Home » Modeling » Papyrus » Download source of official page and extend composite diagrams
Download source of official page and extend composite diagrams [message #629056] Sun, 26 September 2010 20:58 Go to next message
Andres  is currently offline Andres Friend
Member
1-Hello, i like download the papyrus source code from
https://speedy.supelec.fr/Papyrus/svn/Papyrus/,
but i have problem in the most of svn client, that throw me and error message that says that the repository was relocate.
Just with eclipse svn client i can download some of the sources, but others like core folder i cant download.
Any suggestion?
what is the differennce between the sources in this svn repository and the repository of eclipse?
2-I WAS INVESTIGATE papyrus to examinate the posibility to extend this with a new diagram of specific profile.... how i can get the gmf source for example of class diagram, to do this? i see the source of papyrus from http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/branches/0.7.X/plugins,but i dont see the gmf of diagram class. the diagram classs of papyrus was made with gmf?...how i could extend this?.
Re: Download source of official page and extend composite diagrams [message #630249 is a reply to message #629056] Fri, 01 October 2010 10:17 Go to previous messageGo to next message
Remi Schnekenburger is currently offline Remi SchnekenburgerFriend
Hello Andres,
1. you are confusing between the Papyrus MDT project, and one its predecessor, Papyrus.
The Eclipse official project is Papyrus MDT, you are on the forum for this project. The svn sources are located there: http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus
The repository you have given adress is the repository for the old papyrus project, which was one of the projects that initiate the contribution to the Eclipse Papyrus MDT project. the adress still works for me, surprising!
2. To get the class diagram plugin, you were in the right place, the plugins folder is then divided into several parts, in order to reflect the structure of the tool itsel. All UML diagrams are located in the uml sub-folder. For example, for class diagram code, you should download this plugin: http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/branches/0.7.X/plugins/uml/org.eclipse.papyrus.diagram.c lazz.
To generate code, we have extended the GMF generator templates and metamodel. you will find this stuff in the developer plugins folder:
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/branches/0.7.X/plugins/developer.
To see an example of the extension of diagrams, look for the sysml diagrams in the sysml folder. for example, the bdd diagram is an extension of UML papyrus diagram.
Rémi
Re: Download source of official page and extend composite diagrams [message #630447 is a reply to message #630249] Sat, 02 October 2010 16:27 Go to previous messageGo to next message
Member
Thanks Rémi for reply, I was conffused with Papyrus and Papyrus MDT, that you say.
Anyway, i can dowload the source of the old project, -I had a problem with my svnclient..-.
I like make you an other question, I am working with eclipse helios -modeling version-, and i want with update manager download papyrus mdt plugin to work with eclipse.
If i download the plugin with the option Help,Installing Modeling Components, i download succesfull the plugin version 0.7.
But if i try to download the last version 1.12-3, with help,Install new software, and the update site http://www.papyrusuml.org/home/liblocal/docs/updates/papyrus
I have the folowing error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Papyrus UML Modeler 1.12.3.200912231359 (com.cea.papyrus.feature.feature.group 1.12.3.200912231359)
Missing requirement: Papyrus UML Modeler 1.12.3.200912231359 (com.cea.papyrus.feature.feature.group 1.12.3.200912231359) requires 'org.eclipse.draw2d.feature.group [3.5.0,3.6.0)' but it could not be found
Can you help me?
Andrés
Re: Download source of official page and extend composite diagrams [message #630572 is a reply to message #630447] Mon, 04 October 2010 08:38 Go to previous message
I answered you in the other post:
http://www.eclipse.org/forums/index.php?t=rview&goto=630 449
Cheers
Rémi
[Updated on: Mon, 04 October 2010 08:39]
Report message to a moderator
Previous Topic:Icons for stereotypes
Next Topic:Help adding menu
Current Time: Sun Feb 25 06:11:21 GMT 2018
Powered by FUDForum. Page generated in 0.02044 seconds
