Home » Modeling » Epsilon » Assigning rule generated target model elements to a contained reference
Assigning rule generated target model elements to a contained reference [message #632337] Tue, 12 October 2010 15:36 Go to next message
James Sharp is currently offline James SharpFriend
Hi Chaps,
I have been toying around with rules and the usage of equivalent and equivalents.
I have the following rule:
rule DefinedType2NameType
transform definedType : vhdl!DefinedType
to nameType : csp!NameType {
guard : not (definedType.containsItem.exists(typeItem : vhdl!TypeItem | typeItem.name <>"'1'" and typeItem.name<>"'0'"))
nameType.name := definedType.name.toUpperCase();
nameType.definesNameTypeItems := new csp!NameTypeList;
nameType.definesNameTypeItems.containsDataTypeItem.equivalen ts();
var temp := definedType.containsItem.equivalents();
//nameType.definesNameTypeItems.containsDataTypeItem.addAll( temp);
temp.println();
This rule triggering the creation of the equivalent CSP values using a lazy rule (not shown here), however when I uncomment the line:
nameType.definesNameTypeItems.containsDataTypeItem.addAll(te mp);
I get the error message:
Internal error: java.lang.ArrayStoreException
How would I go about assigning the collection of tranformed TypeItems to the target model location specified by the commented line?
Many Thanks,
James
Re: Assigning rule generated target model elements to a contained reference [message #632514 is a reply to message #632337] Wed, 13 October 2010 09:39 Go to previous messageGo to next message
Hi chaps,
This is an error on my account. I should be using equivalent() not equivalents().
Please could you elaborate if possible on what equivalents() does as the manual is not clear.
Many Thanks,
James
Re: Assigning rule generated target model elements to a contained reference [message #632539 is a reply to message #632514] Wed, 13 October 2010 10:36 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi James,
x.equivalents() returns a collection that contains all the elements
produced from x.
x.equivalent() is the same as x.equivalents().first()
Dimitris
James Sharp wrote:
> Hi chaps,
> equivalents().
> Many Thanks,
> James
Re: Assigning rule generated target model elements to a contained reference [message #632589 is a reply to message #632539] Wed, 13 October 2010 14:12 Go to previous messageGo to next message
Hi Dimitris,
When performing .equivalent() I am receiving a bag in return as .equivalents() was returning a Bag of Sequences. Hence my assumption to move to equivalent() rather than equivalents().
How is this so?
Many Thanks,
James
Re: Assigning rule generated target model elements to a contained reference [message #632598 is a reply to message #632539] Wed, 13 October 2010 14:43 Go to previous messageGo to next message
Hi Dimitris,
My results when using equivalent() and equivalents() does not follow this pattern, (or maybe I have just not understood how to assign the values properly)
I have the line:
cProc.processStatement.letHaskellStatements.addAll(vProc.pro cessStatements.equivalent());
which returns:
Bag {HaskellStatement []} <- just one element as you say:
However if I use:
cProc.processStatement.letHaskellStatements.addAll(vProc.pro cessStatements.equivalents());
this returns:
Bag {Sequence {HaskellStatement []}, Sequence {}}
And I get the error message:
at org.eclipse.emf.common.util.BasicEList.assign[BasicEList.jav a:124]
If I remove the @lazy from the rule I get 2 HaskellStatements generated within my model (albeit not assigned to the correct object).
Should I be getting back both HaskellStatements? Should they be wrapped as Sequence like this for equivalents()?
The Lazy rule producing them is:
@lazy
rule Assignment2HaskellStatement
transform vAssignment : vhdl!Assignment
to hStatement : csp!HaskellStatement {
hStatement.assignsValueTo := csp!TypeItem.select
(item|vAssignment.assignValueTo.usesElement.name.isSubstring Of(item.name)).first();
Sorry but totally lost why this is the result I am getting here, any help would be greatly appreciated.
Many Thanks,
James
Re: Assigning rule generated target model elements to a contained reference [message #632614 is a reply to message #632598] Wed, 13 October 2010 15:16 Go to previous messageGo to next message
Hi James,
equivalent() and equivalents() return different results depending on
whether they are invoked on objects or collections. For an object "o"
and a collection "c":
o.equivalent() -> returns one object
o.equivalents() -> returns a collection of objects
c.equivalent() -> returns a collection of objects
c.equivalents() -> returns a collection of collections
Therefore, the fact that
vProc.processStatements.equivalents() -> Bag {Sequence {HaskellStatement
[]}, Sequence {}}
means that processStatements is a collection which contains 2 objects,
the first of which has generated 1 HaskellStatement object and the
second has generated nothing.
Does this help?
Dimitris
James Sharp wrote:
> Hi Dimitris,
> values properly)
> I have the line:
> which returns:
> However if I use:
> this returns:
> @lazy
> Many Thanks,
> James
Re: Assigning rule generated target model elements to a contained reference [message #632623 is a reply to message #632614] Wed, 13 October 2010 15:47 Go to previous message
Hi Dimitris,
Thanks, makes perfect sense. Didn't think about what it was operating on..... whoops.
James
Previous Topic:Calling Operations from within Operations
Next Topic:re-execute rule to duplicate object generation
Current Time: Thu Apr 26 09:55:24 GMT 2018
Powered by FUDForum. Page generated in 0.01884 seconds
