Home » Modeling » Papyrus » Diagram generation from models
| Diagram generation from models [message #632216] |
Tue, 12 October 2010 02:56  |
Jan Reimann Messages: 65 Registered: July 2009 |
Member |
Currently the generation of diagram files from existing UML models
doesn't exist. But since the UML2Tools are not part of Helios anymore we
must use Papyrus as new graphical modeling environment. To make the
transfer easier it would be very nice if I could generate new Papyrus
diagrams from existing models. When is this feature planned to be
integrated?
best regards,
Gilbert
| Re: Diagram generation from models [message #633485 is a reply to message #633210] |
Mon, 18 October 2010 04:01   |
Originally posted by: formatzeh.gmx.de
Hi Raphaël,
thanks for your reply. I'm interested in the second use case since I'm
in the situation that I have a lot of UML models created with the
UML2Tools. So - to overcome the new diagram environment Papyrus it
should be possible to easily generate (or initialize) diagrams from the
old models. I only can say that, until now, Papyrus is not a solution
because of that missing feature. I recognized that the UML2Tools are
missing in Helios, so I tried out Papyrus and could not generate new
diagrams for my old models. So I installed some snapshot of the
UML2Tools. But I'm willing to use Papyrus. So initializing a new diagram
with all model elements included would be a solution for me. The layout
is another problem. But there is a group having some layout ideas.
Consider the following link:
http://rtsys.informatik.uni-kiel.de/trac/kieler
An initial nice layout can be set with their framework and the rest must
be done by the user. For me it sounds great :)
best regards,
Gilbert
raphaël Faudou wrote:
> Hi Gilbert,
> There are two different things : 1/create a Papyrus model from .uml file
> and 2/initialize diagrams from existing UML elements.
> What you can already do is 1/
> You just start from .uml file and then create a Papyrus model with 3
> associated files (.uml, .di and .notation). To do that, you just have to
> select your .uml model and then right click "New>papyrus model". I
> creates a Papyrus model and from the "model explorer" view you can
> create diagrams on which you will be able to drag and drop existing UML
> elements.
> Concerning 2/ it is more complex as we need to determine which elements
> should be on the diagram and which sould not. If we apply the strategy
> to put all elements from a given package, when you start from a large
> .uml model, the initialization of a class diagram might lead to layout
> problems. Well, this feature requires discussions and probably some
> configuration to handle the different possible usages.
> Please let us know which use case you would like to see in Papyrus and
> we can submit a feature on that.
> regards
> Raphaël
> Papyrus team
>> integrated?
>> best regards,
>> Gilbert
| Re: Diagram generation from models [message #633505 is a reply to message #633485] |
Mon, 18 October 2010 05:32   |
Raphael Faudou Messages: 77 Registered: July 2009 |
Member |
Hi Gilbert,
if we can find time to initialize a few diagrams, which initializations
would you like to see in proiority? class diagram? what else?
regards
raphaël
Le 18/10/2010 10:01, Gilbert Mirenque a écrit :
> Hi Raphaël,
> best regards,
> Gilbert
>> Hi Gilbert,
>> elements.
>> regards
>> Raphaël
>> Papyrus team
>>> integrated?
>>> best regards,
>>> Gilbert
| Re: Diagram generation from models [message #633535 is a reply to message #633505] |
Mon, 18 October 2010 06:55   |
Hi Raphaël,
Class diagrams and state charts would be nice.
best regards,
Gilbert
> Hi Gilbert,
> regards
> raphaël
>> Hi Raphaël,
>> best regards,
>> Gilbert
>>> Hi Gilbert,
>>> elements.
>>> regards
>>> Raphaël
>>> Papyrus team
>>>> anymore we
>>>> integrated?
>>>> best regards,
>>>> Gilbert
| Re: Diagram generation from models [message #635325 is a reply to message #635324] |
Tue, 26 October 2010 08:45  |
Dave Carlson Messages: 399 Registered: July 2009 |
Thank you Sabastien, I am CCed on the bug and look forward to testing this feature.
Another scenario for testing that I tried last week: use a WSDL specification with XML Schemas to reverse-engineer into a UML specification. I am testing this for healthcare specifications. I used XSD to create Ecore model, then converted Ecore to UML. We then need to create class and sequence diagrams to document this service specification.
Current Time: Wed May 22 11:15:08 EDT 2013
Powered by FUDForum. Page generated in 0.01724 seconds
