assigning a default value to an inherited property [message #627617] |
Wed, 20 May 2009 14:43 |
Szymon Messages: 6 Registered: July 2009 |
Junior Member |
I am using uml2 and I have a problem with assigning a default value to an
inherited property.
In my uml model I have a class A with a property a. In a class B, which is
a child of A I would like to assign a default value for the property a. In
class B I use the same name for the property a.
When I try to generate the EMF model I get a warning "Discarded feature
'B::a' because it is a duplicate of inherited feature 'A::a'".
If I set the "Redefined Property" of B::a to point to A::a it is even
worse because I get an additional warning: "Feature 'B::a' should be
annotated as redefintion of feature 'A::a'".
Obviously when I generate a java code on the basis of my model the default
value is not assigned to the property a of class B.
Any idea how I could assign a default value to the property a of the class
B?
regards,
Szymon
FUDForum. Page generated in 0.03883 seconds
