Hi all
I recently upgraded to galileo and it does not support org.eclipse.wst.rdb.sqleditor.SQLEditor which I was using to edit and build my stored procs. So with DTP how do I instruct it to use a specific statement terminator so that it does not confuse the semicolons within the store proc definition and the statement terminators used to drop and create the stored proc
below is how I used to define my stored procs using org.eclipse.wst.rdb.sqleditor.SQLEditor. (double semicolon vs. single semicolon)
T
-- <ScriptOptions statementTerminator=";;" />
DROP PROCEDURE IF EXISTS ... ;;
CREATE PROCEDURE
END;;
GRANT EXECUTE ON PROCEDURE ...;;
What type of database are you using? The statement terminator in the
SQLEditor defaults to ";", but this can be overridden by enablement
plugins. The logic is in the SQLService.splitSQL class.
You might want to try the Data Studio product, which is built on top of
DTP. The SQL editor it includes supports the <ScriptOptions
statementTerminator=...> annotation in your script.
There is a free version available at http://www-01.ibm.com/software/data/optim/data-studio/featur es.html
taly81010@yahoo.com wrote:
> Hi all
> semicolon)
> Thanks
> T
> CREATE PROCEDURE ..;
> END;;
