Home » Eclipse Projects » Eclipse 4 » Error in running the photo demo
Error in running the photo demo [message #562997] Wed, 02 September 2009 08:36 Go to next message
David Wynter is currently offline David WynterFriend
Followed here,
http://wiki.eclipse.org/E4/UI/Running_the_photo_demo
got
!SESSION 2009-09-01 22:36:11.843
eclipse.buildId=unknown
java.version=1.6.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.e4.demo.e4photo.product
Command-line arguments: -product org.eclipse.e4.demo.e4photo.product
-data C:\workspace/../runtime-e4photo.product -dev
file:C:/workspace/.metadata/.plugins/org.eclipse.pde.core/e4 photo.product/dev.properties
-os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-09-01 22:36:14.859
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"org.eclipse.e4.ui.workbench.swt.application" could not be found in the
registry. The applications available are: org.eclipse.equinox.app.error.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.osgi 2 0 2009-09-01 22:36:14.890
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-09-01 22:36:14.890
!MESSAGE Bundle
initial@reference:file:plugins/org.w3c.dom.smil_1.0.1.v200903091627.jar/
was not resolved.
!SUBENTRY 2 org.w3c.dom.smil 2 0 2009-09-01 22:36:14.890
!MESSAGE Missing imported package org.w3c.dom.events_[3.0.0,4.0.0).
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle org.eclipse.e4.ui.css.core_0.9.0.v20090727-2030 [8] was
not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.core 2 0 2009-09-01 22:36:14.890
!MESSAGE Missing required bundle org.apache.batik.css_[1.6.0,1.7.0).
!MESSAGE Bundle org.w3c.dom.smil_1.0.1.v200903091627 [11] was not resolved.
!MESSAGE Bundle org.eclipse.e4.ui.workbench.swt_0.9.0.v20090723-1500
[16] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2009-09-01 22:36:14.890
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.nebula_0.9.0.
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.core_0.9.0.
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.swt_0.9.0.
!MESSAGE Bundle org.apache.batik.css_1.6.0.v200805290154 [20] was not
resolved.
!SUBENTRY 2 org.apache.batik.css 2 0 2009-09-01 22:36:14.890
!MESSAGE Missing required bundle org.w3c.dom.svg_0.0.0.
!MESSAGE Bundle org.eclipse.e4.ui.css.swt_0.9.0.v20090727-2030 [23] was
not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt 2 0 2009-09-01 22:36:14.890
!MESSAGE Bundle org.eclipse.e4.ui.css.nebula_0.9.0.v20090716-1930 [28]
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.nebula 2 0 2009-09-01 22:36:14.890
!MESSAGE Bundle org.w3c.dom.svg_1.1.0.v200806040011 [36] was not resolved.
!SUBENTRY 2 org.w3c.dom.svg 2 0 2009-09-01 22:36:14.890
!MESSAGE Missing required bundle org.w3c.dom.smil_0.0.0.
!MESSAGE Bundle
org.eclipse.e4.ui.workbench.renderers.swt_0.9.0.v20090726-11 30 [47] was
not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.renderers.swt 2 0 2009-09-01
22:36:14.890
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench.swt_0.9.0.
!MESSAGE Bundle
org.eclipse.e4.ui.workbench.renderers.swt.contributions_0.9. 0.v20090720-2115
[56] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.renderers.swt.contributions 2 0
I checked and these bundles are installed?
Thx.
David
Re: Error in running the photo demo [message #563024 is a reply to message #562997] Wed, 02 September 2009 13:41 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
This causes the cascade failure you are seeing:
That package should be coming from your JRE, I can see it in JDK 1.4.2, 1.5.0 and 1.6.0 Do you have the javax.xml bundle in your install, 1.3.4?
How did you get set to run the Demo? Just take 3.5.0 and update all of the pieces (EMF, e4 UI, e4 CSS)?
PW
Paul Webster
Re: Error in running the photo demo [message #563074 is a reply to message #563024] Sat, 05 September 2009 10:13 Go to previous message
> PW
I followed the tutorial to the letter, so yes installed 3.5.0 and then
updated all the pieces as defined in the tutorial. I note in the
Installed software list that plugin id org.w3c.dom.events does exist
with the Version 3.0.0.draft20060314_v2009005140418. Which does satisfy
the version requirements of the imported package. Is there something
ewlse I need to do to make e4 aware of this plugins presense?
Thx.
David
Previous Topic:Something is fishy
Next Topic:Error when running my RCP product using e4 as the target platform
Current Time: Thu Apr 19 10:13:56 GMT 2018
Powered by FUDForum. Page generated in 0.02352 seconds
