[Eugenia] Generate GMF ... does nothing!? [message #564778] |
Fri, 06 February 2009 09:35 |
Michael Moser Messages: 914 Registered: July 2009 |
Hi - I wanted to give Eugenia a try but ran into a problem (or bug?):
I downloaded/installed Epsilon from
http://download.eclipse.org/modeling/gmt/epsilon/updates/ and then
exactly followed the screencast at
http://www.eclipse.org/gmt/epsilon/cinema/Eugenia.htm
I copy-pasted the File system example found a
http://epsilonlabs.wiki.sourceforge.net/EuGENia into the Emfatic editor
as suggested and was able to create the .ecore file from the .emf file -
no problems.
I then created the .genmodel file as instructed and next issued the
Eugenia => Generate GMF tool, map and graph models command.
But, alas, in contrast to the screencast nothing happens here, i.e.
there are no .gmf* files showing up in the model folder (nor anywhere
else).
What am I missing? This is using Eclipse 3.4.1 (Ganymede) and Epsilon
0.8.3.
There are no problems, i.e. all files seem fine and have no syntax
errors.
I also checked the eclipse log file and it show no entry.
Hints, ideas, suggestions?
Michael
FUDForum. Page generated in 0.03331 seconds
