Home » Modeling » Epsilon » Autocompletition (Total Nub)
Autocompletition (Total Nub) [message #582365] Thu, 29 October 2009 02:20 Go to next message
Horacio Hoyos is currently offline Horacio HoyosFriend
I am a newcomer to both modeling and Epsilon. My prior, and short, experience is with oaw. I was trying to do a small ETL example to initiate my work in Epsilon.
The issue is that in oaw once I defined a variable of a metamodel "type", I could use the '.' (dot) to navigate throught the properties of that varaible. I tried doing the same on ETL but the editor is not giving me any options when either using the '!' or the '.'.
Any pointers?
Horacio Hoyos
Horacio Hoyos Rodriguez
Epsilon Committer
Research Assistant
University Of York
Re: Autocompletition (Total Nub) [message #582387 is a reply to message #582365] Thu, 29 October 2009 11:21 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Horacio,
Epsilon languages such as ETL are not statically typed (there are pros
and cons to this) and as such, code completion is not available in the
editors.
Dimitris
Horacio wrote:
> Hello,
> Any pointers?
> Horacio Hoyos
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Previous Topic:[EVL] ConstraintTrace
Next Topic:Autocompletition (Total Nub)
Current Time: Sat Apr 21 19:06:22 GMT 2018
Powered by FUDForum. Page generated in 0.02215 seconds
