes, I would be interested by a backchannel documentation (or example), as I would be interested by the user password manager implementation.
After our discussion, I tried several thing to resolve my problem, but I only finished by broking the model stored on the EMF Store server, making the server restart impossible (because of validation problems). So I reseted the EMF Store server (is there any way to clean the server when such problem occurs ?).
But now, I have another problem: I'm trying to create a sample project, but when creating a new root object, I have the following exception:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http:///LibraryGroup.ecore' not found. ( file:///D:/Documents/xxx/Program%20Files/eclipse/virtualUnic aseUri, 5, 165)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2591)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2422)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:2072)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:2031)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:134)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1840)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1023)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
... 22 more
I don't understand how package URIs (which I thought being only an identifier) should be formated to be valid. Could you give me some help on this point please ?
Guillaume
Re: [EMFStore] "0 Model Version(s) registered" error [message #643375 is a reply to message #643338] Mon, 06 December 2010 16:42 Go to previous messageGo to next message
Hi Guillaume,
OK, I will add documentation for this, it might take to the end of
December. If you have any questions now, please do not hesitate to ask.
What do you mean by this?
Can you send me an exception and provide me with more description ;)
> Quote:
Did you configure your model plugin to launch with the server in the
server configuration? I think this is the problem, the server "does not
know" your model.
Maximilian
> Best regards,
> Guillaume
Re: [EMFStore] "0 Model Version(s) registered" error [message #643611 is a reply to message #643375] Tue, 07 December 2010 16:12 Go to previous messageGo to next message
Member
Thank you ! Smile
I'm speaking about some UI to set the users passwords... but it's not urgent. Wink
> Can you send me an exception and provide me with more description Wink
Well... I have no more this error as I reseted everything :-/ But I remember the exception raised by the server when starting (before shutting down) was telling that the model validation were failing. Sorry but I don't remember more :-/
>> But now, I have another problem: ...
> know" your model.
No, my model plugins are correctly included into the server run configuration... the error probably comes from elsewhere :-/
Guillaume
Re: [EMFStore] "0 Model Version(s) registered" error [message #643618 is a reply to message #643611] Tue, 07 December 2010 16:29 Go to previous messageGo to next message
Member
I found the problem: the following extension was missing in my model plugin (I don't know why):
<extension point="org.eclipse.emf.ecore.generated_package">
      <package
            uri="http:///LibraryGroup.ecore"
            class="LibraryGroup.LibraryGroupPackage"
            genModel="model/LibraryGroup.genmodel"/>
   </extension>
Re: [EMFStore] "0 Model Version(s) registered" error [message #643638 is a reply to message #643618] Tue, 07 December 2010 17:29 Go to previous messageGo to next message
Once the plug.xml exists, it won't be regenerated...
> <package
> </extension>
Re: [EMFStore] "0 Model Version(s) registered" error [message #643799 is a reply to message #643611] Wed, 08 December 2010 10:16 Go to previous message
comment inline ;)
> Thank you ! :)
Don´t thank me before I have done it ;))
> urgent. ;)
OK, I get it! I planned this as a feature into the next sprint already,
it is definitely a good point!
>> not know" your model.
I see you already found the problem (see next post).
Maximilian
> Guillaume
Previous Topic:How to create a dynamic instances of two dependant Metamodels
Next Topic:Comparing GMF Resources
Current Time: Wed Jan 17 09:27:16 GMT 2018
Powered by FUDForum. Page generated in 0.01858 seconds
