Home » Eclipse Projects » Eclipse Platform » Register a PreferencePage at runtime?
Register a PreferencePage at runtime? [message #639106] Mon, 15 November 2010 10:37 Go to next message
Jan Kohnert is currently offline Jan KohnertFriend
I want to register and create preference pages at runtime, wthout use of the 'org.eclipse.ui.preferencePages.page' Extensionpoint.
Is this possible? and if yes, how?
Jan
Re: Register a PreferencePage at runtime? [message #639238 is a reply to message #639106] Mon, 15 November 2010 17:42 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You can instantiate your own
org.eclipse.jface.preference.PreferenceDialog.PreferenceDial og(Shell,
PreferenceManager) with your own preference pages.
it won't be hooked up to the standard workbench preference system,
though, which is controlled by a subclass. See
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.cr eateDialogOn(Shell,
String)
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Register a PreferencePage at runtime? [message #734597 is a reply to message #639238] Sat, 08 October 2011 20:18 Go to previous message
Marco Lopes is currently offline Marco LopesFriend
Member
Paul Webster wrote on Mon, 15 November 2010 12:42
String)
PW
Paul Webster
Paul,
Can you take a look at this "related" post?
http://www.eclipse.org/forums/index.php/t/237702/
Maybe you can explain that behavior.
Thanks.
Previous Topic:[Debug Platform] Stack Frame doesn't get focus
Next Topic:.eclipseproduct is not generated
Current Time: Wed May 23 01:46:06 GMT 2018
Powered by FUDForum. Page generated in 0.01955 seconds
