Error in EVL Quick Fix: "cannot find resource '/project:/...'" [message #573110] |
Fri, 07 August 2009 15:03 |
--------------090907090104040608050504
Content-Type: text/plain; charset=ISO-8859-1
Hello all,
I've started to define quick fixes for a EVL file I'm using in a model.
Validation works and the markers appear at the right places, but when I
right click one of them and select "Quick Fix" I get an error message
saying that the '/project:/NameOfProject/PathToMyModelFile' resource
does not exist. If I dismiss the error message, all I get is the
"Ignore" default quick fix.
I thought it might be in the same category of issues as bug #285559, so
I looked around with the debugger and found two problems.
- The method getElementResourceLocation of the class
org.eclipse.epsilon.evl.emf.validation.GmfMarkerResolver returns
platform URIs to the workspace files, but they don't have the
"resource" segment, so they look like this:
rather than this:
project:/resource/NameOfProject/PathToMyModelFile
- The method getEditingDomain of the class
org.eclipse.epsilon.evl.emf.validation.EmfMarkerResolver uses the
previous platform URI by creating a Path from it. Reading the
Javadocs for Path, I gather that it expects an absolute filesystem
path, not a platform URI, so that's where the "/project:/foo/bar" part
comes from.
I've attached a quick and dirty patch which solves these two issues. I
don't quite like having to convert the platform URI to a String and then
back to a URL so I can pass it to FileLocator#toFileURL, and I'm not
sure about the way I'm handling exceptions in that call. It does fix the
problem, though. Should I report a bug about this?
By the way: it's not related to this issue, but shouldn't the diagram
editor refresh its contents when the quick fix is applied? Currently, I
have to remember to hit Refresh to see the changes, and if I hit Save,
the old version is saved, instead of the new one.
Antonio
Content-Type: text/x-patch;
name="fix-evl-quickfix.patch"
Content-Disposition: inline;
filename="fix-evl-quickfix.patch"
SW5kZXg6IHNyYy9vcmcvZWNsaXBzZS9lcHNpbG9uL2V2bC9lbWYvdmFsaWRh dGlvbi9FbWZN
YXJrZXJSZXNvbHZlci5qYXZhCj09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KLS0tIHNyYy9vcmcv ZWNsaXBzZS9l
cHNpbG9uL2V2bC9lbWYvdmFsaWRhdGlvbi9FbWZNYXJrZXJSZXNvbHZlci5q YXZhCShyZXZp
c2lvbiA1MjQpCisrKyBzcmMvb3JnL2VjbGlwc2UvZXBzaWxvbi9ldmwvZW1m L3ZhbGlkYXRp
b24vRW1mTWFya2VyUmVzb2x2ZXIuamF2YQkod29ya2luZyBjb3B5KQpAQCAt MTAsMTAgKzEw
LDE1IEBACiAgKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioqKioq
KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqLw0KIHBhY2thZ2Ug b3JnLmVjbGlw
c2UuZXBzaWxvbi5ldmwuZW1mLnZhbGlkYXRpb247DQogDQoraW1wb3J0IGph dmEubmV0LlVS
TDsNCisNCiBpbXBvcnQgb3JnLmVjbGlwc2UuY29yZS5yZXNvdXJjZXMuSUZp bGU7DQogaW1w
b3J0IG9yZy5lY2xpcHNlLmNvcmUucmVzb3VyY2VzLklNYXJrZXI7DQogaW1w b3J0IG9yZy5l
Y2xpcHNlLmNvcmUucmVzb3VyY2VzLlJlc291cmNlc1BsdWdpbjsNCiBpbXBv cnQgb3JnLmVj
bGlwc2UuY29yZS5ydW50aW1lLkNvcmVFeGNlcHRpb247DQoraW1wb3J0IG9y Zy5lY2xpcHNl
LmNvcmUucnVudGltZS5GaWxlTG9jYXRvcjsNCiBpbXBvcnQgb3JnLmVjbGlw c2UuY29yZS5y
dW50aW1lLlBhdGg7DQogaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5jb21tb24u dXRpbC5VUkk7
DQogaW1wb3J0IG9yZy5lY2xpcHNlLmVtZi5lY29yZS5FT2JqZWN0Ow0KQEAg LTUwLDkgKzU1
LDE1IEBACiAJfQ0KIAkNCiAJcHVibGljIEVkaXRpbmdEb21haW4gZ2V0RWRp dGluZ0RvbWFp
bihJTWFya2VyIG1hcmtlcikgew0KLQkJU3RyaW5nIGZpbGVQYXRoID0gZ2V0 RWxlbWVudFJl
c291cmNlTG9jYXRpb24obWFya2VyKTsNCi0JCUlGaWxlIGZpbGUgPSBSZXNv dXJjZXNQbHVn
aW4uZ2V0V29ya3NwYWNlKCkuZ2V0Um9vdCgpLmdldEZpbGUobmV3IFBhdGgo Z2V0RWxlbWVu
dFJlc291cmNlTG9jYXRpb24obWFya2VyKSkpOw0KLQkJU3RyaW5nIGVkaXRv cklkID0gUGxh
dGZvcm1VSS5nZXRXb3JrYmVuY2goKS5nZXRFZGl0b3JSZWdpc3RyeSgpLmdl dERlZmF1bHRF
ZGl0b3IoZmlsZVBhdGgpLmdldElkKCk7DQorCQlTdHJpbmcgc1Jlc291cmNl TG9jYXRpb24g
PSBnZXRFbGVtZW50UmVzb3VyY2VMb2NhdGlvbihtYXJrZXIpOw0KKwkJU3Ry aW5nIHNGaWxl
UGF0aDsNCisJCXRyeSB7DQorCQkJc0ZpbGVQYXRoID0gRmlsZUxvY2F0b3Iu dG9GaWxlVVJM
KG5ldyBVUkwoc1Jlc291cmNlTG9jYXRpb24pKS5nZXRQYXRoKCk7DQorCQl9 IGNhdGNoIChF
eGNlcHRpb24gZSkgew0KKwkJCXNGaWxlUGF0aCA9IHNSZXNvdXJjZUxvY2F0 aW9uOw0KKwkJ
fQ0KKwkJSUZpbGUgZmlsZSA9IFJlc291cmNlc1BsdWdpbi5nZXRXb3Jrc3Bh Y2UoKS5nZXRS
b290KCkuZ2V0RmlsZUZvckxvY2F0aW9uKG5ldyBQYXRoKHNGaWxlUGF0aCkp Ow0KKwkJU3Ry
aW5nIGVkaXRvcklkID0gUGxhdGZvcm1VSS5nZXRXb3JrYmVuY2goKS5nZXRF ZGl0b3JSZWdp
c3RyeSgpLmdldERlZmF1bHRFZGl0b3Ioc1Jlc291cmNlTG9jYXRpb24pLmdl dElkKCk7DQog
CQkNCiAJCS8vUGxhdGZvcm1VSS5nZXRXb3JrYmVuY2goKS5nZXRFZGl0b3JS ZWdpc3RyeSgp
Lg0KIAkJDQpJbmRleDogc3JjL29yZy9lY2xpcHNlL2Vwc2lsb24vZXZsL2Vt Zi92YWxpZGF0
aW9uL0dtZk1hcmtlclJlc29sdmVyLmphdmEKPT09PT09PT09PT09PT09PT09 PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQotLS0g c3JjL29yZy9l
Y2xpcHNlL2Vwc2lsb24vZXZsL2VtZi92YWxpZGF0aW9uL0dtZk1hcmtlclJl c29sdmVyLmph
dmEJKHJldmlzaW9uIDUyNCkKKysrIHNyYy9vcmcvZWNsaXBzZS9lcHNpbG9u L2V2bC9lbWYv
dmFsaWRhdGlvbi9HbWZNYXJrZXJSZXNvbHZlci5qYXZhCSh3b3JraW5nIGNv cHkpCkBAIC03
Myw3ICs3Niw3IEBACiAJCQ0KIAkJCQ0KIAkJLy9VUkkgdXJpID0gVVJJLmNy ZWF0ZVVSSSht
YXJrZXIuZ2V0UmVzb3VyY2UoKS5nZXRGdWxsUGF0aCgpLnRvU3RyaW5nKCkp Ow0KLQkJU3Ry
aW5nIGxvY2F0aW9uID0gInBsYXRmb3JtOiIgKyBtYXJrZXIuZ2V0UmVzb3Vy Y2UoKS5nZXRG
dWxsUGF0aCgpLnRvU3RyaW5nKCk7DQorCQlTdHJpbmcgbG9jYXRpb24gPSAi cGxhdGZvcm06
L3Jlc291cmNlIiArIG1hcmtlci5nZXRSZXNvdXJjZSgpLmdldEZ1bGxQYXRo KCkudG9TdHJp
bmcoKTsNCiAJCQ0KIAkJLy9TeXN0ZW0uZXJyLnByaW50bG4oIkdNRiA6ICIg KyBsb2NhdGlv
bik7DQogCQkNCg==
--------------090907090104040608050504--
FUDForum. Page generated in 0.03191 seconds
