Home » Eclipse Projects » BIRT » Problem with Sorting table data
Problem with Sorting table data [message #559333] Thu, 16 September 2010 12:10 Go to next message
JP Redro is currently offline JP RedroFriend
Hi All,
As per the following thread i have embedded sorting script in befroeFactory. But i am getting error message. Please suggest me.
http://www.eclipse.org/forums/index.php?S=effb3763c6d4f471e8 4910218211526d&t=msg&th=159352
My Code is:
importPackage(Packages.org.eclipse.birt.report.model.api);
importPackage(Packages.org.eclipse.birt.report.model.api.ele ments);
importPackage(Packages.com.ibm.icu.util);
importPackage(Packages.org.eclipse.birt.data.engine.api);
delm = reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "LITEM");
sc = StructureFactory.createSortKey();
sc.setKey("row[\"LNO\"]");
sc.setDirection("desc");
ph = delm.getPropertyHandle(TableHandle.SORT_PROP);
ph.addItem(sc);
Getting following error :
Caused by: org.mozilla.javascript.EcmaError: TypeError: Cannot call method "getPropertyHandle" of null (<inline>#10) at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
JP.
JP
Re: Problem with Sorting table data [message #559455 is a reply to message #559333] Thu, 16 September 2010 17:00 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
JP,
the error is that LITEM is not found. Did you name the report item in
its general properties. Also try this if you are using 2.3.2 or above:
delm = reportContext.getDesignHandle().findElement( "LITEM");
Jason
Re: Problem with Sorting table data [message #559619 is a reply to message #559455] Fri, 17 September 2010 12:04 Go to previous messageGo to next message
pasupuleti  is currently offline pasupuleti Friend
Hi Jason ,
we are using 2.2.1 version
Yes it is named in general properties.
Data soure : XML type
Our requirement as followings
We need to sort the information based on the line number before loading into the report layout . Could please suggest ,how to achieve it in birt 2.2.1.
PA
[Updated on: Fri, 17 September 2010 12:05]
Report message to a moderator
Re: Problem with Sorting table data [message #559679 is a reply to message #559619] Fri, 17 September 2010 14:51 Go to previous message
Where are you getting line number? Do you want it to be row number?
BTW can you try:
delm = reportContext.getReportRunnable().designHandle.findElement(
"LITEM");
Jason
On 9/17/2010 8:04 AM, pasupuleti wrote:
> Hi Jason ,
> yes it is name the report item in
> general properties.
> 2.2.1.
> PA
Previous Topic:Difference between sorting in BIRT 2.5 and 2.6 (Grouping and sorting in charts)
Next Topic:Arrange Column data in a row
Current Time: Sat Jan 20 23:14:27 GMT 2018
Powered by FUDForum. Page generated in 0.02079 seconds
