Home » Modeling » Epsilon » Null Pointer Exception when invoking .asOrderedSet in EOL query
Null Pointer Exception when invoking .asOrderedSet in EOL query [message #581643] Thu, 08 October 2009 12:07 Go to next message
Sajit  is currently offline Sajit Friend
Hello Dimitris,
The query in EOL File is:
operation InitialisationDataSet getTimeslotsNot TransmittableTo(other:InitialisationDataSet) : OrderedSet(TimeslotBlock) {
var myTxBs: OrderedSet(TimeslotBlock) := self.getTimeslotBlocks().select(b|b.isExplicitTransmit());
var allTransmittableBs: OrderedSet(TimeslotBlock) := self.getAllTimeslotsTransmittableTo(other);
myTxBs.println();
allTransmittableBs.println();
return myTxBs.reject(b|allTransmittableBs.includes(b));
The statement to execute query using EOL is:
timeslots := ids1.getTimeslotsNotTransmittableTo(ids2).asOrderedSet();
timeslots.println();
The above statement gives the required output. But when executed in Java it throws null pointer exception.
The code in Java is:
EolOperation getAllTimeslotsNotTransmittableTo = module.getOperations().getOperation("getAllTimeslotsNotTransmittableTo ");
List idsList = new ArrayList();
idsList.add(ids2);
EolOrderedSet timeSlots = (EolOrderedSet) getAllTimeslotNotTransmittableTo.execute(ids1, idsList, module.getContext());
The above line gives null pointer exception.
Sajit
Re: Null Pointer Exception when invoking .asOrderedSet in EOL query [message #581663 is a reply to message #581643] Thu, 08 October 2009 13:16 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Sajit,
Could you please check if getAllTimeslotNotTransmittableTo is null? If
so this may be due to the extra space in
getOperation("getAllTimeslotsNotTransmittableTo "); <-
Dimitris
Sajit wrote:
> Hello Dimitris,
> myTxBs.println();
> idsList.add(ids2);
> Sajit
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Previous Topic:Explicit invocation of ETL rule
Next Topic:Explicit invocation of ETL rule
Current Time: Thu Jan 18 21:37:11 GMT 2018
Powered by FUDForum. Page generated in 0.01938 seconds
