Home » Modeling » Papyrus » Modify palette at runtime
Modify palette at runtime [message #636727] Tue, 02 November 2010 15:19 Go to next message
123star  is currently offline 123star Friend
I'd like to modify the palette in this way:
in a ISelectionListener I listen to the selection of pages, when a page is selected by the user I'd like to hide or show the groups of my custom palette.
Is it possible?
Where should I look if the only thing I see in the ISelectionListener is the selected IPage; is there a way to retrieve the palette at runtime and the modify it (hoping it refreshes its view automatically...)?
Thanks in advance, 123star
Re: Modify palette at runtime [message #636895 is a reply to message #636727] Wed, 03 November 2010 09:17 Go to previous messageGo to next message
Patrick Tessier is currently offline Patrick TessierFriend
I have duscussed with Remi, I exist a solution. He will respond to you.
Re: Modify palette at runtime [message #637893 is a reply to message #636895] Tue, 09 November 2010 09:42 Go to previous message
Remi Schnekenburger is currently offline Remi SchnekenburgerFriend
sorry for the delay, I was attending to the nice Eclipse Summit Europe.
The palette listens for the prefenreces of the tool. It also listens the application/unapplication of the profile application.
As soon as a profile is applied, the preferences for the palette display is updated.
In your case, you could implement a selection listener and use the org.eclipse.papyrus.diagram.common.part.PapyrusPalettePrefer ences.changePaletteVisibility(String, String, boolean) method, changing the visiblity of the tool depending on your conditions
Remi Schnekenburger
Get professional Eclipse developer support:
Previous Topic:Model Corrupted
Next Topic:How to edit parameters for class operations in class diagram?
Current Time: Fri Mar 23 05:32:29 GMT 2018
Powered by FUDForum. Page generated in 0.01398 seconds
