Home » Modeling » Papyrus » How to re-open a diagram?
How to re-open a diagram? [message #606936] Thu, 02 September 2010 06:30 Go to next message
Arto Jarvinen is currently offline Arto Jarvinen
Member
I have created a couple of diagrams in Papyrus. I see that the diagram data is in the .notation file (I assume this is the serialization of the model). Then I closed the diagrams using the Close Diagram pop-up command. Now I want to open a diagram again but I can't find any command for that. I'm sure I'm just looking at the wrong place but I've been doing it for quite some time so any hints would be appreciated. Thanks! -Arto
Blog: http://www.ostrogothia.com/process/
Re: How to re-open a diagram? [message #606940 is a reply to message #606936] Thu, 02 September 2010 07:46 Go to previous messageGo to next message
Tatiana Fesenko is currently offline Tatiana Fesenko
Hello Arto!
There should be a corresponding .di file next to .notation file. Try to open the *.di file - it should work.
Best wishes,
Tanya.
Re: How to re-open a diagram? [message #606941 is a reply to message #606940] Thu, 02 September 2010 09:19 Go to previous messageGo to next message
Member
Thanks Tanya,
I understand. The thing is that if I close all diagram tabs at the bottom of the .di editor and then reopen the editor, its turns up gray, i.e. no diagrams show. That is as it should I guess since i closed the diagrams. But I can't find any way to show the diagram tabs (and thus the associated diagrams) again. I assume that closing a diagram tab doesn't mean that it is deleted? And it seems to remain in the .notation file so the diagram data seems to persist.
Arto
Re: How to re-open a diagram? [message #606942 is a reply to message #606941] Fri, 03 September 2010 11:06 Go to previous message
Yann Tanguy is currently offline Yann Tanguy
Member
Expand the model explorer tree to find your diagram, right click on the
diagram in this tree and use "Open" command in the contextual menu.
regards,
YT
Arto Jarvinen a écrit :
> Thanks Tanya,
> Arto
Previous Topic:Export to PNG and Problems with class diagrams
Next Topic:How to re-open a diagram?
Current Time: Thu May 23 16:29:54 EDT 2013
Powered by FUDForum. Page generated in 0.05736 seconds
