Home » Eclipse Projects » Eclipse 4 » Setting the input on a dynamically opened part.
Setting the input on a dynamically opened part. [message #568276] Tue, 02 February 2010 15:34 Go to next message
Jens Keller is currently offline Jens KellerFriend
Member
This time no question and instead a little tutorial on setting the input data on a newly openend part descriptor.
See http://www.eclipse.org/forums/index.php?t=msg&th=160958& amp;start=0& thread for a way to open a part descriptor at runtime.
First you need to define a variable in your Application.e4xmi which is used to pass the part input.
<variables>input</variables>
Then you can use the IEclipseContext to modify and read this variable.
IEclipseContex.modify( "input", inputObject );
IEclipseContext.get( "input" );
This means in detail:
Open the part descriptor:
EPartService.showPart( partDescriptor.getID() );
Find the newly opened part and use it's IEclipseContext to modify the variable:
Collection<MPart> col = servicePart.getParts();
for(MPart part : col){
if( part.getId().equals( partDescriptor.getID() ) ){
part.getContext().modify( "input", partInput );
break;
And now the following method in the part should get called:
@Inject
@Optional
public void setPartInput( @Named( "input" ) Object partInput ) { ... }
For more information you can look in the e4 photo demo ( in Libray.java at line 117 the variable
is modified to promote the actual selected photo to the other parts which implement a setSelection() method)
or http://wiki.eclipse.org/E4/EAS/Selection eclipsepedia article.
Re: Setting the input on a dynamically opened part. [message #568302 is a reply to message #568276] Tue, 02 February 2010 16:29 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
Maybe you want to start a wiki-page documenting little snippets with
code so that people can be pointed there always?
Tom
Am 02.02.10 16:34, schrieb Jens Keller:
> data on a newly openend part descriptor. See
> variable:
> partInput );
> break;
> @Inject
> @Optional
> at line 117 the variable is modified to promote the actual selected
> photo to the other parts which implement a setSelection() method) or
Previous Topic:Remote javascript debugger
Next Topic:New e4 snippets wiki-page
Current Time: Fri Apr 20 03:20:29 GMT 2018
Powered by FUDForum. Page generated in 0.01300 seconds
