Home » Modeling » Epsilon » TemplateFactory.load help
TemplateFactory.load help [message #566877] Tue, 21 April 2009 06:56
No real name is currently offline No real name
Member
Hi there,
I have in an EGL script the following line:
var t : Template := TemplateFactory.load('./Other.egl');
Previously, this line worked, but after my version of Epsilon from the SVN
I find that I get the following error:
Internal error: java.lang.IllegalArgumentException: URI is not absolute
at java.net.URI.toURL[URI.java:1080]
at org.eclipse.epsilon.egl.EglModule.parse[EglModule.java:97]
at org.eclipse.epsilon.egl.types.EglTemplate.<init>[EglTemplate.java:48]
org.eclipse.epsilon.egl.types.EglFileGeneratingTemplate.<init >[EglFileGeneratingTemplate.java:50]
org.eclipse.epsilon.egl.template.FileGeneratingTemplateFacto ry.load[FileGeneratingTemplateFactory.java:51]
at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
Do you have any ideas why this might have occurred.
I believe I am probably using the method incorrectly, as I may have
unintentionally changed some of my code along the lines. However, when
having a naive look in to the code, as to why this might error might be
happenning I noticed that in:
org.eclipse.epsilon.egl.template.TemplateFactory
the resolveTemplate method calls UriUtil.resolve(path, templateRoot, root)
-- and on inspection templateRoot and root are null. Should this be the
case? Perhaps I need to call the TemplateFactory.load method differently?!
Any help to resolve this issue would be much appreciated.
PS. I'm running this EGL script from a standard launch configuration.
All the best,
Edd
Previous Topic:EWL setting a profile/stereotype and trigger the wizard
Next Topic:Access to the Diagram Model
Current Time: Mon May 20 11:23:40 EDT 2013
Powered by FUDForum. Page generated in 0.04106 seconds
