Home » Eclipse Projects » Eclipse 4 » UI rendering in Web
UI rendering in Web [message #564142] Wed, 28 October 2009 14:35 Go to next message
saurav sarkar is currently offline saurav sarkarFriend
Hi All,
A very basic question to clear my understandingNow AFAIK in the desktop to web concept the Eclipse SWT UIs can be rendered in the web browser.
Now would the exsisting UI's which has been made with earlier releases be also rendered into web automatically or i have to do some migration steps to achieve the same.
Please provide your inputs on the same.
Thanks and Regards,
Saurav
Re: UI rendering in Web [message #564179 is a reply to message #564142] Wed, 28 October 2009 17:27 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
If you have an RCP app a project called RAP is already available to help support rendering it in a web browser.
Is this not what you are looking for? http://www.eclipse.org/rap/
PW
Paul Webster
Previous Topic:any references to command handler syntax?
Next Topic:can't get started with RCP using e4
Current Time: Sun Apr 22 09:02:07 GMT 2018
Powered by FUDForum. Page generated in 0.01639 seconds
