Home » Modeling » Epsilon » Problem with generated wizards
Problem with generated wizards [message #574155] Sat, 15 August 2009 13:03
St is currently offline StFriend
Member
Hi list,
I have a project with wizards and operations files plus plugin.xml
declaration of wizards for my metamodel, but it doesn't work as it should
: there is only one eclass for which wizards work.
Here is the tar.gz of the workspace:
http://stephaneerard.fr/workspaces-epsilon-tools.tar.gz
The project in question is eclipse-project-0.1.
The working wizard is src/eclipse_project/Project/Project.ewl
I think the problem comes from the plugin.xml declarations as I tested the
ewl files using epsilon prefs and it worked.
I have tried two different nsURI declarations, like:
"http://eclipse-project/0.1"
and
"http://eclipse-project/0.1/Project/Building/Command"
for the eclipse_project::Project::Building::Command eclass as example.
There are no error or warning markers nowhere regarding this problem
(existing errors correspond to generated and copied files from
epsilonTools to eclipse-project, didn't clean the workspace, just delete
epsilonTools/src/src and actions dir somewhere else within to get them
away) :(
Thank you !
Previous Topic:ClassCastException when assigning enum literal to attribute
Next Topic:[EuGENia | EOL] GMFMap Link mapping manipulation
Current Time: Wed Apr 25 18:38:16 GMT 2018
Powered by FUDForum. Page generated in 0.01809 seconds
