Re: [EuGENia] unable to create some elements [message #580890 is a reply to message #580869] |
Fri, 18 September 2009 11:25 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Vasco,
Could you please post your .emf metamodel and indicate the specific
classes that are causing the problems?
Dimitris
Vasco Sousa wrote:
> Hello
> I have some trouble creating basic elements that I think are in the
> scope of elements processed by EuGENia.
> The first one is a gmf.link (for EClass), the problem is
> the class that is used to create the link inherits from an
> abstract class that has no source or target, as I have found
> that abstract elements should also have a representation for
> EuGENia to function properly, I believe the problem lies in
> ether this being really necessary with the impossibility of creating a
> link with foo="bar"
> Abstract
> |---NodeA - gmf.link( source="sourceA", target="targetA")
> | |---sourceA
> | |---targetA
> |---NodeB - gmf.link( source="sourceB", target="targetB")
> |---sourceB
> |---targetB
> The second problem is containments are not created by EuGENia, after its
> forth level. I have :
> canvas
> ->container
> ->container
> ->container
> ->container (this is no longer created in any file as
> container, but their contained nodes are in Graph and Tool)
> ->node.
> If there are any ways to get over these limitation I could use the help.
> Thank you.
> Vasco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
FUDForum. Page generated in 0.02108 seconds
