Home » Eclipse Projects » Dali » ClassCastException while traversing resources
ClassCastException while traversing resources [message #605358] Mon, 13 August 2007 17:12
Originally posted by: eclipse.spatula.net
When I start Europa or open the JPA perspective, I get the following
message:
An error occurred while traversing resources. Reason:
org.eclipse.jdt.core.dom.QualifiedName
This is on a project which already has a persistence.xml and for which
many Entities were already defined by hand. I added the JPA
natures/facets to it by hand based on the creation of a new JPA project.
That seems to have mostly worked, and I do get the JPA outlines for my
Entities, though not all of the time. Sometimes I also get a red
underline under my @Entity annotation and the error associated with it is
that the entity is not associated with any persistence unit (although it
plainly is in META-INF/persistence.xml and sysinternals.com's Filemon
shows that it was accessed and read). The behaviour here seems to be
somewhat nondeterministic, as sometimes it works and sometimes it doesn't,
with no obvious trigger.
Here's the full stack trace from the error log that causes the error while
traversing resources; perhaps it will be helpful:
java.lang.ClassCastException: org.eclipse.jdt.core.dom.QualifiedName
org.eclipse.jpt.core.internal.jdtutility.EnumArrayDeclaratio nAnnotationElementAdapter.resolve(EnumArrayDeclarationAnnota tionElementAdapter.java:91)
org.eclipse.jpt.core.internal.jdtutility.EnumArrayDeclaratio nAnnotationElementAdapter.getValue(EnumArrayDeclarationAnnot ationElementAdapter.java:66)
org.eclipse.jpt.core.internal.jdtutility.EnumArrayDeclaratio nAnnotationElementAdapter.getValue(EnumArrayDeclarationAnnot ationElementAdapter.java:1)
org.eclipse.jpt.core.internal.jdtutility.MemberAnnotationEle mentAdapter.getValue(MemberAnnotationElementAdapter.java:43)
org.eclipse.jpt.core.internal.jdtutility.ShortCircuitAnnotat ionElementAdapter.getValue(ShortCircuitAnnotationElementAdap ter.java:47)
org.eclipse.jpt.core.internal.content.java.mappings.JavaCasc ade.updateFromJava(JavaCascade.java:574)
org.eclipse.jpt.core.internal.content.java.mappings.JavaRela tionshipMapping.updateFromJava(JavaRelationshipMapping.java: 567)
org.eclipse.jpt.core.internal.content.java.mappings.JavaMult iRelationshipMapping.updateFromJava(JavaMultiRelationshipMap ping.java:700)
org.eclipse.jpt.core.internal.content.java.mappings.JavaAttr ibuteMapping.initialize(JavaAttributeMapping.java:80)
org.eclipse.jpt.core.internal.content.java.JavaPersistentAtt ribute.updateFromJava(JavaPersistentAttribute.java:564)
org.eclipse.jpt.core.internal.content.java.JavaPersistentTyp e.updatePersistentFields(JavaPersistentType.java:694)
org.eclipse.jpt.core.internal.content.java.JavaPersistentTyp e.updatePersistentAttributes(JavaPersistentType.java:677)
org.eclipse.jpt.core.internal.content.java.JavaPersistentTyp e.updateFromJava(JavaPersistentType.java:671)
org.eclipse.jpt.core.internal.content.java.JpaCompilationUni t.synchronizePersistentTypes(JpaCompilationUnit.java:406)
org.eclipse.jpt.core.internal.content.java.JpaCompilationUni t.setFile(JpaCompilationUnit.java:325)
org.eclipse.jpt.core.internal.content.java.JavaJpaFileConten tProvider.buildRootContent(JavaJpaFileContentProvider.java:3 0)
org.eclipse.jpt.core.internal.JpaFileContentRegistry.buildCo ntent(JpaFileContentRegistry.java:60)
org.eclipse.jpt.core.internal.JpaFileContentRegistry.getFile (JpaFileContentRegistry.java:44)
org.eclipse.jpt.core.internal.JpaProject.createJpaFile(JpaPr oject.java:630)
at org.eclipse.jpt.core.internal.JpaProject$3.visit(JpaProject. java:497)
org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:57)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:81)
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:85)
org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:126)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:67)
at org.eclipse.jpt.core.internal.JpaProject.fill(JpaProject.jav a:504)
org.eclipse.jpt.core.internal.JpaModelManager.fillJpaProject (JpaModelManager.java:180)
at org.eclipse.jpt.core.internal.JpaModel$1.visit(JpaModel.java :152)
org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:119)
at org.eclipse.jpt.core.internal.JpaModel.fill(JpaModel.java:15 8)
org.eclipse.jpt.core.internal.JpaModelManager$WorkspaceBuild Job$1.run(JpaModelManager.java:260)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1779)
org.eclipse.jpt.core.internal.JpaModelManager$WorkspaceBuild Job.run(JpaModelManager.java:257)
And here's the session info:
eclipse.buildId=I20070625-1500
java.version=1.5.0_12
Command-line arguments: -os win32 -ws win32 -arch x86
This is with JPA 1.0 in Eclipse Europa.
Previous Topic:Use Dali with EclipseUML 2007 Free Edition
Next Topic:Many problems with Dali
Current Time: Thu Jan 18 20:04:37 GMT 2018
Powered by FUDForum. Page generated in 0.01779 seconds
