Home » Modeling » Epsilon » Set source.decoration in a link when navigability is BIDIRECTIONAL
Set source.decoration in a link when navigability is BIDIRECTIONAL [message #582135] Thu, 15 October 2009 20:20 Go to next message
marco  is currently offline marco Friend
Member
enum LinkNavigability {
bidirectional = 0;
unidirectional = 1;
@gmf.link(source="from",target="to")
abstract class Link extends Element{
attr LinkNavigability navigability;
ref InteractionPoint[1] from;
ref InteractionPoint[1] to;
ref Component fromContext;
ref Component toContext;
@gmf.link(target.decoration="rhomb")
class SABinding extends Link {
@gmf.link(target.decoration="arrow")
class SAChannel extends Link {
how can I create source.decoration where the attribute navigability has the value 0 (bidirectional)
thanks
marco
Re: Set source.decoration in a link when navigability is BIDIRECTIONAL [message #582195 is a reply to message #582135] Thu, 15 October 2009 21:46 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Marco,
I believe that to update figures in response to changes to the
respective semantic elements, you need to modify the generated code.
Below is a link that appears to be relevant.
http://serdom.eu/ser/2009/01/21/eclipse-gmf-making-figures-s ensitive-to-attributes-of-semantic-elements
Not sure I can help any further with this one as it's clearly not a
EuGENia issue. If you need further help with this, I'd recommend posting
to the GMF forum.
Dimitris
> bidirectional = 0;
> unidirectional = 1;
> thanks
> marco
Previous Topic:Node with 2 labels [GMF]
Next Topic:Cannot reproduce EVL-GMF tutorial
Current Time: Thu May 24 12:28:54 GMT 2018
Powered by FUDForum. Page generated in 0.01389 seconds
