Home » Archived » GMT (Generative Modeling Technologies) » Invoking Java from Moscript problems ...
Invoking Java from Moscript problems ... [message #560514] Thu, 09 November 2006 13:49
Originally posted by: iscrquinter.gmail.com
I am trying to invoke a Java class method using the the following code:
psmSM.ESStubGenerator::generateAxisStub(){
var wsdlAddress : String = self.wsdlAddress;
var cp : String = "c:/Documents and Settings/Ricardo Quintero/Mis
documentos/Doctorado/Tesis/New
Tesis/Tesis/wsEclipseTest/JavaAdapters2AXIS/bin;" +
"c:/axis/lib/activation.jar;" +
"c:/axis/lib/axis.jar;" +
"c:/axis/lib/axis-ant.jar;" +
"c:/axis/lib/commons-discovery-0.2.jar;" +
"c:/axis/lib/commons-logging-1.0.4.jar;" +
"c:/axis/lib/jaxrpc.jar;" +
"c:/axis/lib/log4j-1.2.8.jar;" +
"c:/axis/lib/saaj.jar;" +
"c:/axis/lib/wsdl4j-1.5.1.jar;" +
"c:/axis/lib/xercesImpl.jar;" +
"c:/axis/lib/xml-apis.jar";
java("adapters.wsdl2java.WSDL2JavaAdapter","generateStubfrom ",wsdlAddress,cp)
The method adapters.wsdl2Java.WSDLJavaAdapter (that is defined in anotoher
project in the same workspace) calls the org.apache.wsdl.WSDLJava.main
method (of the AXIS framework), but Eclipse stops running and crash-down
....(boom !!!)
I tested on Eclipse 3.1 and 3.2 ...and with Mofscript 1.1.11 ... and the
results are the same ...
What can I do ? What am I doing wrong ? Some suggestion ?
Previous Topic:[oaw] type.name empty for uml::PrimitiveType
Next Topic:Invoking Java from Moscript problems ...
Current Time: Sat Jan 20 07:35:19 GMT 2018
Powered by FUDForum. Page generated in 0.02176 seconds
