Home » Eclipse Projects » Nebula » Using CalendarCombo as a table cell editor
Using CalendarCombo as a table cell editor [message #599346] Fri, 26 March 2010 01:40
Matthew Hall is currently offline Matthew Hall
Hello Emil,
I've been using your CalendarCombo control for some time now. So far
it's worked beautifully (thank you!) but I have a new use case that is
giving me some problems.
I tried adding a CalendarCombo to a TableViewer as a cell editor. I can
type a date into the text cell in the base control. However whenever I
open the drop-down calendar, I can't click on the calendar without the
base control losing focus, which the cell editor seems to detect and
closes the editor.
Any ideas? Is there something special I need to to? I can provide a
standalone snippet if that would help demonstrate the problem I'm having.
Matthew Hall
Previous Topic:Using CalendarCombo as a table cell editor
Next Topic:Gallery with SWT.VIRTUAL
Current Time: Thu May 23 20:20:28 EDT 2013
Powered by FUDForum. Page generated in 0.02225 seconds
