In hosted Eclipse Runtime I can't seem to get compare to work for my own models -- I've registered them under content types. Any ideas about what might be going wrong?
Also, does it make sense to register these programmatically or through extension point?
Hi Miles. I realize that's a pretty late answer but I just came upon this newsgroup, EMF compare is using the EMF one (and used to use the EMFT one).
For the record, yes you should either extend the EMF Compare content type directly and then the platform should call EMF compare, or specify the compare merger with your own content type like this :
